Can't access xxxxRefs from SequenceFlow [message #1118675] |
Fri, 27 September 2013 13:01  |
I have a simple flow that contains a number of SequenceFlow objects. When I parse the flow I find that the sourceRef and targRef fields are empty in the SequenceFlow objects even though I can see them in the XML -
Here is the XML -
<sequenceFlow id="flow1" sourceRef="startevent1" targetRef="parallelgateway2"></sequenceFlow>
(The id field is populated by the way)
And here is the code that I use to access the elements -
URI uri = URI.createURI("test.bpmn");
Bpmn2ResourceFactoryImpl resFactory = new Bpmn2ResourceFactoryImpl();
Resource resource = resFactory.createResource(uri);
resource.load(getResourceAsStream(filename), Collections.EMPTY_MAP);
// Definitions is the root element in our xml file
Definitions d = (Definitions) resource.getContents().get(0).eContents().get(0);
// We are only interested in the processes for the moment
List<RootElement> rootElements = d.getRootElements();
for( RootElement possibleProcessElement: rootElements) {
if (possibleProcessElement instanceof org.eclipse.bpmn2.Process) {
org.eclipse.bpmn2.Process process = (org.eclipse.bpmn2.Process) possibleProcessElement;
for (FlowElement anElement : process.getFlowElements()) {
if (anElement instanceof SequenceFlowImpl) {
SequenceFlow aSequence = ((SequenceFlow) anElement);
if (aSequence!=null) {
String source="";
String target="";
if (aSequence.getSourceRef() != null) source = aSequence.getSourceRef().getId();
if (aSequence.getTargetRef() != null) target = aSequence.getTargetRef().getId();
System.out.println(aSequence.getId()+" Flow from source "+source+" to "+target+" "+aSequence.toString());
And the output is this (all the flows are the same - with different ids of course) -
flow1 Flow from source to
Looking at my jars the classes are all in - org.eclipse.bpmn2_0.7.0.201304230617.jar
I am running in Eclipse Juno -
Eclipse SDK
Version: 4.2.1
Build id: M20120914-1800
Ken
Re: Can't access xxxxRefs from SequenceFlow [message #1121121 is a reply to message #1120004] |
Mon, 30 September 2013 05:40   |
Hi Bob
Thanks for taking the time to look at this. Here is the BPMN file and the code I use to analyse it. (I couldn't find how to attach files from the help). I had to take the definitions out as it seemed to think that I was using links to eclipse.org sites.
<collaboration id="Collaboration">
<participant id="pool1" name="Location1" processRef="process_pool1"></participant>
<participant id="pool2" name="ILM" processRef="process_pool2"></participant>
<participant id="pool3" name="P6" processRef="process_pool3"></participant>
</collaboration>
<process id="myProcess" name="My process" isExecutable="true">
<startEvent id="startevent1" name="Start"></startEvent>
<parallelGateway id="parallelgateway2" name="Parallel Gateway"></parallelGateway>
<sequenceFlow id="flow2" sourceRef="parallelgateway2" targetRef="DOG1createFile"></sequenceFlow>
<sequenceFlow id="flow3" sourceRef="parallelgateway2" targetRef="CATcreateFile"></sequenceFlow>
<sequenceFlow id="flow18" sourceRef="startevent1" targetRef="VZMZATCreateFile"></sequenceFlow>
</process>
<process id="process_pool1" name="process_pool1" isExecutable="true">
<laneSet id="laneSet_process_pool1">
<lane id="lane1" name="ProductD">
<flowNodeRef>Location1PDReceiveFile5</flowNodeRef>
</lane>
<lane id="lane2" name="ProductB">
<flowNodeRef>parallelgateway4</flowNodeRef>
<flowNodeRef>Location1ProductBCombineFiles7</flowNodeRef>
</lane>
