Home » Archived » Eclipse Process Manager (Stardust) » findUsers - Webservice API (findUsers - needs only the valid users)
findUsers - Webservice API [message #1149875] Tue, 22 October 2013 07:20 Go to next message
In the findUsers webservice API i need to fetch all the valid users only.
What is the input query we can give for fetching only valid users.
can you provide the sample UserQueryXto input.
Venkatesh C
Re: findUsers - Webservice API [message #1158957 is a reply to message #1149875] Mon, 28 October 2013 03:48 Go to previous messageGo to next message
Venkatesh,
Following code snippet can be used to find only valid users:
private static UsersXto findValidUsers() throws BpmFault
LOGGER.info("-- Finding Valid Users --");
final UserQueryXto user = new UserQueryXto();
UserQueryResultXto userQueryResultXto = QUERY_SERVICE.findUsers(user);
UsersXto usersXto_ret = new UsersXto();
UsersXto usersXto = userQueryResultXto.getUsers();
List<UserXto> userXto = usersXto.getUser();
Iterator<UserXto> iterator = userXto.iterator();
while(iterator.hasNext()){
UserXto userXto2 = iterator.next();
if(userXto2.getValidTo() !=null && userXto2.getValidTo().getTime() < System.currentTimeMillis()){
iterator.remove();
System.out.println("Invalid User - " + userXto2.getFirstName());
return usersXto;
Assuming you have queryService with you in your code.
At the calling method end, you can traverse the returned UsersXto object like below and fetch the required properties of the valid users:
UsersXto usersXto = findValidUsers();
for (UserXto userXto2 : userXto) {
System.out.println(userXto2.getFirstName());
[Updated on: Mon, 28 October 2013 03:49] by Moderator
Re: findUsers - Webservice API [message #1216396 is a reply to message #1158957] Thu, 28 November 2013 08:02 Go to previous message
Hi Vikash Pandey,
Thanks for the reply. Is there any other inbuilt option to filter the same?
Previous Topic:Web project doesn't run on Eclipse's Tomcat
Next Topic:Unable to deploy stardust in Jboss 5.1
Current Time: Sat Jul 19 18:31:28 EDT 2025
Powered by FUDForum. Page generated in 0.05033 seconds
