Home » Eclipse Projects » e(fx)clipse » How to programmatically Center a MWindow and Access his Rendering Tag.(Accessing and Modifying Login View)
How to programmatically Center a MWindow and Access his Rendering Tag. [message #1128245] Mon, 07 October 2013 09:46 Go to next message
I want to build a e(fx)clipse E4 Application which has a Login (MTrimmeredWindow) as start Window. But although i used Rendering Tag like "shellMaximized" my E4xmi dont center itself. I saw in E4 Forum a Post from Thomas.
I wanted to used it so like described in Forum but i couldnt. I cant see no Display and no Monitor.
How can i then programmatically access the Display and Monitor like in E4?
Can i access Rendering Tags like :
  • efx.window.scene.3d
  • efx.window.undecorated
  • efx.window.decoration.fxml
programmatically from a Addon for Example?
[Updated on: Wed, 09 October 2013 05:18] by Moderator
Re: How to programmatically Center a MWindow and Access his Rendering Tag. [message #1128302 is a reply to message #1128245] Mon, 07 October 2013 10:53 Go to previous messageGo to next message
I'd not do the login in a TrimmedWindow but using a lifecycleHook popup
a JavaFX-Stage
Why should shellMaximized center something? I guess we are not currently
honoring the shellMaximized (IIRC this is only available in FX8)
Although I would not use a TrimmedWindow it might make sense to center a
window so we could introduce a tag centering the window. File a bugzilla
if you want it.
> http://www.eclipse.org/forums/index.php/t/198222/ from Thomas.
Display & Monitor are SWT concepts. You need to find the JavaFX counter
parts. Screen.getPrimary() provides you with the primary monitor on your
system.
> efx.window.scene.3d
> efx.window.undecorated efx.window.decoration.fxml
Why do you want to access them? Anyways, those are part of the
M(Trimmed)Window so yes you can access them in an Addon.
Tom
Re: How to programmatically Center a MWindow and Access his Rendering Tag. [message #1128626 is a reply to message #1128302] Mon, 07 October 2013 18:10 Go to previous messageGo to next message
Hallo Tom,
Thank you for the Answers.
First of all i misuse "shellMaximized", i wanted to FullScreen my Window. But thats another Story.
You said that i better use LifeCycleHook. Well i saw a tutorial from Vogella, and with my newbie knowledge about E4 i tried to transpose it to e(fx)clipse E4 like this :
1. I added into my plugin.xml an Extension with name lifeCycleURI with a Value pointing to a Class.
2. The Class look like this where i got a warning about restrictive use of PostContextCreate :
import java.io.IOException;
import org.eclipse.e4.ui.workbench.lifecycle.PostContextCreate;
import org.eclipse.equinox.app.IApplicationContext;
import org.eclipse.fx.ui.di.FXMLBuilder;
import org.eclipse.fx.ui.di.FXMLLoader;
import org.eclipse.fx.ui.di.FXMLLoaderFactory;
import javafx.scene.layout.AnchorPane;
import javafx.stage.Stage;
@SuppressWarnings("restriction")
public class StartupLifeCycleHandler {
	@PostContextCreate
	void postContextCreate(IApplicationContext appContext, Stage primaryStage,
			@FXMLLoader FXMLLoaderFactory factory) {
		System.out.println("Enter PostContextCreate");
		FXMLBuilder<AnchorPane> builder = factory
				.loadRequestorRelative("LoginScreenView.fxml");
		try {
			AnchorPane anchorPane = builder.load();
			primaryStage.centerOnScreen();
			primaryStage.setScene(anchorPane.getScene());
		} catch (IOException e) {
			e.printStackTrace();
		// close the static splash screen
		appContext.applicationRunning();
While compiling i got no Errors but i can't see my LoginScreen, the sysout i wrote cant either be shown. Is something missing in my approach or i really dont get the point?
Re: How to programmatically Center a MWindow and Access his Rendering Tag. [message #1129027 is a reply to message #1128626] Tue, 08 October 2013 04:04 Go to previous messageGo to next message
That can't work, there's no stage at this point, the handler should look
like this:
private boolean ok;
@PostContextCreate
boolean login(@FXMLLoader FXMLLoaderFactory factory) {
Stage s = new Stage();
s.showAndWait();
return ok;
I think will work as well but you need to give it a try, in case you
are not called come back here.
Tom
On 08.10.13 00:10, Ghislain Mustermann wrote:
> Hallo Tom,
> http://www.vogella.com/articles/Eclipse4LifeCycle/article.html, and with
> like this :
> @PostContextCreate
> primaryStage,
> try {
> Thanks
Re: How to programmatically Center a MWindow and Access his Rendering Tag. [message #1129688 is a reply to message #1129027] Tue, 08 October 2013 18:21 Go to previous messageGo to next message
Hi Tom,
i cant obviously cant see the Login. I try it like u show :
	private boolean ok;
	@PostContextCreate
		Stage primaryStage = new Stage();
		try {
		primaryStage.showAndWait();
		return ok;
Re: How to programmatically Center a MWindow and Access his Rendering Tag. [message #1129712 is a reply to message #1129688] Tue, 08 October 2013 18:52 Go to previous messageGo to next message
So is the method called?
Tom
On 09.10.13 00:21, Ghislain Mustermann wrote:
> Hi Tom,
> private boolean ok;
> @PostContextCreate
> try {
> return ok;
Re: How to programmatically Center a MWindow and Access his Rendering Tag. [message #1130162 is a reply to message #1129712] Wed, 09 October 2013 05:16 Go to previous messageGo to next message
Is called!!
i forgot to set my fxml as Scene before send it to stage.
			Scene myScene = new Scene(anchorPane);
			primaryStage.setScene(myScene);
Now its shown. Thank you for that.
So my last Question, Now that i see my Login, which BEST Practices should i use to come to my MWindow and Perspective after a successful Login? From LoginController go through the Database connection and Authentication or should i use command and so on?
[Updated on: Wed, 09 October 2013 05:16] by Moderator
Re: How to programmatically Center a MWindow and Access his Rendering Tag. [message #1130170 is a reply to message #1130162] Wed, 09 October 2013 05:25 Go to previous message
On 09.10.13 11:16, Ghislain Mustermann wrote:
> Is called i forgot to set my fxml as Scene before send it to stage. Now
This does not make sense. You stop in the launch process and if you
close the window the process goes on and the initial window will open
itself.
If you wanted to ask how to pass the logged in user, credentials, ...
I'd suggest you push them to the IEclipseContext.
Tom
Previous Topic:(no subject)
Next Topic:Accessing the controller instance when using FXMLLoaderFactory
Current Time: Sun Jul 20 12:31:26 EDT 2025
Powered by FUDForum. Page generated in 0.27115 seconds
