Home » Eclipse Projects » NatTable » Right click mouse binding(Righ-click mouse binding)
Right click mouse binding [message #1108242] Fri, 13 September 2013 10:57 Go to next message
I would like to get the mouse right click binding to select when I right click over a row that is not selected.
I can configure to do the selection with the following:
uiBindingRegistry.registerMouseDownBinding(MouseEventMatcher.bodyRightClick(SWT.NONE), new SelectRowAction());
However this also applies the selection action when I right click on selected rows which I don't want it to do.
For example, I highlight multiple rows and then I right click over it.
In this situation, it removes my selections and selects the row I right clicked over.
Is there a way to solve this?
John.
Re: Right click mouse binding [message #1108360 is a reply to message #1108242] Fri, 13 September 2013 14:53 Go to previous messageGo to next message
If I understand you correctly you want to avoid performing a selection if the rows are already selected. Is that correct?
In this case you should implement a custom action that performs a check on the selected state of the row prior performing the SelectRowAction.
Re: Right click mouse binding [message #1108374 is a reply to message #1108360] Fri, 13 September 2013 15:16 Go to previous message
Yeah I just managed to figure that out and implemented the custom action.
Thanks for you response!
Previous Topic:Cell, row header, and column header selection not working in RCP app
Next Topic:Export mechanism modifications
Current Time: Sun Jul 20 13:26:46 EDT 2025
Powered by FUDForum. Page generated in 0.84839 seconds
