Home » Modeling » EMF » org.eclipse.emf.databinding problem(Adding org.eclipse.emf.databinding seems to cause plugin with view to not display)
org.eclipse.emf.databinding problem [message #1156338] Sat, 26 October 2013 09:34 Go to next message
I'm attempting to following this tutorial:
www.vogella.com/articles/EclipseDataBindingEMF/article.html
i.e. EMF & Databinding.
In order to satisfy this code:
DataBindingContext bindingContext = new DataBindingContext();
    bindingContext.bindValue(WidgetProperties.text(SWT.Modify).observe(Description),
        EMFProperties.value(OisContractTemplatePackage.Literals.STATEMENT__ITEM)
            .observe(stmnt));
I need to add this dependency:
As soon as I add that dependency in my plugin.xml, even if I still have ONLY the template generated code (so the above code is commented out), when I run the application the view is not available from the list.
As soon as I remove the dependency, the view is back in the list!
What's going on!
Greg
Re: org.eclipse.emf.databinding problem [message #1156349 is a reply to message #1156338] Sat, 26 October 2013 09:43 Go to previous messageGo to next message
Just validate your run configuration's plugins, i.e. most probably you are missing other dependencies.
Also have a look at the console log...
Re: org.eclipse.emf.databinding problem [message #1156439 is a reply to message #1156338] Sat, 26 October 2013 11:07 Go to previous messageGo to next message
OK - so I figured out a little more...
The reason mine doesn't work and the tutorial does is because I'm trying to do mine as a custom view plugin to an existing set of EMF/GMF based projects. So my databinding project is not an RCP (as per the tutorial).
So why does it matter if it's an RCP App? And how do I get this to work...?
Greg
Re: org.eclipse.emf.databinding problem [message #1156770 is a reply to message #1156349] Sat, 26 October 2013 16:33 Go to previous message
Thanks for the response.
Found it in the end - missing bundle in my Run Config. Grrrr.....
Previous Topic:[CDO]How the Ecore dynamic model with cdos, saved to the database, thank you????
Next Topic:[CDO] How to make sure cdoLockState().isLocked is up to date ?
Current Time: Sat Jul 19 08:00:43 EDT 2025
Powered by FUDForum. Page generated in 0.04818 seconds
