Home » Language IDEs » Java Development Tools (JDT) » Kepler breakpoints nor working
Kepler breakpoints nor working [message #1124760] Thu, 03 October 2013 18:02 Go to next message
Hi all,
I updated to Kepler yesterday, but unfortunately after updating breakpoints did not break the code when debugging. I have of course:
* checked disable all breakpoints button
* cleaned all projects and rebuild them
* disabled and re-enabled line numbers and the other options for debugging in pref.
Any suggestions?
I am using CentOS 6.3
java 6 update 41
Jesper
Re: Kepler breakpoints nor working [message #1125088 is a reply to message #1124760] Fri, 04 October 2013 02:24 Go to previous messageGo to next message
Jesper,
Obviously it works well for most of us including me, so there must be
something specific in your case why it wouldn't. Does this same issue
appear for newly created breakpoint no matter where you put them, e.g.,
even those in JDK source code?
When you say updated, do you mean you updated your existing installation
as opposed to creating a new installation with a new download? I
personally avoid ever doing the former. Better to start with something
clean, though I suppose the former ought to work too...
On 04/10/2013 3:29 AM, Jesper Karlsen wrote:
> Hi all,
> debugging in pref.
> Any suggestions?
> java 6 update 41
> Cheers,
> Jesper
Re: Kepler breakpoints nor working [message #1125126 is a reply to message #1125088] Fri, 04 October 2013 03:17 Go to previous message
My bad...when reverting back to juno, i found out it was a project problem rather than eclipse...thanks for replying though
Previous Topic:Eclipse for OSX with retina update
Next Topic:Referring to fonts in Java on openSUSE 12.3
Current Time: Sat Jul 19 12:40:19 EDT 2025
Powered by FUDForum. Page generated in 0.25970 seconds
