Home » Eclipse Projects » e(fx)clipse » Exporting an OSGi Application Project
Exporting an OSGi Application Project [message #1105844] Tue, 10 September 2013 06:55 Go to next message
just tried to export my very rudimentary application and was a bit surprised not to find a native launcher (in my case an .exe file) within the exported zip file.
I exported it from the product file editor (although the feature didn't work, but I don't care for the moment and used the plugin-based export).
The .ini files are there, so I guess I', missing something.
Any hints?
Thanks in advance,
Daniel
Re: Exporting an OSGi Application Project [message #1105850 is a reply to message #1105844] Tue, 10 September 2013 07:02 Go to previous messageGo to next message
The problem with the native launcher is that on OS-X it stalls the
system because it occupies the event loop, hence the flag is not set in
the .product file.
I'd suggest you use the generated maven poms then you can also run the
build in a headless fashion.
Tom
On 10.09.13 12:55, Daniel Zimmermann wrote:
> Any hints?
> Thanks in advance,
> Daniel
Re: Exporting an OSGi Application Project [message #1105851 is a reply to message #1105850] Tue, 10 September 2013 07:02 Go to previous messageGo to next message
oh and launching it on the command line is trivial as well:
java -jar plugins/org.eclipse.equinox.launcher_...jar will launch the
application.
Tom
> the .product file.
> Tom
>> Hi,
>> Any hints?
>> Thanks in advance,
>> Daniel
Re: Exporting an OSGi Application Project [message #1105878 is a reply to message #1105851] Tue, 10 September 2013 07:45 Go to previous messageGo to next message
Thank you for both tipps. I could have thought of the java -jar... thing by myself. As far as I remember it is only necessary for "default" applications when using SWT, correct?
Anyway: I'll follow your suggestion and will doe the Maven thing later - this export was really "just-for-fun"!
Thank you very much for your help, Tom!
Greetings,
Daniel
Re: Exporting an OSGi Application Project [message #1105888 is a reply to message #1105878] Tue, 10 September 2013 07:52 Go to previous messageGo to next message
You mean the .exe generation? Well it bootstraps java and in shows e.g.
The maven build has the advantage that it will generate:
a) a setup.exe
b) package the jre with your application
makeing it read to get deployed to app-stores (if you run it on OS-X you
'll get a dmg package which you can put into the Mac App Store)
Tom
> Greetings,
> Daniel
Re: Exporting an OSGi Application Project [message #1106032 is a reply to message #1105888] Tue, 10 September 2013 11:34 Go to previous messageGo to next message
That's nice indeed! Don't ask why, but my Maven knowlegde is tending against zero (never realy needed it). But I have some colleagues that are quite fit in it, so no questions about that topic from my site (for now Razz ).
Thank you again and keep up the good work!
Daniel
Re: Exporting an OSGi Application Project [message #1106708 is a reply to message #1106032] Wed, 11 September 2013 08:40 Go to previous messageGo to next message
Out of pure curiosity: Is an export via the product file even possible?
I ask this, because I just tried it again and while the export itself was successfull, I could not start the application.
I have checked the native laucher artifacts (otherwise no org.eclipse.equinox.launcher would be present in the plugins dir), the product is based on plugins (for now) and the dependencies seems to be solved. I left the start levels in the product as there where in the begining (maybe I should adjust that).
The export is synched, p2 repo is checked as well as allow binary cycles.
When I try to start the app via the launcher I receive the following exception:
java.lang.ClassNotFoundException: my_package.platform.app.MainApplication cannot be found by my_package.platform.app_0.0.0.201309111437
That rises my eyebrows and leaves only question marks in my face...
Re: Exporting an OSGi Application Project [message #1107521 is a reply to message #1106708] Thu, 12 September 2013 10:27 Go to previous messageGo to next message
Just to keep you updated: Short time after writing the last post I checked the plugin jars.
The exception was quite sensible in one way: There was no - and to be precise: not a single - class file within the jars... Interessting.
