Home » Archived » Jubula » Observed "org.eclipse.swt.SWTException: Widget is disposed" multiple time while running au(Observed "org.eclipse.swt.SWTException: Widget is disposed" multiple time while running automation)
Observed "org.eclipse.swt.SWTException: Widget is disposed" multiple time while running au [message #1103139] Fri, 06 September 2013 08:18 Go to next message
While running automation on RCP using Jubula "Widget is disposed" error occurs multiple times, same is NOT observed when same steps are done manually.
Should there be something to be fixed in Jubula config or the AUT ?
Following is the exception trace
An error occurred. Please contact your system administrator.
  Unhandled event loop exception
  org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: Widget is disposed)
          at org.eclipse.swt.SWT.error(SWT.java:4361)
          at org.eclipse.swt.SWT.error(SWT.java:4276)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
          at java.lang.reflect.Method.invoke(Method.java:601)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
  Caused by: org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: Widget is disposed
          at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
          at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:49)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
          ... 22 more
  Caused by: org.eclipse.swt.SWTException: Widget is disposed
          at org.eclipse.swt.SWT.error(SWT.java:4247)
          at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
          at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:340)
          at org.eclipse.swt.widgets.Tree.getSelection(Tree.java:3404)
          at org.eclipse.jface.viewers.TreeViewer.getSelection(TreeViewer.java:256)
          at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:344)
          at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2544)
          at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2967)
          at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1450)
          at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:403)
          at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1404)
          at org.eclipse.jface.viewers.StructuredViewer.refresh(StructuredViewer.java:1506)
          at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer.java:537)
          at org.eclipse.jface.viewers.StructuredViewer.refresh(StructuredViewer.java:1465)
          at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
          ... 25 more
Any help/suggestion is much appreciated. Thanks
Re: Observed "org.eclipse.swt.SWTException: Widget is disposed" multiple time while runnin [message #1110788 is a reply to message #1103139] Tue, 17 September 2013 06:27 Go to previous messageGo to next message
Hi, is this error occurring just in the log, or is it popping up in your AUT?
Thanks for any information.
Re: Observed "org.eclipse.swt.SWTException: Widget is disposed" multiple time while runnin [message #1112104 is a reply to message #1110788] Thu, 19 September 2013 02:10 Go to previous messageGo to next message
Forgot to update this one.
The error was coming up as popup on RCP client, while closing one of the window.
This has been resolved now, the fix was in the code (Dev side) where something was looking up for the closed window, after closure Razz
Bhupendra
Re: Observed "org.eclipse.swt.SWTException: Widget is disposed" multiple time while runnin [message #1112253 is a reply to message #1112104] Thu, 19 September 2013 06:07 Go to previous message
Thanks for the update Smile
Previous Topic:Inconsistency in Jubula runs
Next Topic:Skip a test case based on variable
Current Time: Sun Jul 20 15:16:17 EDT 2025
Powered by FUDForum. Page generated in 0.03892 seconds
