Home » Eclipse Projects » EclipseLink » Composite Primary key error - Multiple writable mappings exist for the field
Composite Primary key error - Multiple writable mappings exist for the field [message #1104560] Sun, 08 September 2013 11:41 Go to next message
hello, have simple example code
@Entity
@Table(name = "item_author_role")
public class ItemAuthorRole implements Serializable {
  @Getter @Setter @EmbeddedId
  private ItemAuthorRoleId id;
  @Setter private Item item;
  @MapsId("itemId")
  @ManyToOne(fetch = FetchType.LAZY)
  @JoinColumn(name = "item_id", referencedColumnName = "item_id")
  public Item getItem()               { return item; }
  public boolean equals(Object obj) {
    if(obj instanceof ItemAuthorRole) {
      ItemAuthorRole role = (ItemAuthorRole) obj;
      return role.getItem().equals(item);
    return false;
  public int hashCode() {
    return new HashCodeBuilder(17, 31).append(item).toHashCode();
@Embeddable
class ItemAuthorRoleId implements Serializable {
  @Getter @Setter @Column(name = "item_id", nullable = false)
  private int itemId;
    if(obj instanceof ItemAuthorRoleId) {
      ItemAuthorRoleId id = (ItemAuthorRoleId) obj;
      return id.itemId == itemId;
    return false;
    return new HashCodeBuilder(17, 31).append(itemId).toHashCode();
Item
@Entity
@Table(name = "items")
public class Item extends AbstractModel implements Serializable {
  @Setter private Set<ItemAuthorRole> itemAuthorRoleSet;
  @Setter private Technic technic;
    itemAuthorRoleSet = new HashSet<>(0);
  @SequenceGenerator(name = "isg", sequenceName = "item_sequence", initialValue = 1, allocationSize = 2)
  @Id
  @GeneratedValue(strategy = GenerationType.SEQUENCE, generator = "isg")
  public Integer getId()                               { return super.getId(); }
  @JoinColumn(name = "item_id", insertable = false, updatable = false) //no effect
  @OneToMany(fetch = FetchType.LAZY, cascade = {CascadeType.DETACH}, mappedBy = "item", targetEntity = ItemAuthorRole.class)
  public Set<ItemAuthorRole> getItemAuthorRoleSet()    { return itemAuthorRoleSet; }
  @OneToOne
  @JoinColumn(name = "technic_id")
  public Technic getTechnic()                          { return technic; }
  @Version
  @Column(name = "opt_lock")
  private Long version;
Exception [EclipseLink-48] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: Multiple writable mappings exist for the field [item_author_role.item_id].  Only one may be defined as writable, all others must be specified read-only.
Mapping: org.eclipse.persistence.mappings.OneToOneMapping[item]
Descriptor: RelationalDescriptor(model.item.ItemAuthorRole --> [DatabaseTable(item_author_role)])
i seen this link http://wiki.eclipse.org/EclipseLink/Development/JPA_2.0/mappedbyid
but i don`t understand what wrong in my example, thanks
[Updated on: Sun, 08 September 2013 23:28] by Moderator
Re: Composite Primary key error - Multiple writable mappings exist for the field [message #1105205 is a reply to message #1104560] Mon, 09 September 2013 10:04 Go to previous messageGo to next message
Why are you using a join column on the OneToMany instead of marking it as mappedBy? Remove the @JoinColumn annotation from Item and be sure to rebuild your app.
It also looks like you are putting JPA annotations on both fields and methods. Try moving the ItemAuthorRole's getItem annotations to the item attribute, as this might be causing them to be not read. If that doesn't help, turn logging onto finest and post the annotation processing that occurs for the ItemAuthorRole entity during JPA deployment.
Best Regards,
Chris
Re: Composite Primary key error - Multiple writable mappings exist for the field [message #1105271 is a reply to message #1105205] Mon, 09 September 2013 12:01 Go to previous messageGo to next message
that already tried, the same error
why ? jpa annotations only on method, on field only @Setter annotation
  @MapsId("itemId")
but in this case it work,
  @MapsId("itemId")
  @Setter @Getter private Item item;
or this
  @MapsId("itemId")
maybe it`s bug of @Setter @Getter annotations library
thanks for help!
Re: Composite Primary key error - Multiple writable mappings exist for the field [message #1106015 is a reply to message #1105271] Tue, 10 September 2013 11:14 Go to previous message
JPA annotations must all be on the fields, or all on methods, as it is used to define the access type for the entity. In this case, you have annotations on the ItemAuthorRole id field (@Embeddable) which causes JPA to use field access and ignore the method annotations. This causes the defaults for item to be used, which is to use an "ITEM_ID" foreign key field.
Keeping all JPA annotations on fields allows your MapsId, JoinColumn and ManyToOne to be picked up and is just good practice unless there is a need for JPA to access certain fields differently. If there is, the @Access annotation allows setting the AccessType for the entity and overriding it on mappings, allowing you to specify AccessType.property on getItem() while keeping AccessType.field access on the id.
Best Regards,
Chris
Previous Topic:@CacheIndex doesn't work with Criteria Query
Next Topic:Typed query hints
Current Time: Sun Jul 20 19:40:00 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
