Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Generated identifier names too long
[Teneo] Generated identifier names too long [message #111871] Thu, 07 February 2008 05:56 Go to next message
The XSD (a standard over which I have no control, other than deviating
from the standard) I am working from has fairly long descriptive names.
Thus when Hibernate attempts to generate the various identifier they end
up too long for the database to accommodate. Is there a way to get it to
use abbreviated names?
here is an example of a generated identifier name
accretionbehaviorchildren_fractionhandlingtype_fractionhandl ingtype_e_id
Thx,
David
Re: [Teneo] Generated identifier names too long [message #111872 is a reply to message #111871] Thu, 07 February 2008 06:11 Go to previous messageGo to next message
Hi David,
Yes can set this option to a value which can be handled by the database:
props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH , "25");
Although Teneo tries to be smart you should watch for nameclashes.
You can also try to set the option:
SET_FOREIGN_KEY_NAME to false
setting this to false will use hibernate foreign key naming (resulting in unreadable fk names but
they should be unique).
gr. Martin
david wrote:
> Thx,
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Generated identifier names too long [message #111874 is a reply to message #111872] Thu, 07 February 2008 09:13 Go to previous messageGo to next message
Using
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "tLoader");
props.setProperty(Environment.PASS, "pass34w0rd");
props.setProperty(Environment.URL, "jdbc:mysql://192.168.0.3:3306/" +
dbName);
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.MySQLInnoDBDialect.class.getName());
props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH , "32");
props.setProperty(PersistenceOptions.JOIN_COLUMN_NAMING_STRA TEGY,
"simple");
props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "false");
props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE, "DATE");
props.setProperty(PersistenceOptions.DISABLE_ECONTAINER_MAPP ING, "true");
I still get lots of of identifier too long errors.
E.g.
49672 [main] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate -
Unsuccessful: create table `indexbasevalue_indexbasevaluechildren` (id
bigint not null auto_increment, e_version integer not null, fme_feature
varchar(255),
`indexbasevaluechildren_calculationtype_calculationtype_id`
varchar(255), `indexbasevaluechildren_datetime_datetime_id`
varchar(255), `indexbasevaluechildren_fraction_fraction_id`
varchar(255),
`indexbasevaluechildren_fractionhandlingtype_fractionhandlin gtype_id`
varchar(255),
`indexbasevaluechildren_indicatorstype_indicatorstype_e_id`
varchar(255), `indexbasevaluechildren_marketcenter_marketcenter_e_id`
varchar(255), `indexbasevaluechildren_multiplier_multiplier_e_id`
varchar(255),
`indexbasevaluechildren_previousdatetime_previousdatetime_e_ id`
varchar(255),
`indexbasevaluechildren_quantitydescriptiontype_quantitydesc riptiontype_e_id`
varchar(255), `indexbasevaluechildren_quantitytype_quantitytype_e_id`
varchar(255), `indexbasevaluechildren_valuationref_valuationref_e_id`
varchar(255), `indexbasevaluechildren_valuationtype_valuationtype_e_id`
varchar(255), `indexbasevaluechildren_unittype_unittype_e_id`
varchar(255), `mixed_indexbasevalue_indexbasevaluechildren_e_id` bigint,
`mixed_indexbasevalue_indexbasevaluechildren_idx` integer, primary key
(id)) type=InnoDB
49672 [main] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate - Identifier
name
'indexbasevaluechildren_fractionhandlingtype_fractionhandlin gtype_id' is
too long
Any other options I can change to control this, I'd prefer to have
meaningful names if possible. I initially tried
props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH , "64");
With the same result.
David
Martin Taal wrote:
> Hi David,
> in unreadable fk names but they should be unique).
> gr. Martin
> david wrote:
>> Hi,
>> names. Thus when Hibernate attempts to generate the various identifier
>> they end up too long for the database to accommodate. Is there a way
>> to get it to use abbreviated names?
>> Thx,
>> David
Re: [Teneo] Generated identifier names too long [message #111875 is a reply to message #111874] Thu, 07 February 2008 09:15 Go to previous messageGo to next message
Ignore this, I missed that I also need to load the Teneo persistance
properties separately.
david
david wrote:
> Using
> "jdbc:mysql://192.168.0.3:3306/" + dbName);
> "32");
> "simple");
> "DATE");
> "true");
> E.g.
> varchar(255),
> varchar(255),
> varchar(255),
> varchar(255),
> varchar(255),
> (id)) type=InnoDB
> name
> too long
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> deviating from the standard) I am working from has fairly long
>>> descriptive names. Thus when Hibernate attempts to generate the
>>> various identifier they end up too long for the database to
>>> accommodate. Is there a way to get it to use abbreviated names?
>>> Thx,
>>> David
Re: [Teneo] Generated identifier names too long [message #111876 is a reply to message #111875] Thu, 07 February 2008 09:22 Go to previous message
Hi David,
I was just going to post this as a reply, your confusion is by the way not surprising, I think it
would be simpler to change this to one setProperty method.
gr. Martin
> david
> david wrote:
>> Using
>> "32");
>> "simple");
>> "DATE");
>> E.g.
>> fme_feature varchar(255),
>> varchar(255),
>> varchar(255),
>> varchar(255),
>> varchar(255),
>> varchar(255),
>> bigint, `mixed_indexbasevalue_indexbasevaluechildren_idx` integer,
>> primary key (id)) type=InnoDB
>> Identifier name
>> is too long
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> (resulting in unreadable fk names but they should be unique).
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Thx,
>>>> David
The Netherlands
Re: [Teneo] Generated identifier names too long [message #615422 is a reply to message #111871] Thu, 07 February 2008 06:11 Go to previous message
Hi David,
gr. Martin
david wrote:
> Thx,
> David
The Netherlands
Re: [Teneo] Generated identifier names too long [message #615424 is a reply to message #111872] Thu, 07 February 2008 09:13 Go to previous message
Using
dbName);
"simple");
E.g.
varchar(255),
varchar(255),
varchar(255),
varchar(255),
varchar(255),
(id)) type=InnoDB
name
too long
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> Thx,
>> David
Re: [Teneo] Generated identifier names too long [message #615425 is a reply to message #111874] Thu, 07 February 2008 09:15 Go to previous message
david
david wrote:
> Using
> "32");
> "simple");
> "DATE");
> "true");
> E.g.
> varchar(255),
> varchar(255),
> varchar(255),
> varchar(255),
> varchar(255),
> (id)) type=InnoDB
> name
> too long
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Thx,
>>> David
Re: [Teneo] Generated identifier names too long [message #615426 is a reply to message #111875] Thu, 07 February 2008 09:22 Go to previous message
Hi David,
gr. Martin
> david
> david wrote:
>> Using
>> "32");
>> "simple");
>> "DATE");
>> E.g.
>> varchar(255),
>> varchar(255),
>> varchar(255),
>> varchar(255),
>> varchar(255),
>> Identifier name
>> is too long
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Thx,
>>>> David
The Netherlands
Previous Topic:[EMF Compare] version number for EMF 2.3
Next Topic:Hibernate: driver not found com.mysql.JDBC.driver
Current Time: Sun Jul 20 18:54:20 EDT 2025
Powered by FUDForum. Page generated in 0.04470 seconds
