Home » Eclipse Projects » Eclipse 4 » No icons after exporting
No icons after exporting [message #1111724] Wed, 18 September 2013 12:38 Go to next message
Hi !
I am facing a problem :
After exporting my project, I don't have any icons on my treeView anymore.
Here is my code :
public class TodoLabelProvider extends LabelProvider {
	private static final Image FOLDER = getImage("folder.png");
	private static final Image FILE = getImage("file.png");
	public Image getImage(Object element) {
		if (element instanceof Message) {
			return FOLDER;
		} else if (element instanceof Word) {
			return FILE;
		return null;
	private static Image getImage(String file) {
		Bundle bundle = FrameworkUtil.getBundle(TodoLabelProvider.class);
		URL url = FileLocator.find(bundle, new Path("icons/" + file), null);
		ImageDescriptor image = ImageDescriptor.createFromURL(url);
		return image.createImage();
Here is my build.properties :
output.. = bin/
bin.includes = META-INF/,\
               plugin.xml,\
               Application.e4xmi,\
               css/default.css,\
               template/,\
               xslt/,\
               icons/
source.. = src/
I don't understand why it does not work.
Do I have to add something in the plugin.xml ?
Thank you for your help !
ps : it works just fine when i launch the application from eclipse.
Re: No icons after exporting [message #1112834 is a reply to message #1111724] Fri, 20 September 2013 04:33 Go to previous messageGo to next message
can you check the deployed version of your bundle, whether the icons are
in it? Do you deploy the bundle as a jar or as a folder?
Jonas
Am 18.09.2013 18:38, schrieb romain ognier:
> Hi !
> Here is my code :
> @Override
> return FOLDER;
> return FILE;
> return null;
> null);
> } } Here is my build.properties :
> output.. = bin/
> plugin.xml,\
> Application.e4xmi,\
> css/default.css,\
> template/,\
> xslt/,\
> icons/
> source.. = src/
Re: No icons after exporting [message #1114788 is a reply to message #1112834] Mon, 23 September 2013 03:55 Go to previous messageGo to next message
I am just exporting my project as an Eclipse product.
So I don't know what to tell you.
Re: No icons after exporting [message #1114832 is a reply to message #1114788] Mon, 23 September 2013 05:11 Go to previous messageGo to next message
Did you ensure to add your icons to the build.properties?
http://www.vogella.com/articles/EclipseProductDeployment/article.html#deployproduct_buildproperties
Re: No icons after exporting [message #1115563 is a reply to message #1114832] Tue, 24 September 2013 05:06 Go to previous messageGo to next message
Yes.
My build property is in my first message :
output.. = bin/
               plugin.xml,\
               Application.e4xmi,\
               css/default.css,\
               template/,\
               xslt/,\
               icons/
source.. = src/
you can see "icons/" in the bin.includes
Re: No icons after exporting [message #1115579 is a reply to message #1115563] Tue, 24 September 2013 05:36 Go to previous messageGo to next message
Oh sorry, missed that.
Did you ensure that all necessary bundles are added to your product?
Re: No icons after exporting [message #1115634 is a reply to message #1115579] Tue, 24 September 2013 07:09 Go to previous messageGo to next message
No problem Smile
How can I ensure that ?
[Updated on: Tue, 24 September 2013 07:09] by Moderator
Re: No icons after exporting [message #1115675 is a reply to message #1115634] Tue, 24 September 2013 08:22 Go to previous messageGo to next message
Open your product configuration and click "Add Required" on the Dependencies tab
[Updated on: Tue, 24 September 2013 08:22] by Moderator
Re: No icons after exporting [message #1115684 is a reply to message #1115675] Tue, 24 September 2013 08:33 Go to previous messageGo to next message
Just did it.
And it still does not work Crying or Very Sad
Re: No icons after exporting [message #1115688 is a reply to message #1115684] Tue, 24 September 2013 08:39 Go to previous messageGo to next message
In your exported product, there is a folder named plugins. Locate your plugin JAR there and open it with an archive tool. Check if your icons are in there. That's what Jonas was suggesting.
Re: No icons after exporting [message #1115694 is a reply to message #1115688] Tue, 24 September 2013 08:48 Go to previous messageGo to next message
Yes, they are !
Re: No icons after exporting [message #1115702 is a reply to message #1115694] Tue, 24 September 2013 08:57 Go to previous messageGo to next message
Why doing the loading this hard?
TodoLabelProvider.class.getClassLoader().getResource("icons/"+name) is
much simpler.
Tom
On 24.09.13 14:48, romain ognier wrote:
> Yes, they are !
Re: No icons after exporting [message #1115709 is a reply to message #1115702] Tue, 24 September 2013 09:10 Go to previous messageGo to next message
Yes, it is simpler.
So I changed my code :
	public String getText(Object element) {
		if (element instanceof Dico) {
			Dico dico = (Dico) element;
			return dico.getName();
		} else if (element instanceof Message) {
			Message messageJ = (Message) element;
			return messageJ.getName();
		return ((Word) element).getName();
			return FOLDER;
			return FILE;
		return null;
	// Helper Method to load the images
		URL url = TodoLabelProvider.class.getClassLoader().getResource("icons/"+file);
But it still does not work. Crying or Very Sad
Re: No icons after exporting [message #1115732 is a reply to message #1115709] Tue, 24 September 2013 09:56 Go to previous messageGo to next message
Are you sure that your use cases are the same as when starting the product from within Eclipse? That means, are you sure the objects are of the corresponding type?
Re: No icons after exporting [message #1115745 is a reply to message #1115732] Tue, 24 September 2013 10:17 Go to previous messageGo to next message
Yes, I am.
I am pretty sure that this is :
which does not work.
Cause i use
TodoLabelProvider.class.getClassLoader().getResource(file)
somewhere else in my code on xml file and it works perfectly fine. I put my icons in the same directory of my xml file but it still does not find them !
Edit :
Ok, I may have find something usefull, I don't know why, but :
URL url = TodoLabelProvider.class.getClassLoader().getResource(file);
clearly does not work. url is null.
Does this have anything to do with the fact that my method is static ?
[Updated on: Tue, 24 September 2013 10:35] by Moderator
Re: No icons after exporting [message #1115758 is a reply to message #1115745] Tue, 24 September 2013 10:44 Go to previous messageGo to next message
It shouldn't. Is your code in a plugin or in a fragment?
Re: No icons after exporting [message #1115765 is a reply to message #1115758] Tue, 24 September 2013 10:57 Go to previous messageGo to next message
Ok... I found out...
And I feel really ashamed.
It seems that eclipse is not case sensitive but the exported project is.
My files name extension was in upper case.
I am really sorry I bothered you for this. Thank you really much anyway.
Re: No icons after exporting [message #1115954 is a reply to message #1115765] Tue, 24 September 2013 16:23 Go to previous message
This was the next I was to suggest! This is f** win32 which does not
care about upper/lowercase whereas any sensible filesystem does and jar
is a filesystem type which is one ;-)
Tom
Previous Topic:ACTIVE_PART: exactly when is it set?
Next Topic:Create product with resources
Current Time: Sun Jul 20 16:11:10 EDT 2025
Powered by FUDForum. Page generated in 0.06587 seconds
