Home » Modeling » TMF (Xtext) » set type of custom xbase expression
set type of custom xbase expression [message #1111189] Tue, 17 September 2013 19:17 Go to next message
I would like to have an expression that returns a certain type
This is a part of my grammar :
Entity :
  'entity' name = ValidID
 (body=XBlockExpression)
XExpressionInsideBlock returns xbase::XExpression:
  XVariableDeclaration | XExpression |  MyAgent
MyAgent is my custom xbase expression and I would like to use it on the right of the assignment operator.
I extended XbaseCompiler and XbaseTypeComputer.
This is a part of my XbaseTypeComputer :
class EntityTypeComputer extends XbaseTypeComputer {
	override computeTypes(XExpression expression, ITypeComputationState state) {
		 if ((expression instanceof MyAgent)){
		    _computeTypes(expression as MyAgent,state)}
		 else {
		    super.computeTypes(expression, state)
protected def _computeTypes(MyAgent expression, ITypeComputationState state) {
		state.acceptActualType(getTypeForName(typeof(Agent), state))
I tried to write this in my dsl editor but it doesn't work :
entity MyEntity
{ var Agent ag = myAgent }
the errors are : "no viable alternative at input 'myAgent'" and "Type cannot be derived"
what is my mistake?
Thank you in advance
Re: set type of custom xbase expression [message #1111874 is a reply to message #1111189] Wed, 18 September 2013 17:20 Go to previous messageGo to next message
On 18/09/2013 01:17, andrea rossi wrote:
> Entity : 'entity' name = ValidID (body=XBlockExpression)
> I extended XbaseCompiler and XbaseTypeComputer. This is a part of my
> XbaseTypeComputer :
> state) {
> else {
> state) {
> entity MyEntity
> cannot be derived"
> what is my mistake?
This sounds like a problem during parsing doesn't it?
I suppose you want 'myAgent' to be parsed by MyAgent rule, but it isn't,
is it?
what's the shape of MyAgent rule?
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: set type of custom xbase expression [message #1112260 is a reply to message #1111874] Thu, 19 September 2013 06:22 Go to previous messageGo to next message
this is myAgent rule :
MyAgent returns xbase::XExpression :
	{MyAgent}'myAgent' name = ValidID
If I write this in my dsl editor works :
entity MyEntity
 { var Integer i = 1
   myAgent agent
but if I write this doesn't work:
entity MyEntity
 { var Agent ag = myAgent agent}
I would like to have an expression I can use in Xblock that returns a certain type and than the expression can be used in the right part of the assignment.
How can I do this?
[Updated on: Thu, 19 September 2013 06:23] by Moderator
Re: set type of custom xbase expression [message #1112490 is a reply to message #1112260] Thu, 19 September 2013 15:45 Go to previous messageGo to next message
On 19/09/2013 12:22, andrea rossi wrote:
> MyAgent returns xbase::XExpression : {MyAgent}'myAgent' name = ValidID
> If i write this in my dsl editor work :
> entity MyEntity
> { var Integer i = 1
> myAgent agent
> entity MyEntity
> the assignment.
> How can I do this?
mh... have you tried to make your agent rule first in
XExpressionInsideBlock?
I mean
MyAgent | XVariableDeclaration | XExpression
Xtext Book:
Re: set type of custom xbase expression [message #1113047 is a reply to message #1112490] Fri, 20 September 2013 11:07 Go to previous messageGo to next message
yes I tried but it doesn't works....
Re: set type of custom xbase expression [message #1113647 is a reply to message #1113047] Sat, 21 September 2013 09:03 Go to previous messageGo to next message
On 20/09/2013 17:07, andrea rossi wrote:
You may want to try to customize XPrimaryExpression instead of
XExpressionInsideBlock...
Xtext Book:
Re: set type of custom xbase expression [message #1133353 is a reply to message #1113647] Fri, 11 October 2013 16:20 Go to previous message
Sorry for the delay of my reply, I would like to thank you for your help. It works
[Updated on: Fri, 11 October 2013 16:21] by Moderator
Previous Topic:Question about cross-linking and creation of instances
Next Topic:Disappearing arguments? (Outline)
Current Time: Sun Jul 20 10:51:03 EDT 2025
Powered by FUDForum. Page generated in 0.09017 seconds
