Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » No notifications for changes to model objects after saving a JpoxResource
No notifications for changes to model objects after saving a JpoxResource [message #115806] |
Wed, 26 March 2008 07:23  |
Hi!
I'm using an EMF editor backed by Teneo with a JpoxResource. In addition I'm
using the EMF validation framework with a live validation. Upon loading the
editor with the resource, notifications about model changes are passed to
my validation class. After saving the resource however, changes to the
model do not result in any notifications. I have debugged the problem a
bit. Upon a call to a setter method on a model object, the method checks
for eNotificationRequired() and sends a notification if the check returns
true. It returns true before hitting save, but it does not after the
resource was saved once.
The following code is an excerpt of the save(Map<?, ?> options) method of
StoreResource:
public void save(Map<?, ?> options) {
boolean err = true;
try {
setAllowNotifications(false);
validateContents();
saveResource(options);
err = false;
} finally {
setAllowNotifications(true);
It disables notifications, saves the resource and enabled notifications
afterwards. The problem is that the second call to setAllowNotifications()
does not propagate to all model objects. The reason is the use of the
NonLoadingEContentsEList class in getNonResolvingContent(EObject) of the
StoreResource class. setAllowNotifications(boolean) uses this method to
iterate over the content and the loaded member variable of the
PersistableEList of the reference containing all model elements is false
after saving the resource.
Shall I file a bug or is that expected behaviour?
Florian
Florian Hackenberger
Re: No notifications for changes to model objects after saving a JpoxResource [message #115819 is a reply to message #115806] |
Wed, 26 March 2008 07:37   |
Hi Florian,
It seems that the issue is related to the loaded member of the persistableelist.
A few questions:
is the loaded member of the epersistableelist also false before saveResource(options) is called?
so the contents of the persistableelist is really loaded (it should be as the notifications flag of
its content is set to false)?
During save no notifications should be sent out, however it is a bug if the notification flag is not
repaired afterwards.
If the loaded flag is set to false during the saveResource, then if you can debug where this happens
then it is probably easy to solve.
gr. Martin
DI Florian Hackenberger wrote:
> Hi!
> StoreResource:
> boolean err = true;
> try {
> validateContents();
> err = false;
> } finally {
> Cheers,
> Florian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: No notifications for changes to model objects after saving a JpoxResource [message #115845 is a reply to message #115819] |
Wed, 26 March 2008 09:34   |
> persistableelist.
It certainly is if the use of NonLoadingEContentsEList is correct.
> A few questions:
> saveResource(options) is called? so the contents of the persistableelist
> is really loaded (it should be as the notifications flag of its content is
> set to false)?
It is set to true before hitting save and set to false afterwards.
> the notification flag is not repaired afterwards.
> can debug where this happens then it is probably easy to solve.
It is not actually set to false. A new instance of EListWrapper is generated
for the structural feature when
List<?> list = (List<?>) eObject.eGet(eref);
is called in NonLoadingEContentsEList::create(EObject, boolean) after the
call to saveResource(options). The new instance has its attribute loaded
set to false, because JPOXArrayList::isLoaded() returns false and therefore
the load() method of EListWrapper is not invoked in the constructor
EListWrapper(StateManager, String, List<E>)
Here is the stack trace:
EListWrapper<E>.<init>(StateManager, String, List<E>) line: 137
EListWrapper<E>.<init>(StateManager, String) line: 105
EListMapping.createWrapper(StateManager, String, List<?>) line: 190
EListMapping.newWrapper(StateManager, String) line: 59
EListMapping.postFetch(StateManager) line: 223
FetchRequest.execute(StateManager) line: 228
ClassTable.fetch(StateManager, AbstractPropertyMetaData[]) line: 2552
RDBMSManager(StoreManager).fetch(StateManager, int[]) line: 959
StateManagerImpl.loadNonDFGFields(int[]) line: 1734
StateManagerImpl.isLoaded(PersistenceCapable, int) line: 2034
CallcenterConfigurationImpl.jdoGetelements(CallcenterConfigu rationImpl)
line: not available
CallcenterConfigurationImpl.getElements() line: 164
CallcenterConfigurationImpl.eGet(int, boolean, boolean) line: 328
CallcenterConfigurationImpl(BasicEObjectImpl).eGet(EStructur alFeature,
boolean, boolean) line: 1002
boolean) line: 994
CallcenterConfigurationImpl(BasicEObjectImpl).eGet(EStructur alFeature) line:
989
NonLoadingEContentsEList<E>.create(EObject, boolean) line: 48
JPOXResource(StoreResource).getNonResolvingContent(EObject) line: 807
StoreResource$2.getChildren(Object) line: 794
StoreResource$2(AbstractTreeIterator<E>).next() line: 142
JPOXResource(StoreResource).setAllowNotifications(boolean) line: 823
JPOXResource(StoreResource).save(Map<?,?>) line: 353
The original instance of the list is loaded via a call to eIsSet(int) for
the feature. Here is the stacktrace:
EListWrapper<E>(PersistableEList<E>).load() line: 207
EListWrapper<E>.load() line: 805
EListWrapper<E>(PersistableEList<E>).delegateIsEmpty() line: 376
EListWrapper<E>(DelegatingEList<E>).isEmpty() line: 241
CallcenterConfigurationImpl.eIsSet(int) line: 406
CallcenterConfigurationImpl(BasicEObjectImpl).eIsSet(EStruct uralFeature)
line: 1225
EContentsEList$ResolvingFeatureIteratorImpl<E>(EContentsEList$FeatureIteratorImpl <E>).hasNext()
line: 427
LiveValidationContentAdapter(EContentAdapter).setTarget(EObj ect) line: 222
To me it seems that the PersistableEList simply implements a lazy loading
scheme and setAllowNotifications() is not aware of this fact.
Florian
Re: No notifications for changes to model objects after saving a JpoxResource [message #115912 is a reply to message #115845] |
Wed, 26 March 2008 13:06   |
Yes the NonLoadingEContentsEList should be used here. What I don't yet
understand is why the StateManagerImpl.isLoaded call replaces the list, afaics it should re-use the
one which is already present, it should consider the field as being loaded.
Can you enter a bugzilla for this? Then I'll pick it up in the next build (this weekend).
gr. Martin
>> persistableelist.
>> A few questions:
>> set to false)?
> line: not available
> boolean) line: 994
> 989
> line: 1225
> line: 427
> Cheers,
> Florian
The Netherlands
Re: No notifications for changes to model objects after saving a JpoxResource [message #615985 is a reply to message #115806] |
Hi Florian,
A few questions:
gr. Martin
> Hi!
> StoreResource:
> boolean err = true;
> try {
> validateContents();
> err = false;
> } finally {
> Cheers,
> Florian
The Netherlands
Re: No notifications for changes to model objects after saving a JpoxResource [message #615987 is a reply to message #115819] |
> persistableelist.
> A few questions:
> set to false)?
line: not available
boolean) line: 994
989
line: 1225
line: 427
Florian
Re: No notifications for changes to model objects after saving a JpoxResource [message #615992 is a reply to message #115845] |
gr. Martin
>> persistableelist.
>> A few questions:
>> set to false)?
> line: not available
> boolean) line: 994
> 989
> line: 1225
> line: 427
> Cheers,
> Florian
The Netherlands
Current Time: Sat Jul 19 20:59:30 EDT 2025
Powered by FUDForum. Page generated in 0.04749 seconds
