Home » Eclipse Projects » Remote Application Platform (RAP) » observe when user hit the browser refresh button
observe when user hit the browser refresh button [message #117627] |
Tue, 06 January 2009 09:15  |
I have a little problem.
I'm using a background thread to update some data from a server every 20
seconds.
The user can start and stop the update manually.
But when this update is running and the user is pressing the refresh
button of the browser, I get an SWTException: Invalid thread access.
Is there any possibility to observe when user hit the browser refresh
button, so that I can first stop this update???
Roland
Re: observe when user hit the browser refresh button [message #117640 is a reply to message #117627] |
Tue, 06 January 2009 09:47   |
Originally posted by: benjamin.wolff.web.de
Hi Roland,
the problem is that there doesn't seem to be a reliable way to notice when the user leaves the page or closes the browser.
the method postWindowClose() is not called in this case. this is a problem for me, because i have to rely on the tomcat
session timeout to close the ressources (database etc.). the postWindowClose() is only called when the User uses a logout or
exit action. it is possible to specify a exitconfirmation when the user leaves the page or closes the browser, but this is realised
with a simple javascript function that pops up a dialog with a string. if there is, or will be, any way to bind a method call, upon leaving the
browser, via javascript i'd really love to hear it :).
if the session is destroyed upon refreshing the page you could hook an listener on the session and use the method beforeDestroy() to cancel running
jobs...
greetings,
ben
Roland Siebert schrieb:
> seconds.
> Roland
Re: observe when user hit the browser refresh button [message #117650 is a reply to message #117640] |
Tue, 06 January 2009 11:08   |
Hmm,
I tried out the method postWindowClose() and it will be called when I
hit the refresh button.
Roland
Ben W. schrieb:
> Hi Roland,
> running
> jobs...
> greetings,
> ben
Re: observe when user hit the browser refresh button [message #117661 is a reply to message #117650] |
Tue, 06 January 2009 11:50   |
hi,
could you please check if the method is also called when closing the browser (X) or leaving the url?
greetings,
ben
> Hmm,
> Roland
> Ben W. schrieb:
>> Hi Roland,
>> running
>> jobs...
>> greetings,
>> ben
Re: observe when user hit the browser refresh button [message #117777 is a reply to message #117661] |
Wed, 07 January 2009 05:44   |
yes, it will be called when you reload the page, close the browser,
close the tab and also when you type another url.
Roland
Ben W. schrieb:
> hi,
> greetings,
> ben
>> Hmm,
>> Roland
>> Ben W. schrieb:
>>> Hi Roland,
>>> leaving the
>>> cancel running
>>> jobs...
>>> greetings,
>>> ben
Re: observe when user hit the browser refresh button [message #117811 is a reply to message #117800] |
Wed, 07 January 2009 07:41   |
Just a note of clarification, there are reliable mechanisms to
observe *whenever* a session terminates (e.g. ISessionStoreListener,
postWindowClose). However, closing the browser window or tab does
*not* terminate the session. The session is terminated after the
session-timeout has elapsed without any request being sent to the
session.
In RAP, this behavior hasn't changed since ever.
HTH
Rüdiger
Ben W. wrote:
> i've tested this by launching the app from eclipse and launching
> deployed on a tomcat.
> using firefox, it seems that the mechanism works fine now, the method is
> called when leaving
> the url or closing the browser, almost always. With Internet Explorer it
> doesn't seem to work
> very reliable but the method is also called many times.
> this is a very pleasant change because this didn't work so reliably in
> the past which gave
> me some problems.
> very nice!!!
> greetings
> ben
>> Is this a new feature ? Some time ago exactly that didn't work (at
>> least not when closing the browser) and I can't remember having read
>> something about this in the release notes ?
>> That would be really great indeed, if that worked now !
Re: observe when user hit the browser refresh button [message #117822 is a reply to message #117811] |
Wed, 07 January 2009 08:01   |
Hi Rüdiger,
i use the postWindowClose() method to close the session immediately (set the timeout on 1 second programmatically), the
ISessionStoreListener always worked fine, that's right.
Greetings,
ben
Rüdiger Herrmann schrieb:
> Just a note of clarification, there are reliable mechanisms to observe
> postWindowClose). However, closing the browser window or tab does *not*
> session-timeout has elapsed without any request being sent to the session.
> HTH
> Rüdiger
> Ben W. wrote:
>> Hi,
>> is called when leaving
>> it doesn't seem to work
>> the past which gave
>> me some problems.
>> very nice!!!
>> greetings
>> ben
Re: observe when user hit the browser refresh button [message #117846 is a reply to message #117822] |
Wed, 07 January 2009 09:11  |
Ben,
sorry, my previous post was misleading. Of course the
SessionStoreListener is the only way to stay informed about the end
of a session.
Rüdiger
Ben W. wrote:
> Hi Rüdiger,
> Greetings,
> ben
>> session.
>> HTH
>> Rüdiger
>> Ben W. wrote:
>>> Hi,
>>> in the past which gave
>>> me some problems.
>>> very nice!!!
>>> greetings
>>> ben
>>>>>> browser, close the tab and also when you type another url.
Current Time: Sat Jul 19 20:31:48 EDT 2025
Powered by FUDForum. Page generated in 0.46969 seconds
