Home » Newcomers » Newcomers » Where is the PluginImportWizard?(plug in)
Where is the PluginImportWizard? [message #1132872] Fri, 11 October 2013 08:55 Go to next message
In the attached sample of swt Helloworld, I learn the sample step by step, but at the step of import, I get the warning, The command didd not complete successfully.
The command did not complete successfully.
unknown wizard: org.eclipse.pde.ui.PluginImportWizard
I use ide for java. what can I do with it?
[Updated on: Fri, 11 October 2013 10:18] by Moderator
Re: Where is the PluginImportWizard? [message #1132889 is a reply to message #1132872] Fri, 11 October 2013 09:10 Go to previous messageGo to next message
in the import box, there is no plug in development term. where is it?
Re: Where is the PluginImportWizard? [message #1132978 is a reply to message #1132889] Fri, 11 October 2013 10:19 Go to previous messageGo to next message
and odd enough, in the new file wizard, instead of plug-in development, mine have a maven item.
what's different from them?
Re: Where is the PluginImportWizard? [message #1133019 is a reply to message #1132889] Fri, 11 October 2013 10:51 Go to previous messageGo to next message
You have to install the PDE if you want it. Use Help -> Install New
Software and pick the Kepler repo Look in General Purpose Tools ->
Eclipse Plug-in Development Environment.
Re: Where is the PluginImportWizard? [message #1133093 is a reply to message #1133019] Fri, 11 October 2013 11:56 Go to previous messageGo to next message
oh, Let me have a try.
Re: Where is the PluginImportWizard? [message #1133100 is a reply to message #1133093] Fri, 11 October 2013 12:05 Go to previous messageGo to next message
Help -> Install New Software and pick the Kepler repo Look in General Purpose Tools ->
There is no Kepler repo? so do not in purpose item,
where can find it?
Re: Where is the PluginImportWizard? [message #1133113 is a reply to message #1133100] Fri, 11 October 2013 12:14 Go to previous messageGo to next message
type or select a site
beneth it there is an availiable software sites. enter it, I find many and pick a kepler and javascript etc.
is that?
Re: Where is the PluginImportWizard? [message #1133130 is a reply to message #1133113] Fri, 11 October 2013 12:29 Go to previous message
It is that. it takes me about 10 minutes to download and back to file import, I find the plug in deveopment item.
Thanks.
Previous Topic:Help with OpenKM
Next Topic:Killing threads in debugger
Current Time: Sat Jul 19 23:49:01 EDT 2025
Powered by FUDForum. Page generated in 0.29852 seconds
