Home » Eclipse Projects » Remote Application Platform (RAP) » Equinox + Jetty + Browser Widget - Problem
Equinox + Jetty + Browser Widget - Problem [message #112855] Wed, 19 November 2008 23:40 Go to next message
------=_NextPart_000_007C_01C94B0D.27A4CE60
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=original
When I define the following in plugin.xml my Application fails.
<extension point="org.eclipse.equinox.http.registry.resources">
<resource alias="/" base-name="/WebContent" />
</extension>
However if I comment above entry, application works fine.
This might be due to Browser widget.
If you had faced this problem and have an workaround... please share.
Attached is the entire code base to simulate the problem.
Just import the project and then run as RAP application and use the
following url in a browser
http://127.0.0.1/rap?startup=test
=> Click on Test => TestCmd => an embedded browser will show up with an
error.
Then go to plugins.xml and comment the following entry
</extension>
Then relaunch tha RAP application and test scenario. Now you can see "This
is a Test" in the embedded browser.
I have already raised this a defect.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244642
But now I am looking for a workaround as RAP team is focusing on other
important aspects... i guess.
Best Regards,
Walter G. Prabhakar.
Content-Type: application/x-zip-compressed;
name="BrowserWidgetDefect.zip"
filename="BrowserWidgetDefect.zip"
UEsDBBQACAAIAIlMFDkAAAAAAAAAAAAAAAAWAAAAY29tLm15LnRlc3QvLmNs YXNzcGF0aJWQwUoD
MRCGzxZ8hyXgsbPuzcOuRaQWC22lXXuVNBm2Y7OTOEnEvr2tWBQPBW/zD998 DH89+uhd8Y4SyXOj
KrhWBbLxlrhr1HP7MLxRo9vLQW2cjjHotD2Ei5+EnGRf7Ihto4xnVRyXjfLS ARpHISK82gROZzbb
gxOmy/HL/WLe3j3Ox8vyL0ecUFg7sLjJHWT6vkSBVdJstdj1rN0HLBerCV3N iKnP/bCCSpX/fixY
BOMFQfAtk6B9crkjjudUUcxJdRzPkD6nkNMJ3hB/wXX5u8hPUEsHCHJcDdLU AAAAfgEAAFBLAwQU
AAgACACJTBQ5AAAAAAAAAAAAAAAAFAAAAGNvbS5teS50ZXN0Ly5wcm9qZWN0 vZPBTgMhEIbPmvgO
zd4FvfVAt7FtvGmaVB8AYdzSwECAbezbC8hqNpsmPZje5v+Zn28IwJZfRs+O 4IOyuGgeyUMzAxRW
KuwWzfvb8/28WbZ3t8x5ewARNxCEVy6m7uTeMOQGWmENMScSIURGi5OXkmsA Y8voUGW37hOKoCP1
0Sstdw5EVlWuU5SjLE6lWd8REFq5AOQgIxHWp4IfeQmA/xshJbjv+swOVdOx weiEchHXSSAvHNVn