<lane id="lane7" name="ProductA">
<flowNodeRef>Location1ProductASendFile10</flowNodeRef>
<flowNodeRef>Location1ProductAReceiveFile6</flowNodeRef>
<flowNodeRef>Location1ProductAWaitForCombinedFile9</flowNodeRef>
</lane>
</laneSet>
<serviceTask id="Location1ProductAReceiveFile6" name="6. [Location1] <ProductA> Receive file " activiti:expression="XCALL_waitForFileArrival" activiti:resultVariableName="success_waitforfile">
<extensionElements>
<activiti:field name="filewearewaitingfor">
<activiti:string>Location1:filesystem:filewearewaitingfor</activiti:string>
</activiti:field>
</extensionElements>
</serviceTask>
<sequenceFlow id="flow12" sourceRef="Location1ProductAReceiveFile6" targetRef="parallelgateway4"></sequenceFlow>
<callActivity id="Location1ProductBCombineFiles7" name="7. [Location1] <ProductB> Combine files" activiti:async="true" calledElement="ProductB_combineFiles">
<extensionElements>
<activiti:in sourceExpression="filewearewaitingfor" target="filesystem"></activiti:in>
<activiti:in sourceExpression="otherfilewearewaitingfor" target="filesystem"></activiti:in>
</callActivity>
<parallelGateway id="parallelgateway4" name="Parallel Gateway"></parallelGateway>
<sequenceFlow id="flow14" sourceRef="parallelgateway4" targetRef="Location1ProductBCombineFiles7"></sequenceFlow>
<callActivity id="Location1PDReceiveFile5" name="5. [Location1] <ProductD> Receive File"></callActivity>
<sequenceFlow id="flow13" sourceRef="Location1PDReceiveFile5" targetRef="parallelgateway4"></sequenceFlow>
<serviceTask id="Location1ProductASendFile10" name="10. [Location1] <ProductA> Send File" activiti:expression="XCALL_copyit" activiti:resultVariableName="success_file_sent">
<extensionElements>
<activiti:field name="sourceFile">
<activiti:string>Location1:filesystem:combinedFile</activiti:string>
</activiti:field>
<activiti:field name="destinationFile">
<activiti:string>P6:filesystem:combinedFile</activiti:string>
</activiti:field>
</serviceTask>
<sequenceFlow id="flow16" sourceRef="Location1ProductASendFile10" targetRef="P6AppReceiveFile"></sequenceFlow>
<serviceTask id="Location1ProductAWaitForCombinedFile9" name="9. [Location1] <ProductA> Wait for combined file " activiti:expression="XCALL_waitForFile" activiti:resultVariableName="success_fileHasArrived">
<extensionElements>
<activiti:field name="combinedFile">
<activiti:string>Location1:filesystem</activiti:string>
</activiti:field>
</serviceTask>
<sequenceFlow id="flow23" sourceRef="Location1ProductBCombineFiles7" targetRef="Location1ProductAWaitForCombinedFile9"></sequenceFlow>
<sequenceFlow id="flow24" sourceRef="Location1ProductAWaitForCombinedFile9" targetRef="Location1ProductASendFile10"></sequenceFlow>
</process>
<process id="process_pool2" name="process_pool2" isExecutable="true">
<laneSet id="laneSet_process_pool2">
<lane id="lane3" name="ZAT Point">
<flowNodeRef>VZMZATCreateFile</flowNodeRef>
</lane>
<lane id="lane4" name="ProductD">
<flowNodeRef>VZMPDSEndFile</flowNodeRef>
</lane>
<lane id="lane5" name="Dog1">
<flowNodeRef>DOG1createFile</flowNodeRef>
</lane>
<lane id="lane6" name="CAT">
<flowNodeRef>CATcreateFile</flowNodeRef>
<flowNodeRef>parallelgateway3</flowNodeRef>
</lane>
<lane id="lane8" name="ProductA">
<flowNodeRef>ILMProductANoteFileArrival3</flowNodeRef>
<flowNodeRef>ILMProductASendFile4</flowNodeRef>
</lane>
</laneSet>
<callActivity id="VZMZATCreateFile" name="2. [VZM LocationM] <ZAT Point> Create File"></callActivity>
<sequenceFlow id="flow9" sourceRef="VZMZATCreateFile" targetRef="VZMPDSEndFile"></sequenceFlow>
