Home » Archived » Jubula » Jubula Eclipse Feature: Test AUT from source
Jubula Eclipse Feature: Test AUT from source [message #1117415] Thu, 26 September 2013 08:19 Go to next message
Hello.
I have successfully installed your Jubula Feature in my Eclipse Kepler and it works now.
But the question is, is it possible to test my AUT (an RCP Eclipse Application) directly from the source code? The AUT source code is under development and therefore located in the workspace of Eclipse Kepler, which contains your Jubula Feature.
Is there any solution, which simplifies it? I think I can execute an Ant-Script which using your command line tools (compiling AUT source code, start Aut Agent Tool, start Autrun Tool) but I think, this is very complex.
Greetings
Re: Jubula Eclipse Feature: Test AUT from source [message #1118465 is a reply to message #1117415] Fri, 27 September 2013 08:40 Go to previous message
Hi there,
Yes, that is possible. To do it, you'll need to work with the launch configurations.
While this is excellent for trying tests out, I would definitely recommend running regression tests on a dedicated machine with a reproducible build and environment as well Wink
Alex
Previous Topic:Eclipse Jubula
Next Topic:Operation not supported by the selected toolkit
Current Time: Sun Jul 20 10:06:12 EDT 2025
Powered by FUDForum. Page generated in 0.14249 seconds
