Home » Eclipse Projects » Commercial » New Eclipse plug-in for building data-intensive Java on multicore h/w
New Eclipse plug-in for building data-intensive Java on multicore h/w [message #11737] Thu, 21 December 2006 18:35
Originally posted by: ebernabei.pervasive.com
If you've ever had to write an application to process gigabytes or
terabytes of data, it's more than likely it wasn't multi-threaded and
multicore SMP aware. Concurrent programming in Java is extremely
difficult, time-consuming and error prone. Perl, Python, COBOL, C.. it
doesn't matter -- it won't use more than 1 core of 1 CPU in your server.
Well, Eclipse users don't need to worry about all that anymore. You just
need to know simple Java constructs and XML scripting. No threading. No
shared memory mgmt. No deadlock detection. No vertical, horizontal and
pipeline parallelism algorithms. The Java framework below does it all for
you; just like J2EE does most of the hard-lifting for web apps.
For a sneak-peek of Pervasive DataRush Beta 1 w/ Eclipse plug-in, go here:
http://www.pervasivedatarush.com/beta
Thanks for saving your IT shop a ton of time and money (while cutting the
runtime of your app by 1/5th).
Emilio
Previous Topic:New Eclipse plug-in for building data-intensive Java on multicore h/w
Next Topic:Commercial use of BIRT
Current Time: Sat Jul 19 14:43:34 EDT 2025
Powered by FUDForum. Page generated in 0.05406 seconds