<serviceTask id="ILMProductASendFile4" name="4. [ILM] <ProductA> Send file" activiti:expression="XCALL_copyit" activiti:resultVariableName="success">
<extensionElements>
<activiti:expression>${filewearewaitingfor}</activiti:expression>
</activiti:field>
<activiti:string>Location1:filesystem:destinationFile</activiti:string>
</activiti:field>
</serviceTask>
<serviceTask id="ILMProductANoteFileArrival3" name="3. [ILM] <ProductA> Note file arrival" activiti:expression="XCALL_waitForFileArrival" activiti:resultVariableName="success_filearrival_at_LocationM">
<extensionElements>
<activiti:field name="fileFromLocationM">
<activiti:string>Location1:filesystem:fileFromDog1OrCAT</activiti:string>
</activiti:field>
</serviceTask>
<sequenceFlow id="flow21" sourceRef="ILMProductANoteFileArrival3" targetRef="ILMProductASendFile4"></sequenceFlow>
<callActivity id="CATcreateFile" name="1. [CAT] Create File"></callActivity>
<sequenceFlow id="flow7" sourceRef="CATcreateFile" targetRef="parallelgateway3"></sequenceFlow>
<parallelGateway id="parallelgateway3" name="Parallel Gateway"></parallelGateway>
<sequenceFlow id="flow8" sourceRef="parallelgateway3" targetRef="ILMProductANoteFileArrival3"></sequenceFlow>
<callActivity id="DOG1createFile" name="1. [DOG1] Create File"></callActivity>
<sequenceFlow id="flow6" sourceRef="DOG1createFile" targetRef="parallelgateway3"></sequenceFlow>
<callActivity id="VZMPDSEndFile" name="5. [VZM LocationM] <ProductD> Send File"></callActivity>
<sequenceFlow id="flow25" sourceRef="ILMProductASendFile4" targetRef="Location1ProductAReceiveFile6"></sequenceFlow>
<sequenceFlow id="flow26" sourceRef="VZMPDSEndFile" targetRef="Location1PDReceiveFile5"></sequenceFlow>
</process>
<process id="process_pool3" name="process_pool3" isExecutable="true">
<laneSet id="laneSet_process_pool3">
<lane id="lane9" name="AppZ">
<flowNodeRef>P6AppReceiveFile</flowNodeRef>
<flowNodeRef>terminateendevent1</flowNodeRef>
</lane>
</laneSet>
<callActivity id="P6AppReceiveFile" name="[P6] <AppZ> Receive File"></callActivity>
<sequenceFlow id="flow17" sourceRef="P6AppReceiveFile" targetRef="terminateendevent1"></sequenceFlow>
<endEvent id="terminateendevent1" name="TerminateEndEvent">
<terminateEventDefinition></terminateEventDefinition>
</endEvent>
</process>
<bpmndi:BPMNDiagram id="BPMNDiagram_Collaboration">
<bpmndi:BPMNPlane bpmnElement="Collaboration" id="BPMNPlane_Collaboration">
<bpmndi:BPMNShape bpmnElement="startevent1" id="BPMNShape_startevent1">
<omgdc:Bounds height="35.0" width="35.0" x="-40.0" y="273.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="parallelgateway2" id="BPMNShape_parallelgateway2">
<omgdc:Bounds height="40.0" width="40.0" x="32.0" y="270.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="parallelgateway3" id="BPMNShape_parallelgateway3">
<omgdc:Bounds height="40.0" width="40.0" x="314.0" y="316.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="parallelgateway4" id="BPMNShape_parallelgateway4">
<omgdc:Bounds height="40.0" width="40.0" x="730.0" y="186.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="terminateendevent1" id="BPMNShape_terminateendevent1">
<omgdc:Bounds height="35.0" width="35.0" x="990.0" y="457.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="DOG1createFile" id="BPMNShape_DOG1createFile">
<omgdc:Bounds height="65.0" width="105.0" x="174.0" y="209.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="CATcreateFile" id="BPMNShape_CATcreateFile">
