Can't "Browse Types" when attempting to add new process variables [message #1106823] |
Wed, 11 September 2013 11:45  |
I just installed Eclipse (Kepler), jBPM/Drools 5.5, and the latest BPMN 2.0 modeler (0.2.7).
I created a new process definition using the Arbitrary Cycles workflow pattern off of the modeler palette. I added a Global variable just fine in the Data Items -> Global List section - i.e. was able to create a new global and select a data type for it.
When I attempted to add a variable to the process definition (Data Items -> Variable List section), and I selected the "+" in the variable details for the data type - a "Create New Item Definition" dialog was displayed, with a "Browse Types" button. When I click on that button, nothing happens, and the following is found in the Eclipse log.
!ENTRY org.eclipse.ui 4 0 2013-09-11 10:26:30.024
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.bpmn2.modeler.runtime.jboss.jbpm5.util.JbpmModelUtil.showImportDialog(JbpmModelUtil.java:140)
at org.eclipse.bpmn2.modeler.runtime.jboss.jbpm5.property.JbpmImportObjectEditor.buttonClicked(JbpmImportObjectEditor.java:42)
at org.eclipse.bpmn2.modeler.core.merrimac.dialogs.TextAndButtonObjectEditor$1.widgetSelected(TextAndButtonObjectEditor.java:100)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
at org.eclipse.jface.window.Window.open(Window.java:802)
at org.eclipse.bpmn2.modeler.core.merrimac.dialogs.AbstractObjectEditingDialog.open(AbstractObjectEditingDialog.java:161)
at org.eclipse.bpmn2.modeler.core.merrimac.dialogs.ObjectEditingDialog.open(ObjectEditingDialog.java:67)
at org.eclipse.bpmn2.modeler.core.merrimac.dialogs.FeatureEditingDialog.open(FeatureEditingDialog.java:124)
at org.eclipse.bpmn2.modeler.core.merrimac.dialogs.ComboObjectEditor.createObject(ComboObjectEditor.java:252)
at org.eclipse.bpmn2.modeler.core.merrimac.dialogs.ComboObjectEditor$4.widgetSelected(ComboObjectEditor.java:160)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Any ideas?
THX!
Keith
FUDForum. Page generated in 0.03706 seconds
