Home » Eclipse Projects » NatTable » [SOLVED] CellEditor in a column header?
[SOLVED] CellEditor in a column header? [message #1123149] Wed, 02 October 2013 04:44 Go to next message
I need a combo box cell editor in a column header of a NatTable. I registered it as I would register it for a table body, however on clicking the cell, the default behaviour is triggered, i.e., instead of popping up a combo box the column is selected. What am I missing here?
[Updated on: Wed, 02 October 2013 05:16] by Moderator
Re: CellEditor in a column header? [message #1123154 is a reply to message #1123149] Wed, 02 October 2013 04:50 Go to previous messageGo to next message
Did you ensure that the edit bindings are also registered for the column header? Have a look at the DefaultEditBindings, which only enable editing in the body region.
Re: CellEditor in a column header? [message #1123158 is a reply to message #1123154] Wed, 02 October 2013 04:54 Go to previous messageGo to next message
Do I have to attach new modified DefaultEditBindings to the column header layer or to the table itself?
Re: CellEditor in a column header? [message #1123164 is a reply to message #1123158] Wed, 02 October 2013 04:57 Go to previous messageGo to next message
I think it should be possible to add additional edit bindings to the table.
Re: CellEditor in a column header? [message #1123174 is a reply to message #1123164] Wed, 02 October 2013 05:15 Go to previous message
I got it to work adding it to the column header layers like this:
columnHeaderLayerStack.addConfiguration(new DefaultEditBindings() {
    public void configureUiBindings(final UiBindingRegistry uiBindingRegistry) {
        uiBindingRegistry.registerSingleClickBinding(
            new CellEditorMouseEventMatcher(GridRegion.COLUMN_HEADER), new MouseEditAction());
Now I can add labels to the column header cells and add the editors via the config registry as if I would add them to the body cells.
[Updated on: Wed, 02 October 2013 05:18] by Moderator
Previous Topic:How to change max and min values of chart using bookmark
Next Topic:CellPainter painting outside of NatTable?
Current Time: Sat Jul 19 15:48:38 EDT 2025
Powered by FUDForum. Page generated in 0.04741 seconds