OvLqutid2IPhV4Zyp0i0VodcPSHXp6DCv8xQneHaEz72Hmr3j5hMs9V9p/C1 LGZ6aToXGD0RvCxz
9shT5lDniX/f8/iXfANQSwcICL47i/4AAABkAwAAUEsDBBQACAAIAIlMFDkA AAAAAAAAAAAAAAAc
AAAAY29tLm15LnRlc3QvYnVpbGQucHJvcGVydGllcyvOLy1KTtXTU7BVKC5K 1uflyi8tKSgtAQsk
ZeYBBYCkXmZeck5pSmoxULAgpzQdKFKRm6MTw8ulgAp8XUMcdT393PSxyOlh EStKTcOmNDw1yTk/
ryQ1rwSbbGZeSmqFXkYJVheUZKTmphpi1Zacn1cM9A8AUEsHCGqMIWh0AAAA 8gAAAFBLAwQUAAgA
CACJTBQ5AAAAAAAAAAAAAAAAFgAAAGNvbS5teS50ZXN0L2luZGV4Lmh0bWzz zEtJrdDLKMnNUQhI
TE9V0FXwyU9MSU3RAwIF9/z8FF4uAFBLBwhacoaNIwAAACMAAABQSwMEFAAI AAgAiUwUOQAAAAAA
AAAAAAAAABYAAABjb20ubXkudGVzdC9wbHVnaW4ueG1spVXBjtMwEL0j8Q+R 7+uycEGo2QoVIXpB
CO3C2XGG1Mixje2Ulq9nEsfEcZtFVX2o4pnnN+95bHe9ObayOIB1QquS3NNX pADFdS1UU5Knx493
b8nm4eWL9Qa4FMbBhH1DX4eUkV0jFH4VRbGGowfVA4ZpGEYL5UuibUNHFmqZ oZ2goLw9DWnyEBes
p2DCgYNL5lxJPDhP3xsjBWceC5E5StQlaU8DaCK6z0CGWdaCBxvokuKradHo aPXP0nUW4VcnlD7S
vfeGWmiEQ2L8cLqzHFxSM8bmGpkUDO2uMukVc3CnUD2mvkO11QrV+AyU+Ink C26uMIT9Mth8A9yL
w8xAEp7rCDq/TGmy3NJlVNLSpFLatCR8Y9fQ5EHA79RdP1+WvWUeGm1P3xB1 QTfXLf3JDoxb9sPT
lpk/z60I+xUBWRI76bVllUSIt91sA3qNtztHsS1TdWqej1rmUmpw3Arjh4cg tKaIqosPU3K5kZE3
v5lhB3LKzxhN7cbVic4gPevTCNv9v24i7RF/tm19UVjMpVpC5dt3f48sEg9y Qj6Glk/fqOdTwOW3
KyjbnVtL5I8lbpffgupS7f28f52sqDo/J8AhdXi9n77uUB1C3+V0TKiBc6KM rHOmZ42eQSWrQIY+
zoiLpTN0dYUiHKY+Tym9mHf+1F9i07n9mYj5eYrB3nbStHxvL3UPX8X4x/wX UEsHCMDHkvcNAgAA
5gcAAFBLAwQUAAgACACJTBQ5AAAAAAAAAAAAAAAAIAAAAGNvbS5teS50ZXN0 L01FVEEtSU5GL01B
TklGRVNULk1GbZBPT4QwEMXvfIqGs0xg9WAge9CbBwzRxHupIztaWuwfsvDp LVths6uHOTTvvd+8
Ts0VfaB12RsaS1qVbAd58ujVu8Ss/hXP2qo88x5LhnPNh5k10ncZqVV7nfpW SxLRI3QP/QQuYCpL
qpPoAmnvjMc1sOELyM/LH4SjkTttSraEYXsnL/jtyWAWjSXTpgMUkgaLYPgA nqo2MsZI3qcFBHZ6
k1x4F4zSRzg4N4DBjqwz0z/RHIr8FF7+Qm0Y4f/YbuEeivSqfFCa5RRTySSf p+SpH7RxWcPFF+9C
808+8iNYNGM4S7WxdnAX217op57XpuQHUEsHCBnGmZXzAAAAwQEAAFBLAwQU AAgACACJTBQ5AAAA
AAAAAAAAAAAAIQAAAGNvbS5teS50ZXN0L1dlYkNvbnRlbnQvaW5kZXguaHRt bFOwySjJzbFTsEnK
T6m080stV3BLzCtJLC7JTFbwzEtJrdADySsEJKanKugq+OQnpqSm6AGBgnt+ foqNPliXjT7YDF4u
AFBLBwjgF+DdRQAAAE0AAABQSwMEFAAIAAgAiUwUOQAAAAAAAAAAAAAAACMA AABjb20ubXkudGVz
dC9pY29ucy9hbHRfd2luZG93XzE2LmdpZgF9AoL9R0lGODlhEAAQAOYAAIuB GtbXmH6VTcropzFX
ClSXMePtudnzq83omvPzueXvqubhleHrpqejVs3GhpmdWIh8Fe36u9Xho6W0 c6LMZ5yjU42CJaGr
