Home » Modeling » GMF (Graphical Modeling Framework) » AbstractTransactionalCommand
AbstractTransactionalCommand [message #1114956] Mon, 23 September 2013 09:14 Go to next message
Hi all,
i need to customize element via command. So i write;
IWorkbench workbench = PlatformUI.getWorkbench();
		Shell shell = workbench.getActiveWorkbenchWindow().getShell();
		FormCreationWizard wizard = new FormCreationWizard();
		wizard.init(workbench, new StructuredSelection());
		WizardDialog dialog = new WizardDialog(shell, wizard);
		dialog.create();
		if (dialog.open() != Window.OK) {
			// return null;
		} else {
			final ResourceSet resourceSet = wizard.getDiagram().getResourceSet();
			FormModel fm = (FormModel) resourceSet.getResources().get(1)
					.getContents().get(0);
			TransactionalEditingDomain editingDomain = TransactionUtil
					.getEditingDomain(fm);
				IFile affectedFile = WorkspaceSynchronizer.getFile(fm.eResource());
				new AbstractTransactionalCommand(
						editingDomain,
						"Set Values", affectedFile == null ? null : Collections.singletonList(affectedFile)) { //$NON-NLS-1$
					protected CommandResult doExecuteWithResult(
							IProgressMonitor monitor, IAdaptable info)
							throws ExecutionException {
						((FormModel) (resourceSet.getResources().get(1).getContents().get(0))).setContext(ct);
						((FormModel) (resourceSet.getResources().get(1).getContents().get(0))).setName("FormModel");
						return new CommandResult(new Status(IStatus.OK, CommonCorePlugin.getPluginId(),
								CommonCoreStatusCodes.OK, StringStatics.BLANK, null));
but
((FormModel)(resourceSet.getResources().get(1).getContents().get(0))).setName("FormModel");
these are not executed. why don't understand.
anyone can help me ?
[Updated on: Mon, 23 September 2013 09:15] by Moderator
Re: AbstractTransactionalCommand [message #1114991 is a reply to message #1114956] Mon, 23 September 2013 10:02 Go to previous messageGo to next message
did you try executing an EMF SetCommand? You can use SetCommand.create(...) to create one for execution.
Ralph
Re: AbstractTransactionalCommand [message #1115018 is a reply to message #1114991] Mon, 23 September 2013 10:33 Go to previous messageGo to next message
i don't try and don't know how can i
can u explain more pls ?
Re: AbstractTransactionalCommand [message #1115546 is a reply to message #1115018] Tue, 24 September 2013 04:36 Go to previous messageGo to next message
you create a SetCommannd with SetCommannd.create(...) get the command stack of the emf edit domain TransactionUtil helps here a lot and execute the command on this command stack.
Ralph
Re: AbstractTransactionalCommand [message #1115667 is a reply to message #1114956] Tue, 24 September 2013 08:09 Go to previous message
Le 23/09/2013 15:14, serhat gezgin a écrit :
> Hi all,
> dialog.create();
> // return null;
> } else {
> editingDomain,
> ((FormModel)
> ((FormModel)
Your code creates an instance of (an anynymous subclass of)
AbstractTransactionalCommand, but this is not enough: you must request
explicitly that is is executed.
AbstractTransactionalCommand cmd = ...
editingDomain.getCommandStack().execute(cmd);
Previous Topic:GMF Command
Next Topic:GMF navigator window
Current Time: Sun Jul 20 14:25:23 EDT 2025
Powered by FUDForum. Page generated in 0.03924 seconds
