Home » Modeling » GMF (Graphical Modeling Framework) » How to define a predefined sequence attributes?
How to define a predefined sequence attributes? [message #1198722] Wed, 20 November 2013 08:27 Go to next message
my doubt is:
I have a node called Variant. Variant has a set of attributes like name and id for example.
What I want is every time that I insert a Variant the attributes can be inserted automatically, for example.
I inserted the first Variant, so the attributes will be..
The Second Variant
and So on..
Can someone help me?
Re: How to define a predefined sequence attributes? [message #1199135 is a reply to message #1198722] Wed, 20 November 2013 12:53 Go to previous messageGo to next message
I tried the following:
NFRSoftgoalImpl nfrsoftgoal = (NFRSoftgoalImpl ) ((NodeImpl) NFRSoftgoalEditPart.this.getModel()).getElement();
int id = sequence_soft.getAndIncrement();
nfrsoftgoal.setId(String.valueOf(id));
nfrsoftgoal.setNFRSoftgoalPriority(BigInteger.valueOf(id));
nfrsoftgoal.setName("NFRSoftgoal" + id);
but, the following error happened: java.lang.IllegalStateException: Cannot modify resource set without a write transaction
I don't know how to solve this problem....
Re: How to define a predefined sequence attributes? [message #1200455 is a reply to message #1199135] Thu, 21 November 2013 03:49 Go to previous messageGo to next message
you can do what you want to do by using the gmfmap model. There is something called FeatureSeqInitializer which you can use. Your bug happens because you are not using a command. For you task you could use an EMF SetCommand.create(...) and execute it on a command stack which you can get from your edit parts for example getEditingDomain().getCommandStack().execute(command).
Ralph
Re: How to define a predefined sequence attributes? [message #1200786 is a reply to message #1198722] Thu, 21 November 2013 07:11 Go to previous messageGo to next message
I need something more concrete.
What you said is very "empty" for me.
Re: How to define a predefined sequence attributes? [message #1202798 is a reply to message #1200786] Fri, 22 November 2013 05:17 Go to previous messageGo to next message
take a look here (http://wiki.eclipse.org/Graphical_Modeling_Framework/Tutorial/Part_2#Feature_Initializers). They use it.
Ralph
Re: How to define a predefined sequence attributes? [message #1203263 is a reply to message #1198722] Fri, 22 November 2013 10:11 Go to previous messageGo to next message
I used the Feature Seq Initializers, but this tip doesn't do what I want.
It just initialize an attribute. What I want is every time that I insert an node, the attribute can be inserted automatically, for example.
The Second Variant
The Feature Seq Initializers only put a value for an attribute, the attribute doesn't change like a iteration above... 1 and after 2 and so on...
Re: How to define a predefined sequence attributes? [message #1209925 is a reply to message #1198722] Mon, 25 November 2013 14:32 Go to previous messageGo to next message
Help me please.
Re: How to define a predefined sequence attributes? [message #1213637 is a reply to message #1209925] Wed, 27 November 2013 05:21 Go to previous message
I do not get your point. What you want to do is counting the instances as far as I understand. In OCL it would be something like [MetaType].allInstances()->size() + 1. This would generate a counter for each attribute.
Ralph
Previous Topic:Preferential Updates of shortcuts
Next Topic:How can i make Compartment with Grid layout ?
Current Time: Sun Jul 20 08:57:31 EDT 2025
Powered by FUDForum. Page generated in 0.06364 seconds
