Home » Eclipse Projects » eRCP » How to reuse 3.x command "org.eclipse.ui.file.import" in Application.e4xmi
How to reuse 3.x command "org.eclipse.ui.file.import" in Application.e4xmi [message #1116168] Tue, 24 September 2013 23:55 Go to next message
I got information that Eclipse 3.x command id like "org.eclipse.ui.file.import" could be used in Application.e4xmi. However, after binding it to a menu item, the menu item is always disabled because there is no a handler for command. Does anyone know how to reuse command "org.eclipse.ui.file.import" in Application.e4xmi?
Re: How to reuse 3.x command "org.eclipse.ui.file.import" in Application.e4xmi [message #1130157 is a reply to message #1116168] Wed, 09 October 2013 05:14 Go to previous message
I had same question, Who can answer it, thanks!
Previous Topic:Remove toolbar from the tab list
Next Topic:RCP 3.0 Export.
Current Time: Sat Jul 19 22:44:23 EDT 2025
Powered by FUDForum. Page generated in 0.24878 seconds
