Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » teneo:circular loop on DB2 error
teneo:circular loop on DB2 error [message #114707] Thu, 13 March 2008 17:03 Go to next message
Hi Martin,
I'm using teneo with DB2 and on certain section of my meta-data during my
database initialize returns me an error which is essentially a loop -
table a is connect to table b to table c to table a.
DB21034E The command was processed as an SQL statement because it was not
a valid Command Line Processor command. During SQL processing it
returned: SQL20254N FOREIGN KEY "NVGTNLMN_LYTLMNTR" is not valid since it
would cause
table "DB2INST1.NAVIGATIONELEMENT" to be delete-connected to itself
through a cycle that contains a delete rule of either RESTRICT or SET
NULL. Reason code = "1". SQLSTATE=42915
DB2 was able to pinpoint where this happens and am able to replicate it on
a small sample.
If I make a substitution change in one of the element (for loop:Text and
copy Text into Preference), the problem goes away.
eg
<xs:complexType name="Preference">
<xs:sequence>
<xs:element name="value" type="loop:Text" minOccurs="0"
maxOccurs="unbounded"/> <--- use actual Text here
</xs:sequence>
<xs:attribute name="name" type="xs:string" use="required"/>
</xs:complexType>
I'm not sure if this is a bug or not. Perhaps changing my settings on how
I generate jdo might be a workaround for this problem. Currently I am using
FETCH_CONTAINMENT_EAGERLY = "true"
JOIN_COLUMN_NAMING_STRATEGY = "simple"
MAXIMUM_SQL_NAME_LENGTH = "18"
INHERITANCE_MAPPING = JOINED/SINGLE_TABLE (tried both)
Is there any other settings that you think I can try? I sent you my simple
sample just in case you want to try it. Thanks.
Julia
Re: teneo:circular loop on DB2 error [message #114816 is a reply to message #114707] Fri, 14 March 2008 09:39 Go to previous messageGo to next message
Hi Julia,
I have been searching the internet for this issue. I have tested with mysql and it works fine.
I don't run db2 so it is difficult for me to reproduce it.
You sent me a smaller test case directly, what db2 error message do you get on that one? Then I know
which table/foreign key to look for.
gr. Martin
Julia wrote:
> Hi Martin,
> my database initialize returns me an error which is essentially a loop -
> not a valid Command Line Processor command. During SQL processing it
> it would cause
> on a small sample.
> eg
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> how I generate jdo might be a workaround for this problem. Currently I
> am using
> simple sample just in case you want to try it. Thanks.
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo:circular loop on DB2 error [message #114877 is a reply to message #114707] Mon, 17 March 2008 01:09 Go to previous message
Hi Julia,
I think the sql is wrong (because the mapping is wrong) in case of a contained many-to-one. Normally
for a many-to-one teneo will set the
fk on the many side. However in this case this results in a foreign key cascade which goes the wrong
way. Currently the reference is from the layoutelement to the text object. Which means that with
cascade delete that when the text gets deleted the layoutelement is also deleted. The required
behavior is the opposite: when the layoutelement is deleted then also its children should be
deleted. In a way a contained many-to-one should be treated as a one-to-one.
As a solution: Teneo should not create an explicit fk constraint but let jpox handle it (through the
dependent element).
Can you enter a bugzilla for this?
For now the only solution I can think of is remove the explicit foreign-key elements in the text
fields in the package.jdo.
gr. Martin
Julia wrote:
> Hi Martin,
> it would cause
> on a small sample.
> eg
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> am using
> Julia
The Netherlands
Re: teneo:circular loop on DB2 error [message #615887 is a reply to message #114707] Fri, 14 March 2008 09:39 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> it would cause
> on a small sample.
> eg
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> am using
> Julia
The Netherlands
Re: teneo:circular loop on DB2 error [message #615894 is a reply to message #114707] Mon, 17 March 2008 01:09 Go to previous message
Hi Julia,
dependent element).
gr. Martin
Julia wrote:
> Hi Martin,
> it would cause
> on a small sample.
> eg
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> am using
> Julia
The Netherlands
Previous Topic:Unnecessary resetting of object references
Next Topic:[Teneo] Hibernate Library Editor Turorial - can't load URI
Current Time: Sun Jul 20 02:29:06 EDT 2025
Powered by FUDForum. Page generated in 0.05341 seconds