ZOj8h/Pzy6y3dQQMAKWzfKSybau6fa64mp6mXZKHJMLdoN/kjae0hrrMm4V3 C4NzBsbmjr3EprfF
eaqxaPX10FtaCaavd7G9nJiQQratZ5uhTK7AiUpzO0lpGKLwhXdmAtDund/h lcLmh8vljLTDiLrN
g6OvaMfXmod5D+f/f8rTtf//456ubuTyr67JfbbaeNLmqNHtpdboqtnip9zm qdjqpNvqq7rpcZGH
PZ+aPa/AkqidY7K6hsTfg6a4fNzFgY6KVr7SiJCOQ5XAZ4akYdvmsp++ZGdZ AkVkMre/rkZ8JFZn
L8DAdtTdf8vSqNHdp6C1Y8bDlK68b7izXbrDg///ydPnm4mNZF9+MdXng9jh hLasc8vigOD0tbXC
g+LdrcfNqP7/kbrEiL+0ebrBvqmtZcHak7TEbyH5BAAAAAAALAAAAAAQABAA AAfagH+Cg4SFggE5
I3JlcXRVOwhuTU5nggsjGEFPFBRHOig4BwdKlhhoYGI1AmoqPX4IB0iCV3k0 GxsNMX0rGnZ+SQOC
ZF4FG1hTDyAXHRo8IsF/CTYEWg4PyRc+Ex4lIoInJzcmQCbjQBDoFiGCW3At aw0yFfPKLlR6giEA
XxD6AP8WLECBEeWQBwIC6kzoMIEDiQ98hEgQNOdOEgJESlhx+CEMHgmV/mQY wmYMHC4zpLxIYYZJ
kYl/WDh40yaLACM/zixRECFCF0Fp9mRIwICBgqMKDCgNaaipoEAAO1BLBwg4 m2tfggIAAH0CAABQ
SwMEFAAIAAgAiUwUOQAAAAAAAAAAAAAAACMAAABjb20ubXkudGVzdC9pY29u cy9hbHRfd2luZG93
XzMyLmdpZgGoBFf7R0lGODlhIAAgAOYAANb0qcfWp8rSucbUmOz6tWBdE7TK dtPmitPaya2xdeTt
l7O6fMPJh+bxsdv2s2+TTOv4uvD8vKWnbhQaFrvGirXAhNzoj8rol42FIqep VpCIKfP+xLzJlLbD
isLLqpeSO97rrLb8k8vbi/r8u5SNM+PurL67fLnCgamtcbK6d9fdi7S+f77J obfEkpuXRaGdT83l
pOP6tNfznLnFlrjlf/L9y+P6rYyCGL3JjsHMlWR8Q5O2YcTlhej1s+vvob3L navUdMHijczpjun0
uaO5ZrjbebvGm8jjgqGfbOH1qtzhpdrfnfb7ttzmndPcutHrq+PssrfWheH0 o+z9sNHvk4GKTsnW
f/DwqZmyWH57HMbOsNXdpn+gU9TpppmXZf79xeb3t+L3t87woT04Da7Bba+0 ca+2eM/msO77w///
yZaeWNbtmICWTtPkppzHZMTpiuDckqDcbMr/ltD4jYyVOJOQLLzOeqK/dLO6 brGtbq7Jg7DBaPb0
t/jzvuPomrTEbyH5BAAAAAAALAAAAAAgACAAAAf/gH+Cg4SFhoeFV1c+PgqO FhYHkpMHVGsyUplJ
NgSdERAQgouNCpCSR6g8qjxCVFQysACbMTEEEGCCjI+nR0VFNMDAPG8XxWsA AA60MWC4f42RB1Z2
BgZAQL7XQFFB3UEXYsgO42FhuaUHdmREOztubjtcOwZ2DAwD+MXh4g7mf36R RJDhokPHgwc62OAx
Ya/hvQEBLsCAkayfIDiRihDRMaFjATUmTCxYsOLECQYUGOSAOIAiuYsqRBjY wbFjFQkoEiQwM7Lk
CQo4VgaA8WScA0EqVFj5E6+jDi9IcOrkuaJkB6BCXR79Y6WaARoPxlSBGlUq T5IVKlzlkCNAgCfJ
/wQdiHKHSJwxWVBI2Ls3pxmqK9RihfgWgKA1QniAHUPEhF6+fgGrXfvDLYwu h4W8kVMgiwETZVCI
Fr0zBcnAgjlwsIz5z43XGDpjmE0bg4bbt0noJvGhtwsXL15kyDwnxBgsDFKU Wb78r+mqqNeuFhCg
jaDbdWJj+LB7d+/vH37/Di48Q57hf0SIEELjOIMTKeLLP101bYcOLYywCCBg i3XXsHWmwWy4Fdgd
b74BFxx6UsAyxRh0iECBSdDVl9ZkLczAggdaCIDAFiAIkokMTDxQQBAomXSh fffhpyGHHjqxRIh/
