Home » Archived » Jubula » Jubula and GUIdancer Version 7.2 released
Jubula and GUIdancer Version 7.2 released [message #1142107] Thu, 17 October 2013 07:53 Go to next message
Hi everyone,
We've just released version 7.2 of the standalones for Jubula and GUIdancer.
The main new feature is that you can now connect your project to an ALM repository to:
- see and edit tasks from the repository in the ITE
- create tasks from test result reports
- automatically add the test results to tasks in the ALM tool when a test runs.
Have a look at the blog entry for some details and screenshots, read the release notes and the documentation for full details. The installation manual contains step by step details on how to migrate.
You can download the new release from http://testing.bredex.de.
Have fun!
Alex and the team
Re: Jubula and GUIdancer Version 7.2 released [message #1143302 is a reply to message #1142107] Fri, 18 October 2013 01:21 Go to previous messageGo to next message
Sorry for the multiple postings guys - there was a problem with the forum!
Re: Jubula and GUIdancer Version 7.2 released [message #1148818 is a reply to message #1142107] Mon, 21 October 2013 15:21 Go to previous messageGo to next message
Upgraded from Jubula version 7.1 to version 7.2 and now get error message when I try to open or create a test ("Test", "New"):
"Database Connection failed. Please enter a valid username and password and try again." Connection dropdown shows "Default Embedded (H2.
_________________________________TRY JUBULA STANDALONE
2013-10-21 14:34:37.150 [Worker-3] ERROR o.e.j.c.core.persistence.Persistor - no or wrong username or password
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:h2:~/.jubula/database/embedded;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE
Error Code: 0
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:517) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.jubula.client.core.persistence.Persistor.buildSessionFactoryWithLoginData(Persistor.java:286) [org.eclipse.jubula.client.core_2.2.0.201310100933.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.<init>(Persistor.java:157) [org.eclipse.jubula.client.core_2.2.0.201310100933.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.instance(Persistor.java:605) [org.eclipse.jubula.client.core_2.2.0.201310100933.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.access$4(Persistor.java:600) [org.eclipse.jubula.client.core_2.2.0.201310100933.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor$2.run(Persistor.java:191) [org.eclipse.jubula.client.core_2.2.0.201310100933.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53) [org.eclipse.core.jobs_3.5.300.v20120912-155018.jar:na]
Caused by: org.eclipse.persistence.exceptions.DatabaseException:
Error Code: 0
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:319) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:584) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:206) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:488) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 10 common frames omitted
Caused by: java.sql.SQLException: No suitable driver found for jdbc:h2:~/.jubula/database/embedded;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE
at java.sql.DriverManager.getConnection(DriverManager.java:602) ~[na:1.6.0_45]
at java.sql.DriverManager.getConnection(DriverManager.java:154) ~[na:1.6.0_45]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 14 common frames omitted
2013-10-21 14:34:52.549 [Worker-2] ERROR o.e.j.c.core.persistence.Persistor - no or wrong username or password
Error Code: 0
Error Code: 0
Re: Jubula and GUIdancer Version 7.2 released [message #1149362 is a reply to message #1148818] Mon, 21 October 2013 23:55 Go to previous messageGo to next message
Note - above was from .jubula client.log on CentOS6.3 Linux machine.
Re: Jubula and GUIdancer Version 7.2 released [message #1149514 is a reply to message #1149362] Tue, 22 October 2013 02:15 Go to previous messageGo to next message
Hi, it sounds like you didn't follow the migration information from the installation manual. Since we updated database drivers, the database does have to be changed - full instructions are in the installation manual which can be downloaded from here:
http://testing.bredex.de/documentation-download.html
It's also installed in the "documentation" folder of the standalone installation.
I'd recommend following all the steps in the migration guide to ensure that the update to the new version runs without a problem.
Hope that helps,
Alex
Re: Jubula and GUIdancer Version 7.2 released [message #1150500 is a reply to message #1149514] Tue, 22 October 2013 16:34 Go to previous messageGo to next message
Thank you Alex. I missed that step.
Re: Jubula and GUIdancer Version 7.2 released [message #1153411 is a reply to message #1142107] Thu, 24 October 2013 11:42 Go to previous messageGo to next message
I notice that the most recent Kepler Eclipse plugin still uses the old database. I discovered this when switching between the standalone version of Jubula and Kepler eclipse with the Jubula plugins.
Will there be an updated set of Jubula plugins?
Bernard
Re: Jubula and GUIdancer Version 7.2 released [message #1154278 is a reply to message #1153411] Fri, 25 October 2013 01:15 Go to previous message
Hi Bernard,
Normally, we sync up the releases with the major milestone (i.e. Luna), but I'll check internally.
Alex
Previous Topic:Mulit-User-Tests with Jubula
Next Topic:RCP Application is NOT recognized with 2.0.1
Current Time: Sat Jul 19 23:36:14 EDT 2025
Powered by FUDForum. Page generated in 0.06004 seconds
