Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Disable the schemaExport on the hibernate
Disable the schemaExport on the hibernate [message #114554] Wed, 12 March 2008 14:05 Go to next message
I'm trying to disable the schema export each time I connect to the
database. It takes a long time to connect and if it is a different
schema it tries to update and that is the wrong solution for production
application.
Here is what I tried:
I create properties for hibernate and assign -
props.setProperty(Environment.HBM2DDL_AUTO, "validate");
dataStore.setHibernateProperties(props);
Please note that I need to use the properties because my application
dynamically changes the database connection with the user input. So I
do not have a configuration file and I manage it via properties.
This should not export the schema but only validate it. However, it
does not have any impact on hibernate. Hibernate always rebuild the schema.
Any ideas how to cause Hibernate not to export the schema.
Tunning it OFF is the best option I'm looking for. Validate is my second.
Yigal
Re: Disable the schemaExport on the hibernate [message #114567 is a reply to message #114554] Wed, 12 March 2008 14:23 Go to previous messageGo to next message
Hi Yigal,
There is also a specific Teneo option: PersistenceOptions.UPDATE_SCHEMA, this should be set to
false. This property should be passed to the setPersistenceProperties method.
I can see that the teneo option is confusing/contradicting related to the same kind of option in
Hibernate. Can you enter a bugzilla for this? Then I can think of a way to make this more intuitive
or at least also listen to the hibernate property.
gr. Martin
> application.
> schema.
> Thanks
> Yigal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Disable the schemaExport on the hibernate [message #114778 is a reply to message #114567] Fri, 14 March 2008 09:10 Go to previous message
Hi Martin,
The TENEO option worked well.
Yes it is confusing that the TENEO overrides the hibernate.
I'll enter a request to clarify it.
Yigal
Martin Taal wrote:
> Hi Yigal,
> this should be set to false. This property should be passed to the
> the same kind of option in Hibernate. Can you enter a bugzilla for this?
> Then I can think of a way to make this more intuitive or at least also
> gr. Martin
>> production application.
>> schema.
>> second.
>> Thanks
>> Yigal
Re: Disable the schemaExport on the hibernate [message #615853 is a reply to message #114554] Wed, 12 March 2008 14:23 Go to previous message
Hi Yigal,
gr. Martin
> application.
> schema.
> Thanks
> Yigal
The Netherlands
Re: Disable the schemaExport on the hibernate [message #615881 is a reply to message #114567] Fri, 14 March 2008 09:10 Go to previous message
Hi Martin,
Yigal
Martin Taal wrote:
> Hi Yigal,
> gr. Martin
>> schema.
>> second.
>> Thanks
>> Yigal
Previous Topic:[CDO 0.8M5] Persisting Enums troubles
Next Topic:How to get the TENEO source code
Current Time: Sat Jul 19 10:03:19 EDT 2025
Powered by FUDForum. Page generated in 0.07394 seconds
