Home » Modeling » GMF (Graphical Modeling Framework) » connections are duplicated
connections are duplicated [message #118811] Thu, 12 April 2007 09:48 Go to next message
Originally posted by: S.Kemmann.gmx.de
Hi there!
I'm using GMF2.0M5 and I (still) have the "old" problem of duplicated
connections like the known problem of GMF1.0!
Has anyone an idea, what this is?
Which policies are responsible for creating connections (to maybe debug my
code)?
Thanks for your help!
S
Re: connections are duplicated [message #118825 is a reply to message #118811] Thu, 12 April 2007 10:15 Go to previous messageGo to next message
Originally posted by: fbanica.soluta.net
Look, I'm not sure if it was the same problem for me (I never worked with
GMF 1.0), but I had this problem of duplicated connections. It turned out to
be because of my wrong meta-model (.ecore).
So, this could be an idea. Look there first.
Floppy
"Sren Kemmann" <S.Kemmann@gmx.de> wrote in message
news:evldb1$l44$1@build.eclipse.org...
> Hi there!
> code)?
> Cheers,
> Sren
Re: connections are duplicated [message #118940 is a reply to message #118811] Thu, 12 April 2007 13:57 Go to previous messageGo to next message
If its from different compartments it seems to be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=148021
There are explanations and possible fixes in the bugzilla entry.
> debug my code)?
AFAIK the generated *ItemSemanticEditPolicy classes.
ciao,
elm
Re: connections are duplicated [message #118953 is a reply to message #118940] Thu, 12 April 2007 13:58 Go to previous messageGo to next message
> > debug my code)?
More specifically the *ItemSemanticEditPolicy for the domain element
that is the source or target of the connection.
ciao,
elm
Re: connections are duplicated [message #118979 is a reply to message #118940] Thu, 12 April 2007 14:27 Go to previous message
Hi Elmar,
yes! It is not from a different compartment, but from a nested node and it
is exactly the bug
The workaround is working, too ... so, I will just apply the workaround.
Thanks!
S
Previous Topic:GMF and JET2
Next Topic:Sample project showing creation of links to links in GMF
Current Time: Sat Jul 19 06:26:54 EDT 2025
Powered by FUDForum. Page generated in 0.03847 seconds
