Re: Examples [message #1208895 is a reply to message #1207910] |
Mon, 25 November 2013 03:24  |
It's difficult to see what's wrong in your projects. I would like to
propose to you to follow step by step the "Getting Started" guide as
said by Pierre-Charles. And, only after, try to make your own modeler.
Laurent
Le 24/11/2013 22:04, Nawel Amok a écrit :
> hello Laurent,
> Quote:
>> In the previous mail you say
>> > i am using my own ecore model
>> This file is a family ecore file or other one?
> no it's not the family ecore file it's my own(just for testing)
> Quote:
>> In the runtime you should have an ecore file (not a .odesign file) in
>> your Modeling Project.
> no i haven't any ecore file in runtime..
> here is an snapshot of what i have in runtime :
> https:/
> /drive.google.com/file/d/0BxB67dkOikCSV2ZIc0FkaWhLSWM/edit?usp=sharing
> thank you,
> Nawel
Re: Examples [message #1739787 is a reply to message #1154419] |
Fri, 25 October 2013 09:56  |
Le 25/10/2013 09:23, Jan Koehnlein a écrit :
Hi.
> is there any example project to play around with?
There are many examples that work with the pre-Sirius version of the
code, which was code-named Viewpoint and available as part of Obeo
Designer [1]. If that's OK for you, you can get an evaluation version of
Obeo Designer (time-limited, but with no feature restriction) and follow
the included "Getting Started" guide. You can also find example modelers
at [2].
If you want to use Sirius itself (same code, but we know there are still
some glitches left from the large-scale renaming) you can get the latest
nightly from [3] and the latest version of EcoreTools [4] which is being
rewritten to use Sirius.
If you go to EclipseCon next week, we would be happy to give you a demo
and answer any questions there; just ask at the Sirius booth. There will
also be a BOF session on wednesday where we will help particpants create
their first Sirius-based modeler.
Thanks for you interest and don't hesitate if you need more details.
Pierre-Charles David
[1] http://www.obeodesigner.com/
[2] http://www.obeonetwork.com/
[3] http://download.eclipse.org/sirius/updates/nightly/0.9
[4] http://wiki.eclipse.org/index.php/Ecore_Tools
Re: Examples [message #1742026 is a reply to message #1154419] |
Hi.
at [2].
FUDForum. Page generated in 0.10775 seconds
