Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: Problem with using QualifyingEntityNameStrategy
Teneo: Problem with using QualifyingEntityNameStrategy [message #114527] Wed, 12 March 2008 10:59 Go to next message
Hi Martin,
Thanks for your insight on same name case. We tried using differenct
database schema and QualifyingEntityNameStrategy.
QualifyingEntityNameStrategy was just easier to work with.
I'm using 2 different schemas that have similiar elements in both that I
added prefix to. I did hit one section of my database initialization that
both schemas would tried to validate a table "PageParamsImpl_Pageheader"
that both need but should have different columns names depending on the
schema. Not sure how to work around this. I sent you (springsite email)
the ecore and jdo files of the short version that I was able to recreate
on.
Any insight would be appreciated. Thanks.
Julia
Re: Teneo: Problem with using QualifyingEntityNameStrategy [message #114541 is a reply to message #114527] Wed, 12 March 2008 13:49 Go to previous messageGo to next message
Hi Julia,
Hmm yes apparently join table names are not prefixed. You can try the JoinTable annotation to set a
specific join table name. Can you also enter a bugzilla for this (join table names should use
entityname and be prefixed).
Sorry but I am at the moment very busy with different things (eclipsecon and other things) so I am
not able to look at your test case before eclipsecon.
gr. Martin
Julia wrote:
> Hi Martin,
> that both schemas would tried to validate a table
> "PageParamsImpl_Pageheader" that both need but should have different
> columns names depending on the schema. Not sure how to work around this.
> I sent you (springsite email) the ecore and jdo files of the short
> version that I was able to recreate on.
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: Problem with using QualifyingEntityNameStrategy [message #114681 is a reply to message #114541] Thu, 13 March 2008 15:34 Go to previous message
Hi Martin,
Thanks. I reported a bug 222647 in bugizilla. In the meantime I will try
out the jointable annotation.
Julia
Re: Teneo: Problem with using QualifyingEntityNameStrategy [message #615849 is a reply to message #114527] Wed, 12 March 2008 13:49 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> Julia
The Netherlands
Re: Teneo: Problem with using QualifyingEntityNameStrategy [message #615870 is a reply to message #114541] Thu, 13 March 2008 15:34 Go to previous message
Hi Martin,
Julia
Previous Topic:Teneo: support for Informix
Next Topic:[Teneo] Is there a way to separate notation that define column length?
Current Time: Sat Jul 19 09:05:10 EDT 2025
Powered by FUDForum. Page generated in 0.10113 seconds
