Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with ScrolledForm
Problem with ScrolledForm [message #115312] Thu, 11 December 2008 06:37 Go to next message
Hi all,
I want to make the scroll bars visible only when some contents in the
composite are not shown.
But the following code cannot achieve my purpose, what shall I do?
import org.eclipse.rwt.graphics.Graphics;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.ui.forms.widgets.FormToolkit;
import org.eclipse.ui.forms.widgets.ScrolledForm;
import org.eclipse.ui.part.ViewPart;
public class FormTest extends ViewPart{
public static final String ID = "net.HomePageView";
private Composite formComposite;
public void createPartControl(Composite parent) {
FormToolkit toolkit = new FormToolkit(parent.getDisplay());
ScrolledForm form = toolkit.createScrolledForm(parent);
If following line is added, scroll bars always show.
If not added, scroll bars will not show even after I click "test" button
many times.
//form.setAlwaysShowScrollBars(true);
formComposite = form.getBody();
formComposite.setLayout(new GridLayout());
formComposite.setBackground(Graphics.getColor(255,255,230));
Button btn = new Button(formComposite, SWT.NONE);
btn.setText("test");
btn.addSelectionListener(new SelectionAdapter(){
public void widgetSelected(SelectionEvent e) {
for(int i=0;i<5;i++){
Label label = new Label(formComposite , SWT.NONE);
label.setText("test label");
Composite formcomposite = label.getParent();
formcomposite.layout();
/* The scroll bars will display when add the following code,
but the size of form will be changed.
//Composite form2 = formcomposite.getParent();
//form2.pack();
public void setFocus() {}
Terry
Re: Problem with ScrolledForm [message #115733 is a reply to message #115312] Mon, 15 December 2008 06:40 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
Hi Terry,
please change your code as follow (add form.reflow( true )):
form.reflow( true );
You should make the form final. Hope that this will help.
Best,
Ivan
Re: Problem with ScrolledForm [message #116151 is a reply to message #115733] Wed, 17 December 2008 23:27 Go to previous message
Hi Ivan,
Thank you for your reply. I try as you suggest and it does take effect. But
I still have a question.
By using form.reflow( true ), the scrolling is not fluent; but by
form.setAlwaysShowScrollBars(true), the scrolling is fluent.
Terry
Ivan Furnadjiev wrote:
> Hi Terry,
> Best,
> Ivan
Previous Topic:Tooling source code?
Next Topic:RAP Session
Current Time: Sat Jul 19 12:45:49 EDT 2025
Powered by FUDForum. Page generated in 0.04282 seconds
