Home » Modeling » EMF » [CDO] ClassCastException loading EJavaObject
[CDO] ClassCastException loading EJavaObject [message #1173489] Wed, 06 November 2013 10:04 Go to next message
I am looking for some help with a problem I am seeing when attempting to recall an EAttribute of type EJavaObject.
I run the data store, then run my client application. I am able to create and persist the object to the database. I then shut down the client application and data store. I restart the data store and when I attempt to restart the client application I get the following exception:
java.lang.ClassCastException: [B cannot be cast to java.lang.String
	at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$26.doWriteValue(CDOTypeImpl.java:558)
	at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$ObjectType.writeValue(CDOTypeImpl.java:1028)
	at org.eclipse.emf.cdo.spi.common.protocol.CDODataOutputImpl.writeCDOFeatureValue(CDODataOutputImpl.java:491)
	at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.writeValues(BaseCDORevision.java:918)
	at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.write(BaseCDORevision.java:239)
	at org.eclipse.emf.cdo.spi.common.protocol.CDODataOutputImpl.writeCDORevision(CDODataOutputImpl.java:381)
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.writeRevision(RevisionInfo.java:221)
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.writeResult(RevisionInfo.java:159)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevisionsIndication.responding(LoadRevisionsIndication.java:188)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:133)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
	at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndication.execute(CDOServerReadIndication.java:36)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:724)
When inspecting the error, I can see that the byte[] extracted from the blob field is trying to be cast to a string.
Am I doing something incorrectly when setting the value to this EJavaObject EAttribute or is this a bug?
Kyle
Re: [CDO] ClassCastException loading EJavaObject [message #1173601 is a reply to message #1173489] Wed, 06 November 2013 11:32 Go to previous messageGo to next message
Am 06.11.2013 16:04, schrieb Kyle B:
> Hello,
> at
What CDO version are you using? EJavaObject serialization support has been added in 4.2:
* @since 4.2
public static final CDOType JAVA_OBJECT = org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl.JAVA_OBJECT;
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] ClassCastException loading EJavaObject [message #1173633 is a reply to message #1173601] Wed, 06 November 2013 12:00 Go to previous messageGo to next message
I meant to include the CDO version in my original post. I apologize. We are using CDO 4.2.0.v20130613-1557.
Re: [CDO] ClassCastException loading EJavaObject [message #1184617 is a reply to message #1173489] Wed, 13 November 2013 10:21 Go to previous messageGo to next message
Eike,
I believe EJavaObject serialization is implemented for the version of CDO I am using. Any further thoughts on the exception I am seeing?
Kyle
Re: [CDO] ClassCastException loading EJavaObject [message #1197239 is a reply to message #1173489] Tue, 19 November 2013 15:35 Go to previous messageGo to next message
Tried upgrading to CDO 4.3-M2 (S20131002-0920) and issue persisted.
Re: [CDO] ClassCastException loading EJavaObject [message #1227414 is a reply to message #1197239] Sat, 04 January 2014 07:24 Go to previous message
Am 19.11.2013 21:35, schrieb Kyle B:
I've fixed it in: https://bugs.eclipse.org/bugs/show_bug.cgi?id=423355
Cheers
/Eike
Previous Topic:[CDO] ClassCastException persisting EJavaObject to DB
Next Topic:[CDO] Oracle: Writing null to boolean value probably should use Types.BIT instead if Types.BOOLEAN
Current Time: Sun Jul 20 17:08:55 EDT 2025
Powered by FUDForum. Page generated in 0.24735 seconds
