Home » Modeling » TMF (Xtext) » How to display contents of Xtext index (builder.state)?
How to display contents of Xtext index (builder.state)? [message #1173365] Wed, 06 November 2013 08:19 Go to next message
how to display the contents of the Xtext index in an editor in a human-readable form? (I am using 2.4.3)
The file builder.state (in .metadata/.plugins/org.eclipse.xtext.builder) is now a binary file. In former times this was an XML file which made it quite easy to view and discover problems with global scoping.
Tim
Re: How to display contents of Xtext index (builder.state)? [message #1173560 is a reply to message #1173365] Wed, 06 November 2013 10:59 Go to previous messageGo to next message
cant you bind a changed PersistedStateProvider through the org.eclipse.xtext.ui.shared.overridingGuiceModule extension point?
Re: How to display contents of Xtext index (builder.state)? [message #1173661 is a reply to message #1173560] Wed, 06 November 2013 12:22 Go to previous messageGo to next message
Hi Christian,
of course this will work, but it seems to me not very convenient to have to change the index-persisting "machinery" to just be able to read this file. I thought there might be some clever editor which can be used through "Open with ...".
Tim
Re: How to display contents of Xtext index (builder.state)? [message #1173720 is a reply to message #1173661] Wed, 06 November 2013 13:14 Go to previous messageGo to next message
i dont know of such an editor. maybe you should file a bug agains sample ecore model editor etc...
Re: How to display contents of Xtext index (builder.state)? [message #1173742 is a reply to message #1173720] Wed, 06 November 2013 13:36 Go to previous messageGo to next message
P.S:
maybe a simple transposition helps
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl;
import org.eclipse.xtext.builder.builderState.BuilderStatePackage;
import org.eclipse.xtext.builder.builderState.EMFBasedPersister;
@SuppressWarnings("restriction")
public class Main {
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
		EPackage.Registry.INSTANCE.put(BuilderStatePackage.eNS_URI, BuilderStatePackage.eINSTANCE);
		Resource resource = new EMFBasedPersister().getFactory().createResource(URI.createURI("builder.state"));
		Map options = new HashMap<>();
		options.put(XMIResourceImpl.OPTION_BINARY, true);
		try {
			resource.load(options );
			System.out.println(resource);
			Resource rs2 = new ResourceSetImpl().createResource(URI.createURI("out.xmi"));
			rs2.getContents().addAll(resource.getContents());
			rs2.save(null);
		} catch (IOException e) {
			e.printStackTrace();
Re: How to display contents of Xtext index (builder.state)? [message #1174708 is a reply to message #1173742] Thu, 07 November 2013 04:11 Go to previous message
Hi Christian,
thanks a lot! Your code works out of the box. I will file a bug against the sample ecore model editor.
Tim
Previous Topic:[ContentAssistant] Propose type involving ImportManager
Next Topic:Replace object after linking
Current Time: Sun Jul 20 16:10:05 EDT 2025
Powered by FUDForum. Page generated in 0.05677 seconds