Re: Exporting an OSGi Application Project [message #1114893 is a reply to message #1107521] Mon, 23 September 2013 07:16 Go to previous messageGo to next message
Hi Tom,
Today I started to dig into the problem of the export again. I don't know, why it didn't occur to me earlier, but I checked the zip file with the logs today and was surprised by the errors I read there
ERROR in C:\Users\dzimmermann\git\standalone_container\my.platform.service\src\my\platform\interfaces\UITabComponent.java (at line 3)
	import javafx.scene.control.Tab;
The import javafx cannot be resolved
Other errors (in other bundles, but most likly a consequnece of this one are for example)
1. ERROR in C:\Users\dzimmermann\git\standalone_container\my.platform.app\src\my\platform\app\util\Utils.java (at line 0)
	package my.platform.app.util;
The type javafx.stage.Stage cannot be resolved. It is indirectly referenced from required .class files
or
ERROR in C:\Users\dzimmermann\git\standalone_container\my.devhandler\src\my\devhandler\ui\DevicesController.java (at line 53)
	public class DevicesController implements Initializable {
Initializable cannot be resolved to a type
And so on and so forth...
Tom: Do you know, what the problem could be? And to ask the question you might have: No, I'm still not using Maven for the export...
Daniel
PS: Without knowing to much about Maven, I tried to update all the bundles pom files (added the parent-element that points to the releng-pom, added all bundles to the releng's modules list) and re-run it which caused the following error (which I'm absolutly uncertain about how to solve it):
[INFO] {osgi.ws=noenv, osgi.os=noenv, osgi.arch=noenv, org.eclipse.update.install.features=true}
[ERROR] Cannot resolve project dependencies:
[ERROR]   Software being installed: my.platform.app.product 1.0.0
[ERROR]   Missing requirement: my.platform.app.product 1.0.0 requires 'org.eclipse.equinox.executable.feature.group 0.0.0' but it could not be found
[ERROR]
[ERROR] Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from my.platform.app.product 0.0.1 to org.eclipse.equinox.executable.feature.group 0.0.0.", "Unable to satisfy dependency from my.platform.app.product 1.0.0 to org.eclipse.equinox.executable.feature.group 0.0.0.", "No solution found because the problem is unsatisfiable."] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from my.platform.app.product 0.0.1 to org.eclipse.equinox.executable.feature.group 0.0.0.", "Unable to satisfy dependency from my.platform.app.product 1.0.0 to org.eclipse.equinox.executable.feature.group 0.0.0.", "No solution found because the problem is unsatisfiable."]
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
	at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
	at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
	at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
	at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
	at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from my.platform.app.product 0.0.1 to org.eclipse.equinox.executable.feature.group 0.0.0.", "Unable to satisfy dependency from my.platform.app.product 1.0.0 to org.eclipse.equinox.executable.feature.group 0.0.0.", "No solution found because the problem is unsatisfiable."]
	at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.newResolutionException(AbstractResolutionStrategy.java:98)
	at org.eclipse.tycho.p2.resolver.ProjectorResolutionStrategy.resolve(ProjectorResolutionStrategy.java:88)
	at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.resolve(AbstractResolutionStrategy.java:63)
	at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:126)
	at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:81)
	at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:374)
	at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:350)
	at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:109)
	at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:82)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:274)
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
	... 11 more
Re: Exporting an OSGi Application Project [message #1114936 is a reply to message #1114893] Mon, 23 September 2013 08:39 Go to previous messageGo to next message
So are you compiling against Java7? The problem there is naturally that
the jfxrt.jar IS NOT on the classpath hence compilation fails:
2 solutions:
* you temporarily copy the guy to your ext dir
* you install jfxrt.jar into your local maven repo and then your
reconfigure your tycho-compiler-plugin to hold an
<extraClasspathElements>
Something like this:
> <plugin>
> <groupId>org.eclipse.tycho</groupId>
> <artifactId>tycho-compiler-plugin</artifactId>
> <version>${tycho-version}</version>
> <configuration>
> <encoding>UTF-8</encoding>
> <!-- mvn install:install-file -Dfile=/Users/tomschindl/Applications/javafx-sdk2.2.0-beta/rt/lib/jfxrt.jar -DgroupId=javafx -DartifactId=javafx.mvn -Dversion=2.2.0-SNAPSHOT -Dpackaging=jar -DgeneratePom=true -->
> <extraClasspathElement>
> <groupId>javafx</groupId>
> <artifactId>javafx.mvn</artifactId>
> <version>2.2.0-SNAPSHOT</version>
> </extraClasspathElement>
> </extraClasspathElements>
> </configuration>
> </plugin>
You see how to install jfxrt.jar into your .m2 repo on the comment but
your maven-aware friends could explain this to you as well - I'm a maven
dummy doing monkey see monkey do.
