Home » Eclipse Projects » e(fx)clipse » Drag&drop issue when exchanging an Object via DragBoard
Drag&drop issue when exchanging an Object via DragBoard [message #1195188] Mon, 18 November 2013 17:11 Go to next message
I'm setting up a drag&drop communication between TreeView and a Pane containing few fields.
At first, I'm trying to exchange a String: this works just fine.
Then, I'm trying to exchange an Object, and this is where things break apart.
I'm not really sure if this is specific to E(fx)clipse or applicable to JavaFX in general...
Here are details:
I'm setting up an EventHandler on the sending side this way:
private EventHandler<MouseEvent> getMouseDragHandler(final ResourceTreeCell cell) {
return new EventHandler<MouseEvent>() {
public void handle(MouseEvent event) {
if(cell.getItem().getType()==ArgoObjectType.DEVICE) {
Dragboard db = cell.startDragAndDrop(TransferMode.ANY);
ClipboardContent content = new ClipboardContent();
content.put(DataFormats.RESOURCE_DEVICE, cell.getItem());
db.setContent(content);
event.consume();
The receiving side gets setup like this:
private void setDragAndDropHandlers(Pane pane) {
pane.setOnDragOver(
new EventHandler<DragEvent>() {
public void handle(DragEvent event) {
if(event.getGestureSource()!=this && event.getDragboard().hasContent(DataFormats.RESOURCE_DEVICE)) {
event.acceptTransferModes(TransferMode.COPY);
event.consume();
pane.setOnDragDropped(
boolean success = false;
if(event.getDragboard().hasContent(DataFormats.RESOURCE_DEVICE)) {
Object ooo = event.getDragboard().getContent(DataFormats.RESOURCE_DEVICE);
ArgoObject source = (ArgoObject) event.getDragboard().getContent(DataFormats.RESOURCE_DEVICE);
success = true;
event.setDropCompleted(success);
event.consume();
and here is a shared DataFormat object:
public static final DataFormat RESOURCE_DEVICE = new DataFormat("com.videonext.argo.resource.device");
I'm getting next exception on receiving side: java.lang.ClassCastException: java.nio.HeapByteBuffer cannot be cast to com.videonext.pleiades.argo.data.model.ArgoObject
"ooo" has java.nio.HeapByteBuffer class, so obviously it throws an exception on the very next line.
ArgoObject is implementing Serializable as it is supposed to do.
Re: Drag&amp;drop issue when exchanging an Object via DragBoard [message #1195203 is a reply to message #1195188] Mon, 18 November 2013 17:24 Go to previous messageGo to next message
You better ask a general JavaFX forum. This is pure FX-Code and no
e(fx)clipse special stuff is involved.
Tom
> apart.
> Here are details:
> @Override
> cell.getItem());
> event.consume();
> pane.setOnDragOver(
> @Override
> event.consume();
> @Override
> Object ooo =
> success = true;
> event.consume();
Re: Drag&amp;drop issue when exchanging an Object via DragBoard [message #1196507 is a reply to message #1195203] Tue, 19 November 2013 07:59 Go to previous messageGo to next message
Thank you, Tom.
I've opened a similar thread here: https://forums.oracle.com/thread/2604605
Will post solution here if I get one.
Re: Drag&amp;drop issue when exchanging an Object via DragBoard [message #1199346 is a reply to message #1196507] Wed, 20 November 2013 15:17 Go to previous messageGo to next message
I've answered my own question in Oracle forum on the link posted above... pretty much RTFM Smile
The essence: when registering a DataFormat, you have to use the fully-qualified class name, not just some arbitrary name Smile
Re: Drag&amp;drop issue when exchanging an Object via DragBoard [message #1199369 is a reply to message #1199346] Wed, 20 November 2013 15:32 Go to previous messageGo to next message
OPS... spoke too early... please disregard prior post
Re: Drag&amp;drop issue when exchanging an Object via DragBoard [message #1462311 is a reply to message #1199369] Wed, 05 November 2014 07:48 Go to previous message
For what it's worth, I think this is an issue with JavaFX and OSGi not playing nice together
JavaFX gets a ClassNotFoundException when trying to deserialize the object, and returns a ByteBuffer instead. JavaFX expects the class to be on the classpath, but in an OSGi environment the class (ArgoObject in your case) is not visible to JavaFX.
I'm not sure what the best solution is. You could serialize the object yourself and put a string in the dragboard, or you could get the ByteBuffer object and finish the deserialization once you are back inside an OSGi context where the ArgoObject class is visible.
Previous Topic:Building a native executable with Eclipse 4.4 and e(fx)clispe
Next Topic:e(fx)clipse 1.1.0 is released
Current Time: Sun Jul 20 09:31:39 EDT 2025
Powered by FUDForum. Page generated in 0.04180 seconds
