Home » Archived » BIRT » Creating printable TOC in PDF
Creating printable TOC in PDF [message #1148491] Mon, 21 October 2013 10:48 Go to next message
I have seen many of the posts to create printable TOC while rendering PDF but I was unlucky all the time as all of the posts suggested 2 steps to create TOC. So, is there any way to create printable TOC in a single step only while rendering as PDF.
Thanks in advance.
Re: Creating printable TOC in PDF [message #1148499 is a reply to message #1148491] Mon, 21 October 2013 10:55 Go to previous messageGo to next message
Actually, the TOC should include page numbers too. and I have to run the report on the linux server via API's
Re: Creating printable TOC in PDF [message #1148652 is a reply to message #1148499] Mon, 21 October 2013 12:57 Go to previous messageGo to next message
What do you mean by the posts suggesting two steps? What were these steps?
Re: Creating printable TOC in PDF [message #1149257 is a reply to message #1148652] Mon, 21 October 2013 22:12 Go to previous messageGo to next message
By 2 steps means that 1st we have to view report as web viewer and after that export it to PDF, then only toc with page number will be there. If we straight click run as pdf then no toc will be there.
I have referred to this link:
http://www.birt-exchange.org/devshare/_/designing-birt-reports/1523-simplified-printable-table-of-contents
Re: Creating printable TOC in PDF [message #1149542 is a reply to message #1149257] Tue, 22 October 2013 02:35 Go to previous messageGo to next message
I have gone across the following post:
http://www.eclipse.org/forums/index.php/t/209169/
but I found not much useful ..
Re: Creating printable TOC in PDF [message #1149661 is a reply to message #1149542] Tue, 22 October 2013 04:09 Go to previous message
Actually, the requirement on 1st page is something like this:
Topic "Business Finance" Entity Collection 1
Business Finance Bar Chart 2
Also please see the attached file
  • Attachment: test.png
    (Size: 40.14KB, Downloaded 275 times)
Previous Topic:Birt web viewer re-run report
Next Topic:How to override Page Autotext's initial value
Current Time: Sun Jul 20 07:12:31 EDT 2025
Powered by FUDForum. Page generated in 0.04324 seconds
