Re: How do I get my code to work? [message #1156279 is a reply to message #1155458] |
Sat, 26 October 2013 08:38  |
This forum is for helping you deal with issues involving downloading,
installing and using Eclipse. It's not to help you with your homework,
to answer general programming or even Java questions.
I would also suggest that you haven't thought very deeply about your
predicament. In the first place, you don't state in very clear terms
what your problem is nor what you think your code is doing that doesn't
conform to purpose given.
For the future, I would suggest that you peruse this link:
http://www.catb.org/esr/faqs/smart-questions.html#intro
Its mere suggestion to use a meaningful subject should, when compared to
the one under which you sent this question, provide you a source of
great enlightenment.
Best of luck.
On 10/25/2013 07:56 PM, kevin belaen wrote:
> Hi I need to make a random generator (1-50) that stops when it hits 22.
> I need to find the max and min of the numbers displayed after it hits 22.
> [snip]
FUDForum. Page generated in 0.08362 seconds
