Home » Newcomers » Newcomers » How to reconfigure eclipse after moving the directories? Eclipse crashing(Moved eclipse IDE folders, now dependencies not found.)
How to reconfigure eclipse after moving the directories? Eclipse crashing [message #1118769] Fri, 27 September 2013 15:20 Go to next message
Short version: I moved the eclipse IDE directories into a folder in program files, and now the program stops loading on splash screen because the dependencies are not where they think they are(it is still configured to the old spot). How can I fix this without reinstalling each version of eclipse?
I have 3 different copies of eclipse: eclipse Android, RCP and EE. I decided it would be wise to move them all into an eclipse directory in program files in Windows and have each version in a separate directory within the "eclipse" directory. So here is how it looks:
Program Files
eclipse
eclipse EE
-files
eclipse RCP
-files
eclipse Android
-files
Before the directories were in my downloads folder and now when I try to launch each one after moving them I am getting all sorts of errors about certain directories/files not being found since they still think they are configured to the downloads directory.
So my question is: Where can I find the configuration file for each version so that I can fix this mess, and have working eclipse versions? I am guessing their is a global config for each one to set dependant directories if not, how can I fix it without redownloading each one?
Re: How to reconfigure eclipse after moving the directories? Eclipse crashing [message #1118905 is a reply to message #1118769] Fri, 27 September 2013 18:47 Go to previous messageGo to next message
> Program Files
> eclipse
> eclipse EE
> -files
> eclipse RCP
> -files
> eclipse Android
> -files
This should not be a problem, at least not for JEE. (I've never done
RCP, but I don't remember ADT suffering from this except that you might
have to respecify the path to the Android SDK.) Please list one or more
of the "certain directories/files not being found".
Re: How to reconfigure eclipse after moving the directories? Eclipse crashing [message #1121668 is a reply to message #1118905] Mon, 30 September 2013 17:33 Go to previous message
And in general, don't put Eclipse under the Program Files directory. Strange things happen there permission-wise if you are not an admin user.
Previous Topic:Can't login to Gerrit, Marketplace and MediaWiki
Next Topic:how to install Eclipse for J2EE in Linux(Ubuntu 13.04)
Current Time: Sun Jul 20 10:54:05 EDT 2025
Powered by FUDForum. Page generated in 0.29918 seconds
