Home » Archived » Visual Editor (VE) » making getXXX methods public/protected
making getXXX methods public/protected [message #117005] Mon, 06 February 2006 10:54 Go to next message
Originally posted by: markus.wawra.shark-soft.com
Hi!
When I add a component (f.e. JButton) with the VE, it creates a private
getXXX Method in the source code. Like:
* This method initializes jButton1
* @return javax.swing.JButton
private JButton getJButton1() {
if (jButton1 == null) {
jButton1 = new JButton();
return jButton1;
Can I tell VE to create public or protected getXXX methods?
Markus
Re: making getXXX methods public/protected [message #117071 is a reply to message #117005] Mon, 06 February 2006 14:27 Go to previous messageGo to next message
No. Typically you would not want to do that because you are exposing the
internals of the class. Which is usually not a good idea. You would
typically only want a small subset of the internals to be public.
Because of that you would simply change it to public in the class editor
pane for those you want public.
Markus wrote:
> Hi!
> return jButton1;
> Regards,
> Markus
Rich Kulp
Re: making getXXX methods public/protected [message #117255 is a reply to message #117071] Thu, 09 February 2006 10:04 Go to previous messageGo to next message
Even if it's untypically I want to create a VE extension which generates
protected (or public, I'm not sure so far) getXXX methods. I found a file
where I can easily change the text for the created methods
(org.eclipse.ve.java.core_1.1.0\templates\org\eclipse\ve\int ernal\java\codegen\jjet\util\DefaultMethod
Template.javajet). This works fine if I change the file directly in the
org.eclipse.ve.java.core plugin.
My next problem is:
How can I change it with a VE plugin extension?
Is there an extensionpoint?
Or is the editing in the org.eclipse.ve.java.core plugin the only way?
Markus
Re: making getXXX methods public/protected [message #117281 is a reply to message #117255] Thu, 09 February 2006 14:42 Go to previous message
That is the only way, and is not a good way. We were thinking of doing
that way back in the past, but it has many problems. But we never
removed the code. But we don't provide any official support to allow the
change.
> file where I can easily change the text for the created methods
> My next problem is:
> Regards,
> Markus
Rich Kulp
Re: making getXXX methods public/protected [message #611978 is a reply to message #117005] Mon, 06 February 2006 14:27 Go to previous message
Markus wrote:
> Hi!
> return jButton1;
> Regards,
> Markus
Rich Kulp
Re: making getXXX methods public/protected [message #611992 is a reply to message #117071] Thu, 09 February 2006 10:04 Go to previous message
My next problem is:
Markus
Re: making getXXX methods public/protected [message #611994 is a reply to message #117255] Thu, 09 February 2006 14:42 Go to previous message
change.
> My next problem is:
> Regards,
> Markus
Rich Kulp
Previous Topic:Restricitions about bmp files
Next Topic:Override file is not processed
Current Time: Sat Jul 19 14:49:29 EDT 2025
Powered by FUDForum. Page generated in 0.05038 seconds
