[CDO] Offline update of CDO objects [message #1139013] |
Tue, 15 October 2013 09:27  |
We are building a crud webservice over a CDO repository. However we intend to make this service stateless. The way updates should work is
1. User reads a CDO object (using a CDOSession that would be closed after the read)
2. User comminicates back the edited attributes.
3. We push the changes back to CDO repository using a new CDOSession.
The question here for step 3 is, can we push changes back to the repository without getting an instance of CDO Object from the repository.
I ask this for efficiency reasons. The fall back obviously would open a transaction , read back the CDO object, apply the changes and commit the transaction.
Can the read back be avoided ? Can we recreate a CDOObject and commit it via a transaction.
- Ashish
Re: [CDO] Offline update of CDO objects [message #1139027 is a reply to message #1139013] |
Tue, 15 October 2013 09:40   |
Hi, Ashish,
What is your plan to avoid dirty updates? It is entirely possible that
between the first session that provided the object to the user and the
second that accepted the user's changes to that object, some other user
has also committed changes to that same object.
The normal usage of CDO repositories is definitely session-oriented and
transactional, to prevent issues such as dirty updates (as well as all
of the benefits of live synchronization etc.).
Christian
> after the read)
> repository.
> the transaction.
> Regards,
> - Ashish
Re: [CDO] Offline update of CDO objects [message #1143427 is a reply to message #1143350] |
Fri, 18 October 2013 03:13  |
Am 18.10.2013 08:03, schrieb Ashish Shinde:
> Hi Eike,
> Thank you for the reply. Answers to your questions inline.
> Regards,
> -Ashish
>> Am 16.10.2013 09:02, schrieb Ashish Shinde:
>>> Hi Eike,
>>> Sorry about not being clear enough. I meant a CDOTransaction that I would open after opening a new CDOSession for
>>> the commit request. Let me try and explain the update flow as I am thinking about it
>>> step 1. rest read request -> open session -> read object -> convert to json
>> So that means:
>> rest read request -> open session -> *open read-only view* -> read object -> convert to json
>> Do you keep that session and view open then?
> No we plan to close the session and view immediately after reading the object. Unless in line with what you mentioned,
> session and or view and or transactions can be pooled across users. I guess sessions are tied to a user so this might
> not work out.
They're only tied to user *names* if you use CDO authentication against the repo. If you don't use any security features
in CDO there's no reason to not reuse a single session across all requests. And then you would certainly want to also
keep the read-only view open, which caches the EObject graph.
Cheers
/Eike
http://www.esc-net.de
> Let me try and explain why the reluctance to keep sessions open.
> Our system will support 50-100 users using the rest webservice through a web interface. Each user would be mostly
> editing model instances. The edit operation invovles doing a bit of reasearch and a single edit could span a day or
> so. Therefore after a user reads an object he could take a day or so to commit the updates. He might have read a few
> more referenced object or maybe unrelated objects too.
> Also a user web session might expire while he was doing edits. We want to save his partial edits temporarily in the
> webinterface backend (out of the rest webservice) so that on next web interface login he could start from his partial
> edits and later on commit.
> Of course if we can keep session for a user perpetually open that might work as well, however the question is how much
> memory is consumed by open sessions. Is it proportional to the number of objects read from a view opened from the
> session or is it constant. If it is constant then can we keep perpetual session open per user. Will there be memory
> leaks etc. Again we could periodically close session too to circumvent build up.
> I hope I have clarified the situation.
>>> step 2. the user edits the object as json and sends back edited json
>> What kind of information does this update request" contain? Deltas? the new values of changed features? The values of
>> all features of the changed objects? What about additions or deletions?
>>> step 3. (this is where I need help) recreate a dirty CDO Object from edited json and commit.
>> Ideally with something like:
>> CDOTransaction tx = session.openTransaction();
>> tx.importChanges(inputStream);
>> Where inputStream delivers the result of a former tx.exportChanges(outputStream).
>> That seems difficult with your JSON infrastructure, so you'll need to iterate over your change infos and do something
>> like:
>> for (ChangeInfo changeInfo : changeInfos)
>> CDOObject object = tx.getObject(changeInfo.getID());
>> if (object.cdoRevision().getVersion() != changeInfo.getVersion())
>> throw new ConcurrentModificationException();
>> applyChangeInfo(changeInfo, object);
>> tx.commit();
>> tx.close();
>>> Ofcourse if the base revision from the read in step 1 is not the same as the head revision we need to flag this as a
>>> conflict and the user would resolve it after seeing the latest version and his version.
>> See my code above.
FUDForum. Page generated in 0.04301 seconds
