Home » Newcomers » Newcomers » How do I get my code to work?(Random generator, min, max, average)
icon5.gif  How do I get my code to work? [message #1155458] Fri, 25 October 2013 19:16 Go to next message
Hi I need to make a random generator (1-50) that stops when it hits 22. I need to find the max and min of the numbers displayed after it hits 22.
This is what I have so far
public static void main(String[] args) throws FileNotFoundException {
Random generator = new Random();
File infile = new File("myrandomnumbers.txt");
PrintWriter prw = new PrintWriter("myrandomnumbers.txt");
Scanner filescan = new Scanner(infile);
int random;
int max=0;
int min=0;
int avg=0;
int count=0;
int numb;
random = generator.nextInt(51);
max = random;
min = random;
while (count !=22)
numb=generator.nextInt(51);
System.out.println(numb);
prw.println(random);
if (random > max)
max = random;
if (random < min)
min = random;
System.out.println("The min is "+ min);
prw.println("The min is "+ min);
System.out.println("The max is "+ max);
prw.println("The max is "+ max);
//System.out.println("The average is "+ avg);
//prw.println("The average is "+ avg);
Please help! I'm so lost Sad
Re: How do I get my code to work? [message #1156279 is a reply to message #1155458] Sat, 26 October 2013 08:38 Go to previous message
This forum is for helping you deal with issues involving downloading,
installing and using Eclipse. It's not to help you with your homework,
to answer general programming or even Java questions.
I would also suggest that you haven't thought very deeply about your
predicament. In the first place, you don't state in very clear terms
what your problem is nor what you think your code is doing that doesn't
conform to purpose given.
For the future, I would suggest that you peruse this link:
http://www.catb.org/esr/faqs/smart-questions.html#intro
Its mere suggestion to use a meaningful subject should, when compared to
the one under which you sent this question, provide you a source of
great enlightenment.
Best of luck.
> [snip]
Previous Topic:Not Showing :(
Next Topic:Password for instaling eclipse
Current Time: Sat Jul 19 15:55:23 EDT 2025
Powered by FUDForum. Page generated in 0.08214 seconds
