Home » Eclipse Projects » Equinox » P2 update sites
P2 update sites [message #118826] Thu, 02 October 2008 14:34 Go to next message
Originally posted by: fireresq.embarqmail.com
I'm looking for the documentation that describes the p2 update sites and how to set them up.
I have a collection of tools that are built on top of each other
CommonBase Feature is the base of all of the code
Tool1 Feature is the non-UI code for Tool1 and is based on CommonBase Feature
Tool1UI Feature is the UI code for Tool1 and is based on Tool1 Feature and CommonBase Feature
Tool2 Feature is the non-UI code for Tool2 and is based on CommonBase Feature
Tool2UI Feature is the UI code for Tool2 and is based on CommonBase Feature and Tool2 Feature
Tool3 Feature is the non-UI code for Tool3 and is based on CommonBase Feature, Tool1 Feature, and Tool2 Feature
Tool3UI Feature is the UI code for Tool3 and is based on CommonBase Feature and Tool3 Feature
What I'm wondering is how do I set up a P2 update site so that a user can point to the Tool3UI feature update site and have P2
find rest of the dependencies. If anyone could point me to documentation that helps me with this.
Re: P2 update sites [message #118958 is a reply to message #118826] Sat, 04 October 2008 00:10 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
If you want one site for all the features, I can point you to what I do
to aggregate multiple projects' updates into a single site.
http://wiki.eclipse.org/Modeling_Project_Releng/Releasing/Up date_Site_Generation
If you want p2 to be able to read across multiple sites, then AFAIK the
solution is to provide one feature which defines discovery URLs, so that
the p2 Update UI can discover those URLs, explore them, and determine
what updates are required to install Tool3 (by implicitly installing the
plugins of Tool2, Tool1, etc.
Beyond that, I suggest the wiki:
http://wiki.eclipse.org/Category:Equinox_p2
Nick
> how to set them up.
> Feature
> Feature
> can point to the Tool3UI feature update site and have P2 find rest of
> me with this.
Re: P2 update sites [message #119126 is a reply to message #118958] Wed, 08 October 2008 11:17 Go to previous messageGo to next message
Thanks Nick. Can you point me to some documentation on how to build the discovery sites?
> Nick
>> Feature
>> Feature
>> helps me with this.
Re: P2 update sites [message #119374 is a reply to message #119126] Sun, 12 October 2008 02:24 Go to previous messageGo to next message
A discovery site == an update site. Only difference is in the
feature.xml, where you either have an <update> or a <discovery>.
<url>
<update label="%EMFUpdateSiteName"
url="http://download.eclipse.org/modeling/emf/updates/"/>
<discovery label="%EMFTUpdateSiteName"
url="http://download.eclipse.org/modeling/emft/updates/"/>
</url>
> discovery sites?
>> do to aggregate multiple projects' updates into a single site.
>> the solution is to provide one feature which defines discovery URLs,
>> so that the p2 Update UI can discover those URLs, explore them, and
>> determine what updates are required to install Tool3 (by implicitly
>> installing the plugins of Tool2, Tool1, etc.
>> Nick
>>> Feature
>>> Feature
>>> helps me with this.
Re: P2 update sites [message #119488 is a reply to message #119374] Mon, 13 October 2008 15:37 Go to previous message
Nick, thanks for your help.
> <url>
> </url>
>>> Nick
>>>> CommonBase Feature
>>>> CommonBase Feature
>>>> user can point to the Tool3UI feature update site and have P2 find
Previous Topic:Can't startup eclipse after update to 3.4.1
Next Topic:P2 Automatic Updates - problem with org.eclipse.equinox.p2.metadata.repository?
Current Time: Sat Jul 19 11:17:18 EDT 2025
Powered by FUDForum. Page generated in 0.23918 seconds
