Home » Archived » EMF Store » Importing models into projects / importing existing projects into workspace
Importing models into projects / importing existing projects into workspace [message #1125312] Fri, 04 October 2013 07:38 Go to next message
I've recently upgraded my project that was still using EMFStore/ECP 0.9.3 to EMFStore/ECP 1.0.1
Besides the typical migration obstacles I am currently facing two problems.
#1: I can't seem to find the "Import Model Element" function anymore.
This old EMFStore screenshot shows what I'm talking about:
http://www.eclipse.org/emfstore/documentation/images/share_project.png
I already discovered the feature that we can now import child elements of existing models into a project, but I need to import entire models directly into a project.
#2: Likewise, I'm not able to locate the "Import existing projects into the workspace" feature anymore, which was previously to be found under "Other -> Import -> Import Project".
I already checked the documentation but apparently I must be blind Smile
Any help would be appreciated!
Steffen
Re: Importing models into projects / importing existing projects into workspace [message #1150264 is a reply to message #1125312] Tue, 22 October 2013 12:58 Go to previous message
Hi Steffen,
sorry for the very late answer, but this newsgroup was move to th emft
newsgroup. Please let me know, if you found this newsgroup linked
anywhere so I can remove the obsolete link.
About your issue: We consolidated the import/export to one feature only,
which is "Import Project" and "Export Project", which should be
available in the right click menue on the root level.
If not, I kindly ask you to post in the EMFT newsgroup, you will get an
answer much faster then.
Best Regards
Jonas
Am 04.10.2013 14:53, schrieb Steffen Lehnert:
> I already checked the documentation but apparently I must be blind :)
> Regards,
> Steffen
Previous Topic:IMPORTANT PLEASE READ: This newsgroup moved to the EMFT newsgroup
Next Topic:IMPORTANT PLEASE READ: This newsgroup moved to the EMFT newsgroup
Current Time: Sat Jul 19 23:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.05730 seconds
