Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with ScrolledComposite
Problem with ScrolledComposite [message #116927] Mon, 22 December 2008 08:04 Go to next message
I have a problem with ScrolledComposite.
When I start this little Snippet the Labels were cut off at the end.
But when I reload the page, everything will displayed fine.
Very strange!!!
And another problem is that I can't get it working that the Labels were
displayed centered.
Can anybody help me with this???
Roland
public class Test implements IEntryPoint {
public int createUI() {
Display display = PlatformUI.createDisplay();
Shell shell = new Shell( display );
shell.setBounds( 100, 100, 200, 200 );
shell.setLayout( new GridLayout() );
ScrolledComposite scroll = new ScrolledComposite( shell, SWT.V_SCROLL );
scroll.setLayoutData( new GridData( SWT.FILL, SWT.FILL, true, true ) );
scroll.setLayout( new GridLayout() );
Composite composite = new Composite( scroll, SWT.NONE );
composite.setLayoutData( new GridData( SWT.CENTER, SWT.CENTER, true,
true ) );
GridLayout gridLayout_1 = new GridLayout();
gridLayout_1.verticalSpacing = 150;
composite.setLayout( gridLayout_1 );
scroll.setContent( composite );
Label label = new Label( composite, SWT.NONE );
label.setLayoutData( new GridData( SWT.CENTER, SWT.CENTER, true, false
label.setText( "Label" );
composite.pack();
shell.open();
while ( !shell.isDisposed() ) {
if ( !display.readAndDispatch() ) {
display.sleep();
return 0;
Re: Problem with ScrolledComposite [message #117043 is a reply to message #116927] Tue, 23 December 2008 06:28 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
Hi Roland,
see my answers bellow...
Roland Siebert wrote:
> Very strange!!!
I can't reproduce it with CVS HEAD. Which version of RAP do you use?
Which browser?
> were displayed centered.
You just need to call scroll.setExpandHorizontal( true ); to instruct
ScrolledComposite to resize the content object to be as wide as the
ScrolledComposite itself.
> Roland
Best,
Ivan
> SWT.V_SCROLL );
> true ) );
> true, true ) );
> true, false ) );
> true, false ) );
> true, false ) );
> composite.pack();
> shell.open();
> display.sleep();
> return 0;
Re: Problem with ScrolledComposite [message #117161 is a reply to message #117043] Wed, 24 December 2008 08:12 Go to previous message
i found a solution.
After filling the compsite i call "scrolledComposite.setMinSize(
composite.computeSize( SWT.DEFAULT, SWT.DEFAULT ) );"
And for the center-problem it is working with
"scrolledComposite.setExpandHorizontal( true );"
Thanks.
Roland
Ivan Furnadjiev schrieb:
> Hi Roland,
>> Hi,
>> Very strange!!!
> Which browser?
>> Roland
> Best,
> Ivan
>> SWT.V_SCROLL );
>> true ) );
>> true, true ) );
>> true, false ) );
>> true, false ) );
>> true, false ) );
>> composite.pack();
>> shell.open();
>> display.sleep();
>> return 0;
Previous Topic:Change the color and weight of Table line
Next Topic:TreeViewer not expanding, and Tree widget
Current Time: Sun Jul 20 16:42:14 EDT 2025
Powered by FUDForum. Page generated in 0.03660 seconds