<omgdc:Bounds height="67.0" width="111.0" x="164.0" y="303.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="VZMZATCreateFile" id="BPMNShape_VZMZATCreateFile">
<omgdc:Bounds height="71.0" width="161.0" x="174.0" y="19.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="VZMPDSEndFile" id="BPMNShape_VZMPDSEndFile">
<omgdc:Bounds height="71.0" width="181.0" x="164.0" y="113.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="Location1ProductASendFile10" id="BPMNShape_Location1ProductASendFile10">
<omgdc:Bounds height="55.0" width="105.0" x="1010.0" y="283.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="P6AppReceiveFile" id="BPMNShape_P6AppReceiveFile">
<omgdc:Bounds height="71.0" width="121.0" x="700.0" y="439.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="pool1" id="BPMNShape_pool1">
<omgdc:Bounds height="324.0" width="500.0" x="636.0" y="33.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane1" id="BPMNShape_lane1">
<omgdc:Bounds height="136.0" width="480.0" x="656.0" y="33.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane2" id="BPMNShape_lane2">
<omgdc:Bounds height="94.0" width="480.0" x="656.0" y="169.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="pool2" id="BPMNShape_pool2">
<omgdc:Bounds height="466.0" width="471.0" x="104.0" y="9.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane3" id="BPMNShape_lane3">
<omgdc:Bounds height="95.0" width="451.0" x="124.0" y="9.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane7" id="BPMNShape_lane7">
<omgdc:Bounds height="94.0" width="480.0" x="656.0" y="263.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane4" id="BPMNShape_lane4">
<omgdc:Bounds height="95.0" width="451.0" x="124.0" y="103.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane5" id="BPMNShape_lane5">
<omgdc:Bounds height="91.0" width="451.0" x="124.0" y="201.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane6" id="BPMNShape_lane6">
<omgdc:Bounds height="91.0" width="451.0" x="124.0" y="292.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane8" id="BPMNShape_lane8">
<omgdc:Bounds height="91.0" width="451.0" x="124.0" y="383.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="pool3" id="BPMNShape_pool3">
<omgdc:Bounds height="111.0" width="500.0" x="636.0" y="409.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="lane9" id="BPMNShape_lane9">
<omgdc:Bounds height="111.0" width="480.0" x="656.0" y="409.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="ILMProductASendFile4" id="BPMNShape_ILMProductASendFile4">
<omgdc:Bounds height="76.0" width="105.0" x="434.0" y="390.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="ILMProductANoteFileArrival3" id="BPMNShape_ILMProductANoteFileArrival3">
<omgdc:Bounds height="71.0" width="115.0" x="274.0" y="392.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="Location1ProductAReceiveFile6" id="BPMNShape_Location1ProductAReceiveFile6">
<omgdc:Bounds height="55.0" width="121.0" x="690.0" y="283.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="Location1ProductBCombineFiles7" id="BPMNShape_Location1ProductBCombineFiles7">
<omgdc:Bounds height="68.0" width="105.0" x="860.0" y="173.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="Location1PDReceiveFile5" id="BPMNShape_Location1PDReceiveFile5">
<omgdc:Bounds height="91.0" width="121.0" x="690.0" y="57.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="Location1ProductAWaitForCombinedFile9" id="BPMNShape_Location1ProductAWaitForCombinedFile9">