TLHGCUjcMcYeAeBAAQUtBpmhfh54IICHINIowf9NF6TBRQEXDICDjy22kOEM RBoZoxIg0GiCFFMA
YMODGTwxgGocWDkDllkeiQACS0BRQgmCjEDAFEkAMIINjJ0xQA5ocvADCxt2 6CECXDbQAJ1/MNHJ
FDYAsEAUH50RwAA/ZLqhlm/CCcUQPShap6MENODFAF/EwEYVHTjhlltuvulE E5+CMkQDdY4wQg9V
DBCBDTZEoAcXWJwQgBPIIuCEEkqUMAQEEUQLwRC5MiHBABt0QkASXcQAAAwH NCGuHyU00AO00W6w
ARqh/PEFH3ks8QUTpJYAQg+dgNHDvucSEG0E6m5QQw1oCNLHCUqkoesI9JaA r7b+/gtwwANXjMgF
xRgbEggAO1BLBwjX37uarQQAAKgEAABQSwMEFAAIAAgAiUwUOQAAAAAAAAAA AAAAABkAAABjb20u
bXkudGVzdC9yZWYvdGVzdC5odG1ss8koyc2x4+WyScpPqQTSCgohGZnFCkCk EJJaXKIQkJiequCT
n5iSmqKQmaeQqJBUlF9enFqkUJ6Zkp5aoqcA1KoP1WujDzUMAFBLBwg9DWTN SQAAAFUAAABQSwME
FAAIAAgAiUwUOQAAAAAAAAAAAAAAACYAAABjb20ubXkudGVzdC9zcmMvZGlh bG9nL1Rlc3REaWFs
b2cuamF2YZ1W3W/iOBB/plL/hxEvTfaQ0b4uvUqF0l1uaalKenval5WbDOCt G0e2U1rt9X+/ceyE
0IIWnfgaZ37zPZ6h4OkDXyJkgku1HBwfHR+Jx0JpCz/5E2c5WnZ3Ox1sPy2t kOwLN6srXuxi+ccN
Q+klw1SKwiBLlUamy9yKR2SXQuJUpdwqPfg9+obb1SEwye1C6cfd0J8LniLz 0Ro2uaiIkcqN5bk1
h8gkwko818gv6pTtEDFry+bfkv3Me63WBjUb+t/9QMlfVGnZZy2yC275QcBp Re6HrkW2RGvYSBHf
CIuHQHOrlfw9cL5CeQAswWfb7hGLxrLz1Iqn0A3uVZT3UqSQSm4MJITwKQeS xTyjR9ulgOOjX/QB
CHIbiajyCgquMbcVHVdADwcwZYEaojYAYhjUXLRDqdKHWT4rMCeY1SU2/Fdw rgK4iMBMuRW2zLBH
pMqXNX2eZRqNIWqkqE/1C1Fzy63jfRcFDJyG0AsQeqNXEx/B8wutLKYWMwjV gJRit+hjdHmImoqG
UEKYx0cdF8hC5FzCpkNguSH/hBzXLV4Uu/A6wYXADh5GXnkPqMVZMruBmPzr 9zuNv/vRo/F1Mr6t
BGo4o/wGmxt/Yh8ywDuQuwVR7Wt1qAl2OZlOfwxnyZf4jUP7TfT7LSMf/5cV p2D+Yiw+MncBCy1y
K12bdKeKZyJfwonGRb/q8JV9lCddaKIjBvXFyoG3MAFSg2yp81BRV5W65UKf PymRtTTFdck7YkHH
OoH4jGlpMeq6OW1SLQr7yazUOjr5xqVFfRI7o7GT6+wO56/5Jxh7LTD7Glzs dFAaPFDqktPEz5r4
X/cHMbfaZc400bhE0L3xhDt3tnqjun1k7dRl7+z0XmUvZ8lKGKA3rybBab96 eNqvEF1f/Q9OjddJ
aw5KLal3W2uJ0ZXJonqlMBpdwzLPJEbNqGI307vPk+sfk4u4V2mqbhpUF8Bt rMjQ87x0A2UQ2HVs
zuK2NQpeySeMyI+YWTWmOafpyl6S7chne1+rka4z6MIfXqvPb2e7se+0jA42 5pz90N9k59X/kGTq
yjN+TrGwQuWAvkJ1jUgAvV803tKHRNPqDK6/bkreDLKq6n6KDUtraQ+TeU8N ud43zoJPbblmePfg
7VJns69UnR50qWd7sODUrq3hfqiS0fn1aDz1ikY8T1G+U/ZafdOfH1BXYQSG P0nuVvqW3xG+erhx
u4GODtUO8H2po26D7saDHbfClaA1Cuo5c2j5KvmWyJtJ40KhO/A3lyWa1qhp TSkKfdDZW2mVL8Sy
1Fit2LCVKU/7VjJ7I9BAt1fvxgolyTlYgeb2ReK7nAY33S66Ov8H/q2o2/F8 8n0cDqPpbD6mkvb7
/pxMkmn7fDW53ph3n/8AUEsHCAJbT/AKBAAARAsAAFBLAwQUAAgACACJTBQ5 AAAAAAAAAAAAAAAA