Tom
Tom
On 23.09.13 13:16, Daniel Zimmermann wrote:
> Hi Tom,
> ERROR in
> (at line 3)
> are for example)
> 1. ERROR in
> (at line 0)
> or
> ERROR in
> (at line 53)
> Regards,
> Daniel
> how to solve it):
> found
> [ERROR] [ERROR] Internal error: java.lang.RuntimeException: "No solution
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 11 more
Re: Exporting an OSGi Application Project [message #1114937 is a reply to message #1114936] Mon, 23 September 2013 08:40 Go to previous messageGo to next message
Oh just saw we already generate the extraClasspathElements stuff so all
you need is to execute the mvn install:intall-file.
Tom
On 23.09.13 14:39, Tom Schindl wrote:
> 2 solutions:
>> <plugin>
>> <configuration>
>> </configuration>
>> </plugin>
> Tom
> Tom
>> Hi Tom,
>> ERROR in
>> (at line 3)
>> are for example)
>> 1. ERROR in
>> (at line 0)
>> or
>> ERROR in
>> (at line 53)
>> Regards,
>> Daniel
>> how to solve it):
>> found
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 11 more
Re: Exporting an OSGi Application Project [message #1115008 is a reply to message #1114937] Mon, 23 September 2013 10:24 Go to previous messageGo to next message
Hi Tom,
sorry, that I didn't mentioned it, that I'm using Java7...
I saw, that there is that extraClasspathEntry element. I currently don't understand what you mean by
a) copying the jfxrt.jar into the "ext" dir <- which one is the "ext" dir? I guess I would need to do this for the product-based export
b) the tycho-thing: So I call the "mvn install [...]" stuff (from the CLI), you did in your first post, before starting the Maven task in Eclipse? Is that correct?
Thanks again,
Daniel
Re: Exporting an OSGi Application Project [message #1115020 is a reply to message #1115008] Mon, 23 September 2013 10:31 Go to previous messageGo to next message
it's one of the other!
On 23.09.13 16:24, Daniel Zimmermann wrote:
> Hi Tom,
> understand what you mean by a) copying the jfxrt.jar into the "ext" dir
this is the extension-lib dir of your JRE - but this would pollute your
jre which is not good
yes - this is the option to go
> Thanks again,
> Daniel
Re: Exporting an OSGi Application Project [message #1115040 is a reply to message #1115020] Mon, 23 September 2013 11:11 Go to previous messageGo to next message
Ok I still don't see the connection between the missing jfxrt.jar and the "org.eclipse.equinox.executable.feature.group" element, but since you're the one of us two actualy knowing, what he's doing, I think I should just believe you! Wink
One final question... For now...
When I execute the command (with the correct path/to/my/jfxrt.jar from a random path, the build failes with something "The goal you specified requires a project to execute but there is no POM in this directory (C:\Users\dzimmermann\.m2). Please verify you invoked Maven from the correct directory." - so I need to create a new and empty maven project within the .m2/repositories directory? Or do I have to invoke the code from within my releng-project?)
I'm indeed sorry to ask all this questions, but my maven-aware colleagues already went home... :-/
Re: Exporting an OSGi Application Project [message #1115050 is a reply to message #1115040] Mon, 23 September 2013 11:30 Go to previous messageGo to next message
Beside the stuff from my last post, I just saw this StackOverflow question: http://stackoverflow.com/questions/15278215/maven-project-with-javafx-with-jar-file-in-lib
Would a system dependecy as described in the answer be sufficient enough? What do you think? I will try this tomorrow, for now I'm done with it...
Thanks and bye,
Daniel
Re: Exporting an OSGi Application Project [message #1115077 is a reply to message #1115050] Mon, 23 September 2013 12:23 Go to previous messageGo to next message
most likely.
Tom
> question:
> with it...
> Thanks and bye,
> Daniel
Re: Exporting an OSGi Application Project [message #1115078 is a reply to message #1115040] Mon, 23 September 2013 12:25 Go to previous messageGo to next message
did it copy the jfxrt.jar to the .m2 hierarchy? The problem you see is
that the compiler is unable to compile your classes because jfxrt.jar is
not on a classpath (the lib folder stuff is NOT on the default classpath
for your JRE hence the compiler can't find the javafx classes).
