Home » Language IDEs » Java Development Tools (JDT) » Kepler UI Bug After Linux Upgrade
Kepler UI Bug After Linux Upgrade [message #1144276] Fri, 18 October 2013 15:26 Go to next message
Hello everybody,
Yesterday I upgraded my Ubuntu installation to 13.10 and found that upon entering Kepler none of the drop down menus (File, Edit, Refactor, etc.) are functional. I can use keyboard shortcuts to get to them, but even then most of the options are missing.
I understand that this is probably a function of my OS upgrade, but this is only happening with Eclipse so I figured I'd come here to see if anyone else has dealt with this problem or a similar one in the past.
I'd like to avoid purging/reinstalling because I've customized the editor a fair amount... but if I have to so be it.
Re: Kepler UI Bug After Linux Upgrade [message #1185205 is a reply to message #1144276] Wed, 13 November 2013 19:06 Go to previous message
Any luck? Or did you purge?
Previous Topic:Set default VM arguments for all JUnit Tests?
Next Topic:Property view not usable
Current Time: Sat Jul 19 14:55:24 EDT 2025
Powered by FUDForum. Page generated in 0.26501 seconds