IwAAAGNvbS5teS50ZXN0L3NyYy90ZXN0L0FjdGl2YXRvci5qYXZhrVNha9sw EP3sQP7DNftih1X+
AWHQbBlLxihlWenHocoXR1SWjHROGsb++062kmwtpWzMGGxO9969e3caj8aj VqoHWSMQBpqNOaCb
1nkC52vhQq3FxssG984/iPedrQzOFemdJOdnr+d+cJbwceAtp9PxCKbwbYsg jxygjAwBFOd5ZwIQ
H7amqy+1BaM3COqgDEZcyVK7e6NVgpxkAIsw2KClAE8Uwo9YOCvLvuiRd7Xg WOIKJIk/G22lgTV5
bWu4+XL7aXX9fbWAdzBRrhHNQUR3JrPf2cJWeqxAW6awCiOlj1XxyHlWEQtr y+gswqMNWfKB+w7k
O8VZfbA8KzvB8yK2kf0ciidwbp29/Cx3snKqGEJXAbGfBCqj24Ci02KoLOb3 XIU9v13d9IE3LNFT
/trYiqeadk5XMGD/SOznFwE8P+/2AT4+KmxJO9tLz9aHQNgI15FgkywZm0+W dxcXk4JNYT/Tk1iE
x1ozwK/R77TCfEnUxn+DJPrhixrpmiXnxVt2AvdwYxzNq8pjCCkxL/jMdsbE Elk2GMEDpa0Os/9v
p2v/2U2G/pWZp1Zid7OX7F0zb8v7ubzrTT71mxr+itR5O9y355sMKevK92kv ZpXPLtJ56XlEC9zI
zlBa4CyRnW8Da+L3F1BLBwjgJ7Fm5wEAAIUEAABQSwMEFAAIAAgAiUwUOQAA AAAAAAAAAAAAACUA
AABjb20ubXkudGVzdC9zcmMvdGVzdC9BcHBsaWNhdGlvbi5qYXZhbY9NbgIx DIXXk1N41wGhcADU
BVK7YIeqoq5DxkCESaLY0ymquHs9alpYTBb58+f3nrPzZ3dEEGRZGRMuORWB VI4WPYXMaMsglsIB
/dUT2s1rlHLdphAVn6BZ6SF0RxS2L4Ezuesk1we7JSeHVC67jRov53MDc3g/ BQZPjnVP6pSIwRGB
44xeGNIB5ITgcqbgnYQUnxjwC30/3lVhaXK/11oVWd9B0BSEF4wq8zAFfBvT 1J7x6Qs6wd2mnWml
aeoM0NXzGe6x7S9bkXa2Un6UKMg9yRS6jt1bHz9SOe8x+lP7J7uAiMNj2H9k 3X0GTkXTjPKgq6D0
JVYT/buZm/kBUEsHCJ9FKUr/AAAAxgEAAFBLAwQUAAgACACJTBQ5AAAAAAAA AAAAAAAANQAAAGNv
bS5teS50ZXN0L3NyYy90ZXN0L0FwcGxpY2F0aW9uQWN0aW9uQmFyQWR2aXNv ci5qYXZhjZLLTsMw
EEXX9VfMjlKB+wFdFQRSpUogxAJWyLEnjVXHtjwOAaH+O+MklIcQYjWe19Xc k0Sl92qHkJHySgjb
xpAyhLSTqJ2NhLKzUsXorFbZBi/XuoQLldbm2VJIq3/sbI5Ll8HXdtcl5D2x XCwELGDtQQ19qFQC
NcqCJUhIMXiylUOouaQTsp7fnfGQGaM3YCxPEacQ6iKXG5z0qMyhgRxAQR/S vkKvG+itN6GXcKWO
CQfnoEKIIXZOZV7qbW6KnMf+Q05yvhSxq9gYaKeIYP3p8icYwJeM3vDMz8ab ELPlcqoTnMNIUPk8
nOpcYEUsRgghePcK1kOr9jhtjL657aEjHLQ4aYcHTxYAdfHTYm6CIQn3DdNE T8yduK3yd0gJ/Ulm
2gNfNINOX9SLyvF6Kp9E83UTHLjebLdPt3c3D4+SDU1Y/gAy/+03AH18njKY 2Yy6iGn+pboSs4M4
iHdQSwcIIXDjwl4BAACpAgAAUEsDBBQACAAIAIlMFDkAAAAAAAAAAAAAAAA1 AAAAY29tLm15LnRl
c3Qvc3JjL3Rlc3QvQXBwbGljYXRpb25Xb3JrYmVuY2hBZHZpc29yLmphdmGV kL1uwjAQx2f7KU5M
dMkLRAyIZsgWQVXGyjhHeiLY1vkSqCrevUGpkqZNpXazdP79v4KxJ1MhCEZJ taZz8CzguUrQ1hQi
Jg0lJoSarBHyLsn3nk8HdPZ1T670l413R6oaRk7/QA/wumwp+v8xveFA6tAc uk9gaxMjrEfiuwng
