Home » Eclipse Projects » Eclipse 4 » E4 @Named dependency injection and OSGi services
E4 @Named dependency injection and OSGi services [message #902056] Wed, 15 August 2012 12:49 Go to next message
Hi everybody,
I am trying to do the following without luck: I am writing a bunch of
OSGi plugins that will provide services that will be used in an E4
application.
I have an interface IStorage that is implemented by different plugins,
each one providing a particular type of storage (e.g., local, remote, etc.)
Now, I would like to be able to choose the particular "type" using
@Named annotations, something like
@Inject
@Named("remote")
IStorage remoteStorage
The problem is that I cannot make it work.
In my pure OSGi plugin I've tried the following:
1) Creating a declarative service that provides the IStorage interface
and whose name is "remote".
2) Getting an Eclipse context in my plugin's activator using
EclipseContextFactory. getServiceContext(bundleContext); and putting the
"remote" implementation in it using context.set("remote", new
RemoteStorage())
They both don't work.
So the question is: is it possible, in a pure OSGi world, to use E4 DI
to provide different services implementing a given interface and
selecting them using the @Named annotation?
Fabio
P.S.: Registering a service using bundleContext.register(IStorage.class,
new RemoteStorage(), null) works perfectly when I try to @Inject
IStorage somewhere. The problem is that in this way I cannot select one
implementation when multiple ones are available.
Re: E4 @Named dependency injection and OSGi services [message #902143 is a reply to message #902056] Thu, 16 August 2012 02:30 Go to previous messageGo to next message
No - e4 DI will always pick the first one it finds. The @Named
annotation will simply make the DI container search for a key "remote"
instead of "IStorage.class.getName()"
You could invent you own annotation which searches the OSGi-Service
registry differently.
So you'd write:
@Inject
@OSGiNamed("remote")
Tom
Am 15.08.12 18:49, schrieb Fabio Mancinelli:
> Hi everybody,
> application.
> @Inject
> @Named("remote")
> RemoteStorage())
> Fabio
Re: E4 @Named dependency injection and OSGi services [message #902228 is a reply to message #902143] Thu, 16 August 2012 08:51 Go to previous messageGo to next message
@Tom: I think it would be a nice extension if OSGi service could be searched by name. Is it worth opening a bug for that feature request?
Re: E4 @Named dependency injection and OSGi services [message #902249 is a reply to message #902143] Thu, 16 August 2012 10:11 Go to previous messageGo to next message
Thanks Tom for your reply.
What you said was clear to me. It was just the I thought that the @Named
annotation, somehow, affected also the way the OSGi services were searched.
As Lars suggested maybe a feature request here makes sense because
since OSGi declarative services have a provided interface and also a
name, this perfectly fits the use case
@Inject @Named("component-name") ProvidedInterface service;
Fabio
> So you'd write:
> @Inject
> Tom
>> Hi everybody,
>> application.
>> @Inject
>> @Named("remote")
>> RemoteStorage())
>> Thanks,
>> Fabio
Re: E4 @Named dependency injection and OSGi services [message #902344 is a reply to message #902249] Fri, 17 August 2012 04:31 Go to previous messageGo to next message
Well the @Inject in e4 is meant primarily to inject dependencies which basically means decouple the interface from the implementation. While I agree there may be cases that direct implementation reference from the client of the injection is appropriate (OSGi services maybe one of them) , in general I think it should not be encouraged by the framework as DI is the highest level of implementation-hiding patterns.
The @Named does influence the way services are searched but searches for a specific named interface (service) in the context, not a specific implementation for a given interface.
Maybe one solution would be to plug in a context function and let it pick the implementation based on the context. If you are in a "remote" context the CF can select the remote variant of IService, if you are in a "local" context it should select the local one. But your client code would be just @Inject IService and the logic of the implementation switching would be a small and easy extension to the framework.
Maybe I ranted too much but I hope this helps.
Re: E4 @Named dependency injection and OSGi services [message #902360 is a reply to message #902344] Fri, 17 August 2012 06:16 Go to previous messageGo to next message
@Sopot: It feels to me that you are missing a key point here. OSGi services can be named, see here: http://www.vogella.com/articles/OSGiServices/article.html#declarativeservices
The request here is that this name can be used in the @Named tag. This would not introduce any hard implementation coupling IMHO. I think it would be consistent with the DI approach and would allow to select specific OSGi implementations based on the name similar to Context Variables.
Re: E4 @Named dependency injection and OSGi services [message #902803 is a reply to message #902228] Mon, 20 August 2012 10:01 Go to previous messageGo to next message
If we know the service is in the OSGi context then it would avoid the unnecessary search up the tree (cleaner and more efficient). I might modify it to something like:
@OSGiNamed(name="someName", tag="someTags")
This way it would be possible to differentiate multiple providers.
JD
Re: E4 @Named dependency injection and OSGi services [message #988988 is a reply to message #902803] Tue, 04 December 2012 02:49 Go to previous messageGo to next message
Are there any updates on this topic?
I am looking for the exact same functionality.
Re: E4 @Named dependency injection and OSGi services [message #1151704 is a reply to message #988988] Wed, 23 October 2013 10:41 Go to previous messageGo to next message
Lars, could you open a defect for this if you haven't already ?
Re: E4 @Named dependency injection and OSGi services [message #1151711 is a reply to message #1151704] Wed, 23 October 2013 10:49 Go to previous messageGo to next message
I think we would need a new ExtendedObjectSupplier for this, as this is a special case. It is relatively easy to create something like this in a customer implementation. See http://www.vogella.com/articles/Eclipse4OwnAnnotations/article.html
Re: E4 @Named dependency injection and OSGi services [message #1783089 is a reply to message #1151711] Wed, 07 March 2018 11:11 Go to previous messageGo to next message
For the record, does anyone know if this works as proposed by Lars
https://www.eclipse.org/forums/index.php?t=msg&th=369538&goto=902360&#msg_902360
... since "[ds] replace Equinox DS implementation with Felix SCR (DS) implementation"?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=501950
[Updated on: Wed, 07 March 2018 11:25] by Moderator
Re: E4 @Named dependency injection and OSGi services [message #1834867 is a reply to message #1783089] Thu, 19 November 2020 07:06 Go to previous message
I'm looking for this exact functionality. I found a bug which seems to be corresponding to this https://bugs.eclipse.org/bugs/show_bug.cgi?id=485270
Previous Topic:Adding 3.x ViewParts to E4XMI
Next Topic:E4 Batik CSS Parser upgrade?
Current Time: Sat Jul 19 20:15:33 EDT 2025
Powered by FUDForum. Page generated in 0.07013 seconds
