[jet] Controlling the template path [message #1132971] |
Fri, 11 October 2013 10:14  |
My custom JET templates have suddenly started to fail with 7 "The method
hasStaticFeatures() is undefined for the type GenClass" errors.
This is no doubt because I moved the tip of my EMF GIT to the latest
master, picking up
commit 197526f3fa90e8fad36fddd5b0ec4db26369ff11
[418541] Properly handle static features for dynamic feature delegation
However org.eclipse.emf.ecore.codegen is a closed project in my
workspace, so I am surprised that it is being used at all.
My .jetproperties are
<jet-settings>
<template-container>templates;@platform:/resource/org.eclipse.emf.codegen.ecore/templates</template-container>
<source-container>jet-gen</source-container>
</jet-settings>
but changing /resource/ to /plugin/ makes no difference.
Since I cannot find any documentation on the significance of the "@"
that I copied from MDT/UML2 maybe my usage is inappropriate, but it
would seem to me that neither setting should be able to use a closed
project.
Is my thinking wrong or is it a Bugzilla?
Ed Willink
Re: [jet] Controlling the template path [message #1132999 is a reply to message #1132971] |
Fri, 11 October 2013 10:37   |
Ed,
Comments below.
On 11/10/2013 4:14 PM, Ed Willink wrote:
> Hi
> method hasStaticFeatures() is undefined for the type GenClass" errors.
> master, picking up
Yes, and that commit clearly includes the new method:
http://git.eclipse.org/c/emf/org.eclipse.emf.git/commit/?id=197526f3fa90e8fad36fddd5b0ec4db26369ff11
> <jet-settings>
> </jet-settings>
> project.
Much of the JET infrastructure is low level and operates without much
knowledge of the workspace. Even if there is a bug, "fixes" might be
considered a bug by someone relying on current behavior. I'm surprised
though if platform:/plugin makes no difference, and I'm not sure you
should expect platform:/resource to look anywhere other than the
workspace, so a fix is most likely one that just makes it fail until you
have such a workspace project open...
In any case, if you want me to have a look, including everything I need
in a self contained zip file...
> Regards
> Ed Willink
Re: [jet] Controlling the template path [message #1133099 is a reply to message #1132999] |
Fri, 11 October 2013 12:02   |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=419239 raised.
..../plugin/... works, provided you restart Eclipse after making the
change; it seems the Nature/Builder has a change insensitive cache.
Ed Willink
On 11/10/2013 15:37, Ed Merks wrote:
> Ed,
> Comments below.
>> Hi
>> master, picking up
>> <?xml version="1.0" encoding="UTF-8"?>
>> <jet-settings>
>> </jet-settings>
>> project.
> you have such a workspace project open...
> need in a self contained zip file...
>> Regards
>> Ed Willink
FUDForum. Page generated in 0.03461 seconds