VdCVEX4c3rVWgak1ghClgy0cyZkadsLkKiiy7a7INk/5c/aSP8IKFue3+1JJ QI4BrVCLi/Qu0keZ
jwqWsXOYPy61Uur3UcEOz4curlKM0rADh5fZylPtL3Cq1W0M+tmvQskdCZm6 54qxVl4uJ4bTKXq1
m/4AUEsHCBeD3Nb0AAAAPwIAAFBLAwQUAAgACACJTBQ5AAAAAAAAAAAAAAAA OwAAAGNvbS5teS50
ZXN0L3NyYy90ZXN0L0FwcGxpY2F0aW9uV29ya2JlbmNoV2luZG93QWR2aXNv ci5qYXZhlVJBbtsw
EDyLr1j4RAMFYaC5GTm4RQ8BWieIDPhMUxt5EYYkyFWcNvDfQ9mpqtoS4ugi gpyZnRkyaPOoawTG
xHMh6Cn4yOBjrdBYCglV2rEq16v52FkdddiSSerOk+NBWENKh2DJaCbv1MK0 v286LqpnSj5ewrnp
SN+9e6C6iXgZb+3j4wad2a7JVX73OfYJufMrQrPJIDBWpwSLf4xhAuALo6sS jBy/ClG8K36oJccT
gemW06xZFKkJGGVvdy6KfW/WyT2AiagZT7dlViqG+j+bF5Gb6MDhrp/jTO/c 0EWZYA6d9WdPFYSI
R/htQCePFnrwa6iRT/VkO7KHUgm53KK1Jf+2KCG/dLW8Xf6AAdyNIyZtS/qD ss14ePDyajb7Al9n
s+mgcjvb2xxePmibcARTsuYm/SSHo7AVcfY3uV/c9budHBv8vxaf/sY+3OdZ M6rrRU7b9SF/XuYp
v/QLPeV8leTYZBsgIH97sRdvUEsHCDPa6L1uAQAAKQQAAFBLAwQUAAgACACJ TBQ5AAAAAAAAAAAA
AAAAJgAAAGNvbS5teS50ZXN0L3NyYy90ZXN0L0NhdGVnb3J5Vmlldy5qYXZh jVTbbhoxEH0mUv5h
ypORIvcDUB7SBBqkJUENadWnyDEDODH2yp6FRFX+vWOzC9sUlEiItTxnLmfO jEuln9UCgTBS//Tk
9MSsSh8IntRaSePl6HbworEk413/f6MrK7qjgGr1zuiQ5P2P4t1tRcbKS28t 6hQwHjIXxj3j7FrF
5ViVhwDb653Bh4VEbU0ZUWofUIbKkVmhHBqLhdeKfOh/jJ4oWn4GZhXNfVgd hj7NlUapMjk5RleN
lePmHskfNyTvfk2PGx+D30QM8tv2exxo1auvKDG2RT4eh27MbIEUWQW2R0P4 Gaij4O3HwMT4MKoy
slSB5E+DmwkfsoCnJ2X1aI0GbVWMcKkIFz68JgzgC6GbRWgc4E/Cd2qHSIr4 MzdOWeD5M24Boys4
h24aY9mO1M2pOo3n2psZaB5YwhS2piZ23QAuEx31Ur5Op7O/17vTOTgucGcR W48zYCnlze3NoNfP
rjsHGZG2qojkuBdJJI/hqCh6tUutd52hVv2f+AkNNZrXC6pgGc3Nv56Oizzs PHmiBpg5iIz4wgEr
a6GXr7fMKLzWHJu0qc77YEVrb2TA6O0aBUfpSfIDViVwz4e8AaKp+g0Yq5cg Wk8FYNPBDsqS9eFX
gh+aaeD9aMp72/+/bTVq6VSTh8fd6LeMifk7zsw0s8tJAfa9abPheZmJZoMl R/hWuZlFccELu86I
SXH/fXTzMLrqnUEuLwmRngbRDTj/mqdrSSvbZXvrHZOD8WT6+2F8ManFAQhI VXC5iH6LYnsMud9D
r6soml61hKgNjSv//gJQSwcIKLAeqFQCAACpBQAAUEsDBBQACAAIAIlMFDkA AAAAAAAAAAAAAAAl
AAAAY29tLm15LnRlc3Qvc3JjL3Rlc3QvUGVyc3BlY3RpdmUuamF2YXWOy2rD MBBF19ZXzNIBI9pF
V6GL0gcYCg2kZD+RJmaoIglpnBJK/r3j1BQvWm2EdM+9nIzuAwcCoSprY/iY UxFIZbDkAudKdmTb
bxR5xXMalfkPoVIzOeETvaCTVM46Z0we94EduIC1woIBnQl0pCgV/ujClzHN 3D0l9uAKoVAfWRjD
j0q70IJwvVbaa5qtFI4DkGedetAi3M+5HUief7/b1VrpOanLZMeV94HaA4ZK EwV6ZhC93wpGjyFF
2jF9to9qNqj09LD9UwfXWgcLP/v+tungxt7eHbqF2DR9MRfzDVBLBwiQ6ZZH 4QAAAIYBAABQSwME
