Home » Eclipse Projects » Eclipse Scout » Table in Table Column(Add a Table in Table Column Field)
Table in Table Column [message #1189289] Fri, 15 November 2013 21:23 Go to next message
Use case
I have a Table of Employees, and for each row ( Employee ), I would like to show the corresponding Dependants horizontally in one of the columns.
Table ( Employee )
=> Column Name ( String )
=> Column Dependants ( Table )
=>=> Table ( Dependants )
=>=>=> Column Name ( String )
=>=>=> Column DOB ( Date )
=>=>=> Column Other Details ( HTML )
I *don't want* to have Master Details kind of presentation where the List of all employees is shown at the top and details are shown in another table below for the selected employee.
-Walter
Re: Table in Table Column [message #1193832 is a reply to message #1189289] Mon, 18 November 2013 02:38 Go to previous messageGo to next message
I'm not sure what your question is, but I assume that you are wondering what widget to use to display this information, is this correct?
One possibility would be to use a table, where the entry in the first column (Name) is repeated for each dependant (though I'm not sure how well that will work with the "Other Details", depending on how much information you have in there).
Another possibility might be a TreeField, where each Employee is a top level node, then all the Dependants are child nodes of the employee they belong to and their Name, DOB and Details could be nodes of each "dependant node". Same here, though, I'm not sure the HTML details can be shown easily.
In case you are looking for a combination of a tree and a table, I don't think that is available in Scout at the moment.
If this does not answer your question, you might need to elaborate a little. Also, it would probably help if you actually asked a question, so we would know what it is that you hope to get form this post Smile
Re: Table in Table Column [message #1194404 is a reply to message #1193832] Mon, 18 November 2013 08:47 Go to previous messageGo to next message
Well, I am looking for a Tabbox where I have a table shown.
For each row, I need to embed another table in a particular column.
Is that possible ?
Secondly, is it possible to embed HTML contents in a column. Basically, it would be a workaround for the above mentioned use case.
-Thanks.
Re: Table in Table Column [message #1200282 is a reply to message #1194404] Thu, 21 November 2013 01:52 Go to previous messageGo to next message
Walter Mising name wrote on Mon, 18 November 2013 14:47
where I have a table shown.For each row, I need to embed another table in a particular column.
Somone from the Scout developer team correct me if I'm wrong, but I think neither of the two things you want to do is possible, that is why I described some workarounds that could be used as an approximation to what you want.
Re: Table in Table Column [message #1201774 is a reply to message #1200282] Thu, 21 November 2013 17:44 Go to previous message
Hi Walter
I also think that there is no such thing as a "table within a table" in Scout. A table field is probably not particularily well suited to represent this kind of hierarchical data.
If you a) need to display some HTML content anyway and b) your parent table has only two columns (employee name and dependants) you're maybe better off with a HtmlField? It allows rendering arbitrary HTML content, including HTML tables.
"Walter Mising name"
Well, it depends Smile Scout does not offer this feature by itself, but you can exploit the underlying UI technology to some extent.
Swing renders HTML in most of its UI components [1]. You can use this feature also in a Scout Swing client: Just surround the content of a StringColumn with <html>...</html> tags. You need to enable the "text wrap" property on a StringColumn if you want to render multi-line content in a single table row.
As far as I know, the SWT client does not support HTML rendering in this way.
I have quickly verified that HTML rendering also works in the RAP client, but it seems that it is not possible to render multi-line content in the same way as in the Swing client.
[1] http://docs.oracle.com/javase/tutorial/uiswing/components/html.html
Lukas
Previous Topic:Exception with anchors in HtmlField
Next Topic:SWT Client startup Error
Current Time: Sat Jul 19 16:02:19 EDT 2025
Powered by FUDForum. Page generated in 0.04095 seconds