<omgdc:Bounds height="55.0" width="131.0" x="850.0" y="283.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNEdge bpmnElement="flow1" id="BPMNEdge_flow1">
<omgdi:waypoint x="-5.0" y="290.0"></omgdi:waypoint>
<omgdi:waypoint x="32.0" y="290.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow2" id="BPMNEdge_flow2">
<omgdi:waypoint x="52.0" y="270.0"></omgdi:waypoint>
<omgdi:waypoint x="51.0" y="241.0"></omgdi:waypoint>
<omgdi:waypoint x="174.0" y="241.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow3" id="BPMNEdge_flow3">
<omgdi:waypoint x="52.0" y="310.0"></omgdi:waypoint>
<omgdi:waypoint x="51.0" y="336.0"></omgdi:waypoint>
<omgdi:waypoint x="164.0" y="336.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow6" id="BPMNEdge_flow6">
<omgdi:waypoint x="279.0" y="241.0"></omgdi:waypoint>
<omgdi:waypoint x="334.0" y="241.0"></omgdi:waypoint>
<omgdi:waypoint x="334.0" y="316.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow7" id="BPMNEdge_flow7">
<omgdi:waypoint x="275.0" y="336.0"></omgdi:waypoint>
<omgdi:waypoint x="314.0" y="336.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow8" id="BPMNEdge_flow8">
<omgdi:waypoint x="334.0" y="356.0"></omgdi:waypoint>
<omgdi:waypoint x="331.0" y="392.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow9" id="BPMNEdge_flow9">
<omgdi:waypoint x="254.0" y="90.0"></omgdi:waypoint>
<omgdi:waypoint x="254.0" y="113.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow12" id="BPMNEdge_flow12">
<omgdi:waypoint x="750.0" y="283.0"></omgdi:waypoint>
<omgdi:waypoint x="750.0" y="226.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow13" id="BPMNEdge_flow13">
<omgdi:waypoint x="750.0" y="148.0"></omgdi:waypoint>
<omgdi:waypoint x="750.0" y="186.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow14" id="BPMNEdge_flow14">
<omgdi:waypoint x="770.0" y="206.0"></omgdi:waypoint>
<omgdi:waypoint x="860.0" y="207.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow16" id="BPMNEdge_flow16">
<omgdi:waypoint x="1062.0" y="338.0"></omgdi:waypoint>
<omgdi:waypoint x="1062.0" y="379.0"></omgdi:waypoint>
<omgdi:waypoint x="911.0" y="379.0"></omgdi:waypoint>
<omgdi:waypoint x="760.0" y="379.0"></omgdi:waypoint>
<omgdi:waypoint x="760.0" y="439.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow17" id="BPMNEdge_flow17">
<omgdi:waypoint x="821.0" y="474.0"></omgdi:waypoint>
<omgdi:waypoint x="990.0" y="474.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow18" id="BPMNEdge_flow18">
<omgdi:waypoint x="-23.0" y="273.0"></omgdi:waypoint>
<omgdi:waypoint x="-23.0" y="54.0"></omgdi:waypoint>
<omgdi:waypoint x="174.0" y="54.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow21" id="BPMNEdge_flow21">
<omgdi:waypoint x="389.0" y="427.0"></omgdi:waypoint>
<omgdi:waypoint x="434.0" y="428.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow23" id="BPMNEdge_flow23">
<omgdi:waypoint x="912.0" y="241.0"></omgdi:waypoint>
<omgdi:waypoint x="915.0" y="283.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow24" id="BPMNEdge_flow24">
<omgdi:waypoint x="981.0" y="310.0"></omgdi:waypoint>
<omgdi:waypoint x="1010.0" y="310.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow25" id="BPMNEdge_flow25">
<omgdi:waypoint x="539.0" y="428.0"></omgdi:waypoint>
<omgdi:waypoint x="605.0" y="428.0"></omgdi:waypoint>
<omgdi:waypoint x="606.0" y="308.0"></omgdi:waypoint>
<omgdi:waypoint x="690.0" y="310.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<bpmndi:BPMNEdge bpmnElement="flow26" id="BPMNEdge_flow26">