FAAIAAgAiUwUOQAAAAAAAAAAAAAAACgAAABjb20ubXkudGVzdC9zcmMvdGVz dC9UZXN0Q21kSGFu
ZGxlci5qYXZhlZHPcoIwEMbPMOM77BEueQHHg7XO1OmBg209Q1ghEhIm2Ygd p+/eRLBa+2fayy4k
+/0+9qPLeZNXCISWppN4Eou204ZAm4ohl6KzyLg2obRtrkrL5oUlk3N68G8S zfQPkuUBuSOh1XKP
iv6nOHDswsNfVKtfv2m3zTmyUuRSV5bdn/r3k06w1UabpkDF641Qpe5/HKwH S8tG72cS8jrIwY89
+Xw/LCdx5wopOHCZWwvhbtGWIwDwQOi3gZugwQMltj5AC+dF4Rhg0UjLih1y 8vqQHSafUwcMNQWq
je4tfA04sKLodm/ohzaDq/1YhTTnJPZ4M72okTdYJoPXNAAvi49ReJTCHi7n yWARoOsapUzSFE7S
MTqLdCc1bzKVdagSMg7HAbGF5BywDncpzGYwUFn2CGkYOkZRFDrA+tUStkw7 Yp0RiqS6yL35Sy4d
Ws8Y6W+hGCRnFCgnw18NZ5PYl3dQSwcIvtvkLGEBAAA3AwAAUEsBAhQAFAAI AAgAiUwUOXJcDdLU
AAAAfgEAABYAAAAAAAAAAAAAAAAAAAAAAGNvbS5teS50ZXN0Ly5jbGFzc3Bh dGhQSwECFAAUAAgA
CACJTBQ5CL47i/4AAABkAwAAFAAAAAAAAAAAAAAAAAAYAQAAY29tLm15LnRl c3QvLnByb2plY3RQ
SwECFAAUAAgACACJTBQ5aowhaHQAAADyAAAAHAAAAAAAAAAAAAAAAABYAgAA Y29tLm15LnRlc3Qv
YnVpbGQucHJvcGVydGllc1BLAQIUABQACAAIAIlMFDlacoaNIwAAACMAAAAW AAAAAAAAAAAAAAAA
ABYDAABjb20ubXkudGVzdC9pbmRleC5odG1sUEsBAhQAFAAIAAgAiUwUOcDH kvcNAgAA5gcAABYA
AAAAAAAAAAAAAAAAfQMAAGNvbS5teS50ZXN0L3BsdWdpbi54bWxQSwECFAAU AAgACACJTBQ5GcaZ
lfMAAADBAQAAIAAAAAAAAAAAAAAAAADOBQAAY29tLm15LnRlc3QvTUVUQS1J TkYvTUFOSUZFU1Qu
TUZQSwECFAAUAAgACACJTBQ54Bfg3UUAAABNAAAAIQAAAAAAAAAAAAAAAAAP BwAAY29tLm15LnRl
c3QvV2ViQ29udGVudC9pbmRleC5odG1sUEsBAhQAFAAIAAgAiUwUOTiba1+C AgAAfQIAACMAAAAA
AAAAAAAAAAAAowcAAGNvbS5teS50ZXN0L2ljb25zL2FsdF93aW5kb3dfMTYu Z2lmUEsBAhQAFAAI
AAgAiUwUOdffu5qtBAAAqAQAACMAAAAAAAAAAAAAAAAAdgoAAGNvbS5teS50 ZXN0L2ljb25zL2Fs
dF93aW5kb3dfMzIuZ2lmUEsBAhQAFAAIAAgAiUwUOT0NZM1JAAAAVQAAABkA AAAAAAAAAAAAAAAA
dA8AAGNvbS5teS50ZXN0L3JlZi90ZXN0Lmh0bWxQSwECFAAUAAgACACJTBQ5 AltP8AoEAABECwAA
JgAAAAAAAAAAAAAAAAAEEAAAY29tLm15LnRlc3Qvc3JjL2RpYWxvZy9UZXN0 RGlhbG9nLmphdmFQ
SwECFAAUAAgACACJTBQ54CexZucBAACFBAAAIwAAAAAAAAAAAAAAAABiFAAA Y29tLm15LnRlc3Qv
c3JjL3Rlc3QvQWN0aXZhdG9yLmphdmFQSwECFAAUAAgACACJTBQ5n0UpSv8A AADGAQAAJQAAAAAA
AAAAAAAAAACaFgAAY29tLm15LnRlc3Qvc3JjL3Rlc3QvQXBwbGljYXRpb24u amF2YVBLAQIUABQA
CAAIAIlMFDkhcOPCXgEAAKkCAAA1AAAAAAAAAAAAAAAAAOwXAABjb20ubXku dGVzdC9zcmMvdGVz
dC9BcHBsaWNhdGlvbkFjdGlvbkJhckFkdmlzb3IuamF2YVBLAQIUABQACAAI AIlMFDkXg9zW9AAA
AD8CAAA1AAAAAAAAAAAAAAAAAK0ZAABjb20ubXkudGVzdC9zcmMvdGVzdC9B cHBsaWNhdGlvbldv