Tom
> should just believe you! ;)
Re: Exporting an OSGi Application Project [message #1115507 is a reply to message #1115078] Tue, 24 September 2013 03:40 Go to previous messageGo to next message
not on a classpath
No unfortunatly it didn't copy the jfxrt,jar into a maven bundle. There was just this error message telling me the build failed.
I even tried to copy the file into Java's ext directory but this didn't help (with the product export) either.
I will now try the system dependency, but it's getting more and more like searche for the needle in the hay stack... I will tell you, if the system dependency is working. If not - well - then I'm kinda lost.
Re: Exporting an OSGi Application Project [message #1115522 is a reply to message #1115507] Tue, 24 September 2013 03:58 Go to previous messageGo to next message
So are you now using maven or the product-export from within Eclipse?
Tom
On 24.09.13 09:40, Daniel Zimmermann wrote:
> Quote:
>> not on a classpath
Re: Exporting an OSGi Application Project [message #1115543 is a reply to message #1115522] Tue, 24 September 2013 04:34 Go to previous messageGo to next message
I tried both. Both using jdk7.
1) Maven - w/ or w/o the system dependecy I always get the error I described above
[ERROR]   Software being installed: ch.cnlab.swag.platform.app.product 1.0.0
[ERROR]   Missing requirement: ch.cnlab.swag.platform.app.product 1.0.0 requires 'org.eclipse.equinox.executable.feature.group 0.0.0' but it could not be found
[ERROR]
[ERROR] Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from ch.cnlab.swag.platform.app.product 0.0.1 to org.eclipse.equinox.executable.feature.group 0.0.0.", "Unable to satisfy dependency from ch.cnlab.swag.platform.app.product 1.0.0 to org.eclipse.equinox.executable.feature.group 0.0.0.", "No solution found because the problem is unsatisfiable."] -> [Help 1]
2) Product build - no class files (doesn't matter if I add the jfxrt.jar to the ext dir or not)
Re: Exporting an OSGi Application Project [message #1115560 is a reply to message #1115543] Tue, 24 September 2013 05:02 Go to previous messageGo to next message
I managed to have a working build with the product base build mechanism. I'm not really satisfied with a) the idea of using products or b) the way I fixed it: I copied the jfxrt.jar into a libs directory in one of my bundles and added a build-dependency to it on the build page ("Extra Classpath Entries") of each other bundle to it (since it says "List any extra libraries required on the plug-in's classpath for successful compilation." I figured this could help and it did indeed).
I'd still rather make use the maven thing but my colleagues never used tycho and were confused where the other dependencies came in (at least this I was pretty sure about, that tycho does that for us). If you have any suggestions about the "org.eclipse.equinox.executable", I'd gladly use this...
Re: Exporting an OSGi Application Project [message #1115598 is a reply to message #1115543] Tue, 24 September 2013 06:05 Go to previous messageGo to next message
so this means that we need to get this going, what looks supisicous is
that it tells:
So maybe your versioning does NOT match.
Tom
> described above
> 1.0.0
> could not be found
Re: Exporting an OSGi Application Project [message #1115601 is a reply to message #1115560] Tue, 24 September 2013 06:08 Go to previous messageGo to next message
This is not how this should work and it will cause troubles when you
have to classes of e.g. Node, ... .
> use this...
Yes tycho internally does all the dependency resolving using the
MANIFEST.MF-Files and the p2-repos you point it to.
Our company offers professional support - I expect to have this problem
resolved in less than an hour if I have access to the source - You
really have to get the MAVEN-Build going this is the only future proof way.
You can get in touch with me at tom.schindl@xxxxxxxx
Tom
Re: Exporting an OSGi Application Project [message #1115602 is a reply to message #1115598] Tue, 24 September 2013 06:10 Go to previous message
Tycho is a lot more picky than the eclipse product export!
Tom
> that it tells:
> Tom
>> described above
>> 1.0.0
>> could not be found
Previous Topic:ClassNotFoundException when loading Controller via FXML
Next Topic:Relative width of Parts in PartSashContainer - containerData has no effect
Current Time: Sun Jul 20 14:28:55 EDT 2025
Powered by FUDForum. Page generated in 0.29916 seconds
