Home » Modeling » TMF (Xtext) » SortBy in xtend(SortBy in xtend)
icon5.gif  SortBy in xtend [message #1121192] Mon, 30 September 2013 07:12 Go to next message
Hello all,
I am sorting some collection in Xtend.
I.e. coll.sortBy[name]
This sorts me collection based on name.
But here name is a string datatype which should be converted to int.
So If I say coll.sortBy[Integer.valueOf(name)]
It will work for sure.
But name can have only integers (e.g. 1, 100,500 etc) or integers with comma (e.g. 1,3)
Here name is 1,3.
So if it contains comma then I want to add 1+3=4 and this based on these names I want to sort.
Any ideas??
Thanks in advance Smile
Re: SortBy in xtend [message #1121249 is a reply to message #1121192] Mon, 30 September 2013 08:22 Go to previous message
you should put your logic for computing the "result value" of a name into an
extension method.
Something like this:
coll.sortBy(name.resultValue)
def resultValue(String input) {
if (!input.contains(',')) {
return input
val inputParts = input.split(',')
var result = 0
for (s : inputParts) {
result = result + Integer.valueOf(s)
result.toString
HTH
Axel
Arshad Adavani wrote:
> Hello all,
> comma (e.g. 1,3) Here name is 1,3.
> Any ideas??
> Thanks in advance :)
Previous Topic:Accessing files in other projects in xtext
Next Topic:Creat automatically element in the current resource
Current Time: Sat Jul 19 11:54:57 EDT 2025
Powered by FUDForum. Page generated in 0.05192 seconds