cmtiZW5jaEFkdmlzb3IuamF2YVBLAQIUABQACAAIAIlMFDkz2ui9bgEAACkE AAA7AAAAAAAAAAAA
AAAAAAQbAABjb20ubXkudGVzdC9zcmMvdGVzdC9BcHBsaWNhdGlvbldvcmti ZW5jaFdpbmRvd0Fk
dmlzb3IuamF2YVBLAQIUABQACAAIAIlMFDkosB6oVAIAAKkFAAAmAAAAAAAA AAAAAAAAANscAABj
b20ubXkudGVzdC9zcmMvdGVzdC9DYXRlZ29yeVZpZXcuamF2YVBLAQIUABQA CAAIAIlMFDmQ6ZZH
4QAAAIYBAAAlAAAAAAAAAAAAAAAAAIMfAABjb20ubXkudGVzdC9zcmMvdGVz dC9QZXJzcGVjdGl2
ZS5qYXZhUEsBAhQAFAAIAAgAiUwUOb7b5CxhAQAANwMAACgAAAAAAAAAAAAA AAAAtyAAAGNvbS5t
eS50ZXN0L3NyYy90ZXN0L1Rlc3RDbWRIYW5kbGVyLmphdmFQSwUGAAAAABMA EwACBgAAbiIAAAAA
------=_NextPart_000_007C_01C94B0D.27A4CE60--
Re: Equinox + Jetty + Browser Widget - Problem [message #113133 is a reply to message #112855] Sun, 23 November 2008 13:49 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Walter,
with the current implementation there is always a chance to
interfere with another resource registration.
To lower chances of a conflict, the browser widget could register
its resources in a distinct folder. If time permits, I will change
this. However, registering a resource with the alias "/" isn't
recommendable either.
Rüdiger
> </extension>
> error.
> </extension>
> "This is a Test" in the embedded browser.
> Best Regards,
Re: Equinox + Jetty + Browser Widget - Problem [message #113172 is a reply to message #113133] Mon, 24 November 2008 02:45 Go to previous message
See this bug entry:
256245: Browser widget shouldn't register its resources at /
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256245
Rüdiger Herrmann wrote:
> Walter,
> with the current implementation there is always a chance to interfere
> To lower chances of a conflict, the browser widget could register its
> resources in a distinct folder. If time permits, I will change this.
> However, registering a resource with the alias "/" isn't recommendable
> either.
> Cheers,
> Rüdiger
>> </extension>
>> an error.
>> </extension>
>> Thanks,
>> Best Regards,
Previous Topic:JFace Cell Editors missing [247122] (target milestone: 1.2 M3)
Next Topic:[Decorator] Icons not refreshed
Current Time: Sun Jul 20 13:00:45 EDT 2025
Powered by FUDForum. Page generated in 0.04252 seconds
