Home » Eclipse Projects » Remote Application Platform (RAP) » "entry point does not exist" after adding plugins?
"entry point does not exist" after adding plugins? [message #116228] |
Fri, 19 December 2008 04:06  |
Folks;
not sure what exactly is my problem here; I followed [1] to pack up a basic
RAP application into a .war file and deploy this to our GFv3prelude
application server which works pretty fine after coming across some basic
issues. Getting more curageous however, I tried to build a RAP application
being a SOAP client to some backend system. So, basically, all I did was
- looking up the required bundles (axis, javax.xml and friends) in the stock
eclipse plugins/ folder and copying them over to my RAP target platform,
- reloading the target platform and making these plugins known to the IDE,
- building a web service client and implementation, running it locally using
jetty in the IDE,
- followed [1], added the required features, built and deployed my .war file
to just end up with
"java.lang.IllegalArgumentException: An entry point named 'default' does not
exist."
Well. Running the same application inside jetty in the IDE works flawlessly.
As far as I could tell, all the required packages and configuration files
are contained in the .war file, and, worse, I don't see no log output
whatsoever on the server machine. Seems the OSGi Console is unusable on the
server (Solaris) as well as, though it does dump an "osgi>" prompt to the
log file, I can't (obviously...) do any input to there which comes as no
surprise somehow. So to ask:
- Is there a sane way how to figure out whether packages are missing in a
configuration according to [1]?
- Can I make my application logging output, being deployed to a server, a
little more verbose?
- Any quick guesses where to look in this case? Is this a "common mistake"?
Thanks in advance and all the best,
Kristian
[1] http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html
Re: "entry point does not exist" after adding plugins? [message #116304 is a reply to message #116228] |
Fri, 19 December 2008 05:55   |
Kristian,
first thing to do would be consult the OSGi log and the console. If
you cannot gain access to this in your current environment, try
something simpler, e.g. a tomcat running locally.
HTH
Rüdiger
Kristian Rink wrote:
> Folks;
> jetty in the IDE,
> to just end up with
> exist."
> Kristian
Re: "entry point does not exist" after adding plugins? [message #117402 is a reply to message #116319] |
Mon, 05 January 2009 03:23  |
Hi Kristian,
an alternative would be to specify a port after the -console parameter
and use connect to it using Telnet.
Stefan.
>> just an "osgi>" prompt which one can't interact with. I am not sure whether
>> the "-console" OSGi option really works on a Linux platform, after all?
> Answering myself, at the very least I got this fixed and posted the answer
> here [1] as this seems a question arising once in a while yet not having a
> documented answer out there... Now to see why this bundle isn't correctly
> started...
> Cheers & thanks,
> Kristian
> [1]http://dm.zimmer428.net/index.php/archives/423
Current Time: Sat Jul 19 05:48:04 EDT 2025
Powered by FUDForum. Page generated in 0.07327 seconds