<omgdi:waypoint x="345.0" y="148.0"></omgdi:waypoint>
<omgdi:waypoint x="604.0" y="148.0"></omgdi:waypoint>
<omgdi:waypoint x="604.0" y="100.0"></omgdi:waypoint>
<omgdi:waypoint x="690.0" y="102.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
</bpmndi:BPMNPlane>
</bpmndi:BPMNDiagram>
</definitions>
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.io.InputStream;
import java.util.Collections;
import java.util.Iterator;
import java.util.List;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.util.FeatureMap;
import org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl;
import org.eclipse.bpmn2.CallActivity;
import org.eclipse.bpmn2.Definitions;
import org.eclipse.bpmn2.ExtensionAttributeValue;
import org.eclipse.bpmn2.FlowElement;
import org.eclipse.bpmn2.RootElement;
import org.eclipse.bpmn2.SequenceFlow;
import org.eclipse.bpmn2.ServiceTask;
import org.eclipse.bpmn2.impl.SequenceFlowImpl;
import org.eclipse.bpmn2.util.Bpmn2ResourceFactoryImpl;
public class TestBPMN {
public static String EXPRESSION_VARIABLE_LIST="^sourceExpression^resultVariableName^";
public static String TYPE1_LIST = "^text^name^target^sourceExpression^resultVariableName^";
public static void main(String[] args) throws IOException {
URI uri = URI.createURI("TestCase.bpmn");
resource.load(Collections.EMPTY_MAP);
System.out.println(anElement.getClass()+"");
if (anElement instanceof CallActivity) {
CallActivity aCall = ((CallActivity) anElement);
if (aCall!=null) {
System.out.println("Call activity "+aCall+" "+aCall.getAnyAttribute());
analyse(aCall.getAnyAttribute(),aCall.getExtensionValues());
if (anElement instanceof ServiceTask) {
ServiceTask aTask = ((ServiceTask) anElement);
if (aTask!=null) {
System.out.println("");
System.out.println("Service Task "+aTask.getName()+"( "+aTask.getId()+")");
analyse(aTask.getAnyAttribute(),aTask.getExtensionValues());
String source="";
String target="";
System.out.println("Trying "+aSequence);
System.out.println(aSequence.getId()+" Flow from source "+source+" to "+target);
public static void analyse(FeatureMap attrib, List<ExtensionAttributeValue> params) {
analyse(attrib);
for (ExtensionAttributeValue each: params) {
FeatureMap values = each.getValue();
Iterator<FeatureMap.Entry> valuesIt = values.iterator();
FeatureMap.Entry aValue = null;
while (valuesIt.hasNext()) {
aValue = valuesIt.next();
analyse(((AnyTypeImpl) aValue.getValue()),"");
public static void analyse(FeatureMap attrib) {
analyse(attrib,"");
public static void analyse(AnyTypeImpl params,String name) {
analyse(params.getAnyAttribute(),name);
public static void analyse(FeatureMap fm, String name) {
Iterator<FeatureMap.Entry> tempIt = fm.iterator();
while(tempIt.hasNext()) {
FeatureMap.Entry val = tempIt.next();
analyse(val, name);
public static void analyse(FeatureMap.Entry anEntry, String name) {
String type = anEntry.getEStructuralFeature().getName();
if (TYPE1_LIST.contains("^"+type+"^")) {
String retval = ((String) anEntry.getValue()).trim();
if ((retval != null) && (retval.length()>0)) {
System.out.println(" TYPE :: "+type+" NAME :: "+name+" RETVAL :: "+retval);
else if ((type.equals("string")) || (type.equals("expression"))) {
if (anEntry.getValue() instanceof AnyTypeImpl) {
analyse((AnyTypeImpl) anEntry.getValue(),name);
} else {
public static InputStream getResourceAsStream(String aString) throws FileNotFoundException {
return new FileInputStream(aString);
If you need anything more let me know
Ken
FUDForum. Page generated in 0.04292 seconds
