Firefox problem when Text is changed front-side and then server-side [message #110739] |
Wed, 29 October 2008 07:09  |
I have the following problem on Firefox3. No error on IE7.
The user edits the value of a Text component front side and selects a
button.
This selection calls a service which retrieves data and then modifies the
Text component with a new value.
As a result, I get a blank page with the following error message :
Could not evaluate javascript response:
[Exception... "Component returned failure code: 0x80004005
(NS_ERROR_FAILURE) [nsIDOMNSHTMLInputElement.selectionStart]" nsresult:
"0x80004005 (NS_ERROR_FAILURE)" location: "JS frame ::
http://127.0.0.1:1931/rap?startup=default :: anonymous :: line 171" data:
no]
If I don't edit the Text component front-side or server-side I have no
error.
Is this a known issue ? Will it be fixed or is there a workaround ?
Loïc
FUDForum. Page generated in 1.09559 seconds
