Home » Eclipse Projects » Eclipse 4 » Calling Command from Code in Kepler (4.3)
Calling Command from Code in Kepler (4.3) [message #1121377] Mon, 30 September 2013 11:03 Go to next message
I'm using an AWTtoSWT bridge because I have to use a 3rd party Swing component. This component shows a JPopUpMenu that contains several Actions. Now I need to call a Command within one of these Actions. But how? I'm stuck at this point. The Code of the Swing Action looks like this one:
public static class ShowDetailsAction extends AbstractAction {
	public void actionPerformed(ActionEvent e) {
             // call Command at this point
Hope someone knows an easy solution, because I found only the ICommandService for Eclipse 3.7 that's not existing anymore as it seems.
Kind regards
Johannes
Re: Calling Command from Code in Kepler (4.3) [message #1121382 is a reply to message #1121377] Mon, 30 September 2013 11:05 Go to previous messageGo to next message
ECommand and EHandlerService are your friends in e4.
Tom
On 30.09.13 17:03, Johannes Spreemann wrote:
> this one:
> @Override
> Kind regards
> Johannes
Re: Calling Command from Code in Kepler (4.3) [message #1121414 is a reply to message #1121382] Mon, 30 September 2013 11:48 Go to previous messageGo to next message
Hmm Ok,
I found the chapter 9.3 of Lars Vogel's Eclipse platform services - Tutorial, but I'm not able to Inject the EHandlerService and the ECommandService. The org.eclipse.e4.core.commands plug-in is specified in my product file (e4 RCP application). But I just get the message EHandlerService cannot be resolved to a type.
Johannes
Re: Calling Command from Code in Kepler (4.3) [message #1122135 is a reply to message #1121414] Tue, 01 October 2013 05:03 Go to previous messageGo to next message
use following code it may helps you.
 ParameterizedCommand openCommand = commandService.createCommand("your-command-ID", null);
 handlerService.executeHandler(openCommand);
[Updated on: Tue, 01 October 2013 05:04] by Moderator
Re: Calling Command from Code in Kepler (4.3) [message #1122270 is a reply to message #1122135] Tue, 01 October 2013 07:41 Go to previous messageGo to next message
Hey sumit singh,
Thanks for your answer, but unfortunately I figured out this part on my own. My problem is, that Eclipse doesn't allow me to access the ECommandService nor the EHandlerService. Sad
Everythings working fine (Handled ToolBar Elements and also Handled Menu Buttons). My problem is that I have specified the plug-in org.eclipse.e4.core.commands in my Dependencies, but I can't access the class from within my code.
Re: Calling Command from Code in Kepler (4.3) [message #1122278 is a reply to message #1122270] Tue, 01 October 2013 07:55 Go to previous messageGo to next message
How do you try to get the EHandlerService? - you need to use @Inject as a constructor, field or method parameter. Note that for handlers you always should prefer the method injection.
How do you create the class where the EHandlerService should be injected? - note that if you create your class using the new operator, injection will not happen!
Re: Calling Command from Code in Kepler (4.3) [message #1122286 is a reply to message #1122278] Tue, 01 October 2013 08:05 Go to previous messageGo to next message
1. Restarting Eclipse and renewing the dependencies sometimes helps a lot!
2. Dirk, you're right!
I can't inject it. I have no other possibility than to create the class with the new operator. In this case is there any other solution to call the command?
Re: Calling Command from Code in Kepler (4.3) [message #1122295 is a reply to message #1122286] Tue, 01 October 2013 08:15 Go to previous messageGo to next message
There are several topics in this forum about that. Smile
You need to use ContextInjectionFactory to either let your object be created via the DI framework or create it your own and inject the values afterwards.
Re: Calling Command from Code in Kepler (4.3) [message #1122357 is a reply to message #1122295] Tue, 01 October 2013 09:31 Go to previous messageGo to next message
I don't get it. For the ContextInjectionFactory I also need an injected IEclipseContext.
What I exactly need to do is:
I have a dynamically created JPopUpMenu that is generated new, everytime the user makes an right-click on a JFrame :
popup.add(generateAction(new ShowInfoAbstractAction()));
The ShowInfoAbstractAction static class looks like this:
public static class ShowInfoAbstractAction extends AbstractAction {
		// call my Command / Handler
I've done it now the "easy" way to get it working. I added the constructor and passed the ECommandService/EHandlerService within the constructor:
	ECommandService commandService;
	EHandlerService handlerService;
	public ShowInfoAbstractAction (ECommandService commandService,
			EHandlerService handlerService) {
		this.commandService = commandService;
		this.handlerService = handlerService;
				.getCommand("xyz.command.infos_open");
		ParameterizedCommand pCmd = new ParameterizedCommand(openCommand,
				null);
		handlerService.executeHandler(pCmd);
Re: Calling Command from Code in Kepler (4.3) [message #1122432 is a reply to message #1122357] Tue, 01 October 2013 11:15 Go to previous messageGo to next message
Yes of course, if you want to use injection, you need to use the ContextInjectionFactory which is performing the injection and you need the context which contains the values for the injection. That's the way it works.
If you are able to set the ECommandService and the EHandlerService as constructor parameter it is also possible to inject it. Or where do you get the values from?
Nevertheless, it is of course also a solution.
Re: Calling Command from Code in Kepler (4.3) [message #1123355 is a reply to message #1122432] Wed, 02 October 2013 09:31 Go to previous message
The ECommandService and EHandlerService are injected into the JFrame class that is generated by Eclipse via the @Creatable annotation. I add this class to the Application context without the IContextFactory, but with the Injected MApplication. Maybe it's not the way it should be done, but it works (for me) Very Happy
@Creatable
public class MyJPanel extends JPanel {
        @Inject
	public MyJFrame(MApplication application) {
		application.getContext().set(this.getClass().getName(), this);
Previous Topic:Add a ShellListener
Next Topic:Exploring your E4 context. What is inside ?
Current Time: Sun Jul 20 17:01:48 EDT 2025
Powered by FUDForum. Page generated in 0.25533 seconds
